Where do I find the antennae inlet for neoniq 18.5 tv
I bought a 55 burn STV 18 months ago and it is still sitting as a wall decoration, I cannot get anything on the TV working except no signal.
do you have an antenna connected up
are the antenna wires circuit correct
why waste 18 months of a warranty if it didn't work for all of that time
Sep 10, 2017 | Televison & Video
I need a new remote for my Neoniq ELTL22EXFHDD. Can I use universal remote and if so what code do I use? Thank You
https://www.ebay.co.uk/sch/i.html?_odkw=Neoniq+ELTL22EXFHDD&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313.TR0.TRC0.H0.XNeoniq+remote.TRS0&_nkw=Neoniq+remote&_sacat=0
Jun 26, 2017 | Universal Televison & Video
I have a neoniQ LEF 4290 tv that will not turn on
Could be an open fuse or power supply failure
Dec 18, 2016 | Televison & Video
Was given a Neoniq tv with no remote.I have a Arista Universal remote but lost code list.Please help
Arista Usually Has PDF Copy On Website (download and save in documents)--If Model Is Not Listed Use Manual Code Search Procedure. NOTE: Universal Remotes Will Not Always Enable All Functions. If This Happens OEM Remotes Are Available On eBay By TV Name And Model Number. ie: neoniq ******** remote
Feb 28, 2015 | Universal Televison & Video
Universal Remote Control code for neonIQ LCF3218
I am guessing you have a universal remote to replace the original NeonIQ remote. If so, you can use the universal's "code search" feature to find a code that will work. Codes are stored in the remote. If a thorough search does not turn up a usable code, you may have to try another universal remote. Not all codes are stored in every universal remote.
Sep 17, 2014 | Televison & Video
Neoniq my remote control for a neoniq tv 32inches it does not working.the tv itself is working fine,how do fix them or what can use as replacement,thanks
Check the remote control for its infrared emission first. If it is found OK, check other codes said to your TV brand. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/
Feb 24, 2014 | Televison & Video
I need a code for my NEONIQ tv so I can use an universal remote control
You can use a universal remote to this set. Buy a universal remote which have setup codes for your TV.
May 31, 2012 | Televison & Video
How can i hook an antennae to the tv
Hello, Thanks for using Fixya.com
Hello , We are here to help you.
On the back of the TV you should have a Coaxe input. You take the antenna wire ether purchase a adaptor for it if it does not have Coaxe cable or just plug it in the back of the TV.
1. On that back of the TV you look for a plug in like this: rulds2008_14.jpg
2. You take the antenna end that should look like this: rulds2008_15.jpg
3. You plug it into the TV inlet pictured on step 1.
4. Take your remote and make sure you auto program your channel or auto search.
This is a basic instruction how to connect a antenna to your TV. You might need a converter if your antenna input is diffrent from what is pictured above.
Thanks for using Fixya.com, We do hope this information was Very Helpful
Jan 16, 2011 | Soyo Onyx DYLTO32D 32 in. LCD HDTV
I need help setting up my Sega Master System, I am unable to attatch it to the tv.
Hi, Sega master system 2 are connected to your TV via an RF cable. One end is RCA which connects to your console the other end is Pal which connects to you TV's antenna inlet if your using the sega RF switch then the RF switch connects to your antenna inlet on your TV and you should have a RCA to RCA cable which connects the console to the switch. Please note these cables and power adaptors can in some cases be faulty. These console are manually tune to VHF-1 frequency so make sure your TV has this frequency. some do tune to UHF but most tune to VHF-1 if you need parts or want your console modified to connect to a modern TV via AV inlets or S-video visit www.gameoz.com.au they stock a huge range.
Jan 30, 2010 | Sega Master System Console
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
