Question about Health & Beauty
How do i get my tumi scale to work?
My tumi scale just says lo and CAL
Model 9114 salter scale shows Lo. I have changed the batteries but it still only shows Lo.
I had the same problem and, suspecting that the metal contacts weren't making proper contact with the batteries, I used a long nosed pliers to gently bend all ten contacts towards to the batteries (there are eight small tabs in the battery compartment, and two on the battery cover). If you don't have a long nosed pliers a small screwdriver should do it if you held the fixed part of each set of contacts so it doesn't detach during the process.
Unfortunately, it worked, but only for one weigh, and then it reverted to "Lo". This happened twice, so I telephoned the Salter Customer Service Helpline (01732 360783) who recommended a reset, which is done by removing the batteries, standing on the scale for 20 seconds, and replacing the batteries. That also only worked for one weigh, so they are looking into it further and I'll post the results here, but in the meantime I hope one of the above solutions will work for others.
Jan 21, 2014 | Salter Stainless Steel Electronic Bathroom...
How do you replace the battery on the 7544BL Cal-Max Scale
How do I replace the battery in my Taylor 7544BL Cal-max scale.
We removed the back and the lithium battery is positioned oppisite the opening?
May 07, 2013 | Taylor New 7544bl Biggest Loser Cal-max...
Shows 0.0lb no weight
Well I figured it out, just in case anyone comes across this. Turn it over, push the button on the top middle of the scale, hold, turn back over, wait until "C" appears on the screen, stand on scale, now it works. :)
Jan 10, 2012 | Taylor Biggest Loser 7206 Electronic Cal...
Scale keeps showing lo no weight
Try taking the battery out and putting it back in, also there should be a small reset button. You will need a toothpick to push the reset button. Allow time for the scale to reset before stepping on it.
Apr 19, 2011 | Homedics Digital Scale
I replaced the battery and now the scales read "Err" what do I do now?
hello
I own a cal-max digital scale and i replace batteries and still not working it is showinn err
Feb 27, 2011 | Taylor & Digital Scale Lithium Scale
Swr meter not moving
follow these steps to adjust the
standing wave ratio(SWR).
1. Turn on the CB.
2. Set S/RF/SWR/CAL to CAL.
3. Key the Mic and rotate SWR CAL so the meter points
to CAL.
4. Unkey Mic.
5. Set S/RF/SWR/CAL to SWR.
6. Key Mic again and note the actual measurement on
the SWR scale. Refer to the following table to interpret
the reading.
1:1 - 1.5 Great
1.5 - 2:1 OK
2:1 - 3:1 Not So Good
Higher than 3.1:1 Terrible
Jan 14, 2011 | Cobra 29 LTD CB Radio
THE SCALE WE HAVE IS A "TAYLOR CAL MAX BIGGEST LOSER SCALE" AND IT ALWAYS SHOWS "ERR1" WHEN YOU STEO ON IT.
When you step on it and get the err1 message step off wait a few seconds and step back on, remember that while the scale is processing your weight you MUST remain STILL.
good luck
Aug 12, 2010 | Taylor Biggest Loser 7206 Electronic Cal...
E appears on Salter scale, even with new batteries
Hallo I have problem witch kitchen scale Salter.E appear when I pushed on and it takes 3 sec
How can I fix this problem
Than You
Sep 18, 2009 | Salter 2001 electronic kitchen scale
Health & Beauty Logo
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
