Question about Building Materials
This unit is new and only worked one so door has not been used many times just trying to get to woek
Remotes stop working after long period
The receiver in the circuit board is going bad. It works on all of the wireless devices.
Feb 21, 2014 | Sears Craftsman LiftMaster Chamberlain...
I live in a 4-unit condo building constructed in 2008. Recently, after I trained/programed a garage door opener incorporated in a new car I purchased, I discovered that my garage door started to be...
I would recommend this. I'm not sure this will work, but I think it will.
Try starting from scratch. Reprogram the unit to the car again, I think the codes change each time it is done. If not, it's not too difficult to try.
Jan 01, 2011 | liftmaster Chamberlain Garage Door Opener...
1999 passat Window motor stops woeking i unplug it
try hooking up a wire to the chassis of the wiper motor to the body of the car could be bad ground
Mar 05, 2010 | Volkswagen Passat Cars & Trucks
My 1994 camaro air conditioner does not woek how do i fix it myself?
When was the last time it worked. 6 months or more? Most of the time the compressor be leaking freon. and must be replaced.
Dec 05, 2009 | 1994 Chevrolet Camaro
Genie remotes stopped working
The receiver can go bad and that would stop all remotes from working. The wall control would still work because it does not use the receiver.
Sep 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have a non-functioning keypad for my Liftmaster garage door. It's 8 years old. In the past changing the battery has remedied the problem. This time I changed the battery twice with no success. The light...
First of all, did you try recoding unit by hitting LEARN BUTTON on motor. Try that. If n/g, try a new code with a number you did not use. Example, if old code was 5834, try 2222. If it works, one of the numer from you old code is worn out. Try new code or buy new pad.
Jan 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Freezer door does not close tightly.
You can try replacing the seals and or adjusting the hinges.
That may work.
Be aware that if the unit is over 10 years old it is probably using twice as much power as a new one would and costing you an extra $75 to $100 annually to run over a new unit. Could be more than that if the door seals are not tight as well.
Jan 01, 2009 | Kenmore 13.7 cu. ft. / 388 liter Upright...
send me am e mail at with the model number
May 31, 2008 | KitchenAid Architect Series KEMC308KSS...
Building Materials Logo
26 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
