I've just been struck down with this too on my newly purchased MM-E460D. I think I've worked it out, its just a poor description and manual. iPod mode" means choose the music off the iPod via a connected TV whereas "Remote iPod" is choose the music off the iPod via the Samsung remote and also directly from the iPod interface. I've been there for days trying to get "iPod mode" to work via the iPod interface.
This is always tricky with 1st generation iPod touches. After a while they can't handle the new software anymore and some functions won't work anymore. Maybe try to downgrade the software. Otherwise you should probably get a new iPod.
you will have to connect an audio output from the tv to the sourround reciver. you should have some audio output on the back of the tv and a corresponding input on the samsung ht c555
I've managed to sort this problem (well sort of)
ipod can be connected to the usb connection BUT although you can play the music it's not completely compatable formats
the answer is to use a "Y cable" connecting to the earphone out put of the ipod to the 2 aux. (audio) connections on the home cinema
Plug a yellow video cable into the TV (IN) and the Sound system (Out) then go onto AV1 on the TV or which ever port you plugged the cable into and play a movie and u can see it. A menu doesnt come up like the A ipod funtion so it comes up no signal until u play an actual movie on the ipod. If u dont have a yellow video cable i think u can use the white or red audio ones.
I also have the same problem but now I think it's the type of I-Pod you use. Do you use the I-Pod 80 Gb video or the newer 160 Gb I-Pod with the cover flow etc. ? The documention of the HTD7001 says it's only support some I-Pods. I would know sure if I would have a type of Video I Pod wich is supported by the documentation
If you connect an iPod via USB, the system will treat it as a hard drive and will use its (very basic) on-screen system to display your tracks.
I found the best way to get a result is to use a 3.5 (stereo) jack to RCA phono stereo input into the auxillary input on the back (side). To hear your iPod, select AUX on your Samsung and then select and play on your iPod. Bobs your uncle!!
