I don't have a computer how can I gain access to my iPad that is locked and I forgot password
SOURCE: Phone lock for samsung SHG-U700
just press *2767*2878# on the phone to reset it, code will be 00000000 but you will loose all data on phone
Posted on Apr 04, 2008
dww0642
  • 79 Answers
SOURCE: Admin account on Vista pc locked out, forgot admin password
Step 1
START THE COMPUTER. DO THIS BY PRESSING THE POWER BUTTON. DO NOT WAIT UNTIL WINDOW LOADS TO PERFORM STEP 2.
Step 2
PRESS F8 KEY ***BEFORE*** WINDOWS VISTAmag-glass_10x10.gif BEGINS START UP. THIS WILL PROVIDE A LIST OF OPTIONS FOR HOW TO PROCEED.
Step 3
CHOOSE TO START YOUR COMPUTER IN "SAFE MODE".
Step 4
OPEN THE START MENU.
Step 5
OPEN THE CONTROL PANEL (from within the Start Menu).
Step 6
SELECT "USER ACCOUNTS AND FAMILY SAFETY" IN THE CONTROL PANEL POP-UP WINDOW.
Step 7
CLICK THE "CHANGE YOUR WINDOWS PASSWORD" LINK BENEATH THE "USER ACCOUNTS" SECTION.
Step 8
CLICK "REMOVE PASSWORD". VERIFY AND SUBMIT.
Step 9
RESTART YOUR COMPUTER NORMALLY. DO NOT PRESS F8.
Step 10
TO RESET A PASSWORD, ACCESS THE "USER ACCOUNTS AND FAMILY SAFETY" MENU AGAIN. THIS TIME CLICK "CHANGE YOUR WINDOWS PASSWORD", PROVIDE THE DESIRED PASSWORD, VERIFY AND SUBMIT. THIS TIME, WRITE YOUR PASSWORD DOWN.
If this helps please rate me. thanks
Posted on May 09, 2009
  • 19 Answers
SOURCE: forgot my password to get into my text messages
call the phone company they will reset it
Posted on Jun 02, 2009
bhautesh1983
  • 402 Answers
SOURCE: i forgot the bios password
The simplest way to remove a BIOS password is to simply remove the CMOS battery. A computer will remember its settings and keep the time even when it is turned off and unplugged because these parts are powered by small battery inside the computer called a CMOS battery. If we pull out this battery, the computer will forget alot of its hardware settings, including its BIOS password. This should not be performed on Laptops if you are not experienced working with laptop hardware.
Anyway, open up the computer case using a screw driver and locate the flat, circular and metallic CMOS battery. It should look something like the picture to the right. Some computers have this part standing upright.
Once you have located it, observe how the latches are holding it. There are many different ways to remove a CMOS battery but the most common way on newer computers can be seen in the picture below.
Make sure to power down the computer, unplug the power cables and unplug any USB devices if they are powered. The computer must not be able to get power from anywhere for this to work. Take out the CMOS battery and wait 10 – 25 minutes before putting it back in. The reason for this wait is because the computer can still store power in its capacitors even though everything is unplugged. The waiting period allows enough time for them to discharge.
Plug everything back in, power up the computer and enter the BIOS again. If everything went well there should be no more password. In some cases, if you get weird error messages during bootup now, you will need to goto “Load BIOS Defaults” in BIOS and save the changes to fix them.
And Thanks.
Posted on Mar 22, 2010
SOURCE: Ipad disabled b/c son forgot his password...help us get in?
If your son cannot remember the passcode, you will need to restore your iPad using the computer you last synced your iPad with. Using the last computer you synced with allows you to reset your passcode and re-sync all your data, apps, etc.
To begin the process, connect the iPad to your computer using the USB cable or lightning cable. Open iTunes and select the restore option.
If you restore on another computer, you can still unlock the device and remove the passcode, but your data and apps will be wiped.
Hope that helps!
Posted on Apr 03, 2013
Password isnt working. think i got hacked
If this is the case I would suggest that you click on the forgot password link on the account that you are trying to access. Otherwise, I would suggest for you to follow the following steps below on how to gain access to your locked out computer
https://www.bullguard.com/blog/2015/10/how-to-access-your-pc-if-you-forgot-your-windows-password.html
Jul 13, 2017 | Computers & Internet
Forgot home screem password for android ipad
How to bypass Android's lock screen pattern, PIN or password
trendblog.net > Guides
Oct 18, 2015 - How to bypass Android's lock screen pattern, PIN or password ..... Hi can anyone help me I have lost my android tablet device in my bedroom ...
How to unlock an Android phone/tablet - How-To - PC Advisor
www.pcadvisor.co.uk > ... > How to unlock an Android phone/tablet
Feb 4, 2013 - But what do you do when you forget your own access code? ... Choose a new screen lock option, such as a pattern or PIN, then enter a code. ... If you've locked your Android smartphone or tablet with a PIN or password, ...
Forgot iPad Screen Lock Password - How to Recover Data ...
www.wondershare.com > Resource > iPhone
Jan 01, 2016 | Tablets & eReaders
A disabled ipad.
When you've forgot the lock screen password of your iPad tablet, you get 6 tries of the password entering. After that, the only way you could do is restore you iPad to Factory Settings, which would then no doubt delete your data and files on iPad. The lost data and files would not be backed up on iTunes then. In such case, the only way you could recover data and files from locked iPad is to use 3rd-party data recovery software app. Feel free to read this article to know how to recover files from your locked iPad.
Forgot iPad Screen Lock Password How to Recover Data from Locked iPad
Oct 15, 2015 | Apple iPad Tablets & eReaders
A small lock is shown next to wifi on my ipad cannot gain entrance to internet? what do I do
The lock shows the wifi is locked with a password. If you choose that wifi account it will let you enter the password to access it
Sep 25, 2014 | Apple iPad Flexi Case with Plastic Folding...
My iphone has ben inadvertanly locked by passcode, the optus folk have said I have to delete everything through iTunes but I cant get action as I dont have an apple ID or password. plase assist? I don
Hi, there!
You can easily create your own Apple ID here: https://www.apple.com/icloud/setup/
But it seems that your particular iPhone is locked via the former owners Apple ID, which gives you no option other than contacting him and asking to delete this iPhone from his iCloud account.
Best regards,
B
Sep 25, 2014 | Apple iPhone 4 Black Smartphone
Ipad recovery
When you've forgot the lock screen password of your iPad tablet, you get 6 tries of the password entering. After that, the only way you could do is restore you iPad to Factory Settings, which would then no doubt delete your data and files on iPad. The lost data and files would not be backed up on iTunes then. In such case, the only way you could recover data and files from locked iPad is to use 3rd-party data recovery software app. Forgot iPad Screen Lock Password How to Recover Data from Locked iPad
Jul 31, 2014 | Apple Ipad2 32GB Wifi
How do I Unlock ipad screen if I forgot the 4 digit passwordbut i don't have How do I Unlock Ipod screen if I forgot the 4 digit passwordbut i don't have firstcomputer to log in
Don't worry, if you prefer an easier way to do the job, see how you can achieve it and get your iPad unlocked on your PC or Mac on your own with the help of this website: automaticiphoneunlocker.com
Jun 08, 2012 | Apple Ipad I-pad
My hard drive disk is locked and i forgot the password how can i fix it
LOL, you are SOL (Shid Outta Luck). Most times when the hard drive is password protected it was put there by the original owner to keep thieves from gaining access to sensitive data. They can lock it everyday or they can do it remotely once it is stolen. So the million dollar question is: Did You Steal It or Buy it Hot? Anybody smart enough to put a password on the hard drive is smart enough to remember it. After all, most people don't know how to do it.
The only way you're going to get the access to the computer is to get the original owner to give you the password. LOL
Mar 21, 2012 | Acer Computers & Internet
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
