Question about Humidifiers
My son gave me the ultrasonic oil diffuser as a gift. he bought it from Amazon...the mist worked one time only, now not at all!!
2 Suggested Answers
swc6912
  • 62 Answers
SOURCE: My diffuser will not mist. The lights are on and it is running fine otherwise. What is the problem?
Did you use distilled water ?
Ours called for distilled water to work correctly, we used tap water and it worked for the first few times. then started making noise and then stopped.
Started using RO water, (like distilled) and started working again.
Posted on Apr 07, 2015
How do I clean the dual tank ultrasonic humidifier membrane
Air Innovations Clean Mist Ultrasonic Dual Tank Humidifier ...
www.qvc.com/Air-Innovations-Clean-Mist-Ultrasonic-Dual-Tank-H...
QVCAir Innovations Clean Mist Ultrasonic Dual Tank Humidifier. Air Innovations ..... I did not realize that you needed a special filter if you have hard water. If you do ...
Sharper Image Dual Tank Warm &Cool Mist Ultrasonic ...
www.qvc.com/Sharper-Image-Dual-Tank-Warm-&Cool-Mist-Ultras...
QVCSharper Image Dual Tank Warm &Cool Mist Ultrasonic Humidifier ..... I've only had toclean the membrane once since I purchased it, and that's really not a big ...
How to Repair an Ultrasonic Humidifer ' eBay
Dec 14, 2015 | Humidifiers
Apr 07, 2015 | Humidifiers
Motor runs but no mist comes out on EV-HD15
If there is water in it, it sounds like the ultrasonic unit failed.
Dec 05, 2014 | Sharper Image EV-HD15 Cool Mist Ultrasonic...
Just stopped giving mist
Depending upon the hardness of your water supply, humidifiers sometime have to be "primed" to get them going. This information should be contained in the instructions for use
May 04, 2013 | Sunpentown Cool Mist SU-2000 Ultrasonic...
Does the Sunbeam Ultrasonic Humidifier Model 696-12 have a filter?
This humidifier is AMAZING. I’m a huge fan of using essential oils (lavender, lemongrass, spruce, rose, sandalwood etc) and I picked this up from a thrift shop, added some essential oils to the water and my house smells wonderful.
Essential oil diffusers are virtually the same thing design wise except cost a fortune. This is my best diffuser! I paid $10 for it and it works so good, throws off a ton of mist which I love (it’s so dry here) and I will enjoy owning this unit for years to come. Only thing is to gently clean the little ionizer part with the brush gently and keep it clean. Also..this unit unlike newer ones does NOT shut off automatically so keep an eye on it. Running it dry might cause it to burn out.
Jan 07, 2012 | Sunbeam Ultrasonic 81696 Humidifier
There is not mist coming out. What should I do??
The moisture released by this (or any ultrasonic) humidifier should not be visible, so it is very possible that it is working correctly. Try filling the reservoir and marking the water level with a small piece of tape. Then run the humidifier for a few hours, and check the water level again. If the water level is below the edge of the tape, then you know it is releasing moisture into the air, and everything is working fine.
The older style of humidifiers created a mist by spinning a disk that was partly dipped into the water reservoir. They had to be refilled often, and the mist could leave water spots or dust on nearby furniture. The water level should change very slowly in your ultrasonic humidIfier compared to a misting humidifier.
Jan 13, 2011 | Vicks Ultrasonic V5100 Humidifier
WHY DON'T MIST COME OUT OF MY HUMIDIFIER
with cool mist humidifiers your not suppose to see any mist. if it's a warm mist there should be. but by your model number i'm finding that it's a cool mist. that's why your not seeing any mist.
Aug 15, 2009 | Vicks Cool Mist V3500 Humidifier
Sunbeam ultrasonic humidifier runs but produces no mist
It sounds very much like the transducer has failed. This is likely a crystal transducer and since they produce the agitation that should cause a mist, they are running continuously; not a good thing for something that is trying to shake iteslf apart all the time. These require input from a circuit that produces the fairly high level of power needed to drive the crystal so it could also be the source of the problem.
This isn't something an owner is able to diagnose unless they have some technical training.
Nov 08, 2008 | Sunbeam Ultrasonic 81696 Humidifier
Humidifiers Logo
109 people viewed this question
Top Humidifiers Experts
Paul Carew
Dennis
Are you a Humidifier Expert? Answer questions, earn points and help others
