Question about The Computers & Internet
I used the mute button, now I cannot get any talking. Mute won't turn on still has the speaker with the X through it.
cnavarro
  • 2460 Answers
SOURCE: Mute - Turn On??
Welcome to Panasonic :-)
The mute button works when you have a speakerphone call. That means SP-PHONE pressed and press MUTE and it flashes to let you know it's on mute.
Maybe software version 9.0 will fix the mute to work on handset calls.....
Carl
Posted on Sep 04, 2008
SOURCE: How to mute my Uniden phone
You have to use the menu on the handset. Press Menu/Clear, then Mute, then push the Select button. Repeat the same to turn mute off.
Posted on Nov 12, 2008
  • 21 Answers
SOURCE: is there a mute feature
sometimes the mute button is with the menu button or it has it own button. I would look on the phone and see if there is mute above a button. If it is above a button than that is the mute button when the phone is on. To make sure, I would call a friend then put it on speaker, then hit that button to see if that is it.
Posted on Dec 22, 2008
  • 51 Answers
SOURCE: Cannot find mute button on ACER 6930
Look at the keyboard there should be a FN key and then a mute button on top of one of the keys
Posted on Jan 19, 2009
  • 909 Answers
SOURCE: Razr in mute mode
the only mute function is to mute/unmute a call during the active call.
It is the - key (center button at the top of the keypad)
Have you turned the volume too low?
If you turn the volume to low, it will stay low all the time until you reset it to a higher level.
You just press the volume keys on the side of the flip lid or set in the setup menu.
Posted on May 07, 2009
Unmute handset
Mute Microphone
With the handset
You can temporarily turn Off the microphone so that the person you are talking with cannot hear you.
1)Press menu/del during talk mode (while phone is in use).
2)Press ring/vol/? or ring/vol/? to move the pointer to Mute and then select/
Mute On and appear in the display. To cancel muting, repeat above step again when Mute
is set to on, Mute Off appears.
With the base
While using the base speakerphone, press mute on the base to turn Off the microphone.
Press mute again or press (speaker) to cancel muting.
Jan 01, 2015 | Uniden Lands Phones
How do you un-mute tv settings
Try pressing the mute (speaker symbol with diagnol line) or just press up/down volume button
Sep 08, 2014 | Televison & Video
Onkyo mute channels. When turned on, one or more channels remain mute. Acts like a contact problem; when switched on-off-on multiple times, mute channels may vary
follow this steps and fix it. God bless you
The speakers are not connected properly. Check the speaker connections. The Mute function is activated. Turn off the Mute function. The volume is turned all the way down. Turn up the volume. Neither set of speakers is selected (if unit has A/B buttons to select sets of speakers). Press either A or B to select a set of speakers. Both sets of speakers are selected, but only one set is connected (if unit has A/B buttons to select sets of speakers). Press the appropriate button to deselect the speaker outputs which are not connected. The receiver is set to TAPE MONITOR (if applicable). Turn off TAPE MONITOR mode. Headphones are plugged into the main unit. Unplug the headphones. The source selector is set to the wrong source. Select the proper source. The impedance of the speakers is less than the rating for the system. Use speakers with the correct impedance rating.
Oct 11, 2013 | Onkyo TX-SR500 Receiver
We lost sound on our Sansui TVD2798 even though the speakers work. Mute button has no effect. Using the remote, we can't find any option for sound off or on.
There usually is an option for turning off the internal speakers as part of the TV setup routine...BUT you may have had a failure of the internal audio in your TV. Your Zenith remote might have a MUTE button which turns off TV sound and displays a mute message or the MUTE buttton might have been pressed accidentally and has become stuck
Jan 08, 2013 | Sansui Televison & Video
Volume on G E model 21028GE3-4
To adjust the speaker volume, press up/down on the base unit.
To change the ringer volume:
Make sure your phone is OFF (not in talk mode).
Press the MUTE/PROG button to go to the main menu.
Press CID/VOL (up or down) button to scroll to "HANDSET SETUP".
Press MUTE/PROG button to confirm.
Press CID/VOL (up or down) button to scroll to "RINGER VOLUME".
Press MUTE/PROG button to enter the menu. "SET RINGER 1HI 2LOW 3OFF" shows in the display.
Use the touch tone pad on the handset to select 1, 2 or 3, or use the CID/VOL (up or down) button to scroll to your selection. HI is the default setting.
Press the MUTE/PROG button to save your selection. You will hear a confirmation tone and the new volume setting shows in the display.
To change the receiver volume: When the handset is ON (in talk mode) you may adjust the receiver volume by pressing the CID/VOL (up or down) button.
If you need a manual, you can download one here.
Oct 06, 2011 | GE 21028GE3 Cordless Phone
How do i turn off the sound
You can use the function button in your keyboard + Mute sound button in the top keyboard rows to mute and unmute the sounds.
(fn key + Mute symbol key)
I hope this is helpful to you.
Thanks
Apr 26, 2010 | Dell Inspiron 2200 Notebook
Radio speakers seem to be muted. I pushed INFO button, did this cause something to mute ??
Some radios have phone buttons that mute the speakers so you can talk on the phone. If you have Onstar and no active subscription it can also mute the radio thinking you are trying to talk to Onstar.
Apr 24, 2009 | 2004 Chevrolet TrailBlazer
My insignia 37 inch tv
Press menu and use the up or down arrows to find the audio section adjustments. Press the right arrow and again use the up and down arrows to find tv speakers, Press the right arrow to either turn on tv speaker or turn them off ( This is used only if you are using the output signal from you tv in to you stereo input to have surround sound.) Turn them on to listen to sound from the television speakers only. If this does not solve your problem, Press the mute button on you remote control to release the mute function. If all this does not work the telephone number for Insignia is 1-877-467-4289. Talk to them about you problem and see if your television needs some type of service to restore the sound. Hope This helps you with your problem.
Mar 19, 2009 | Insignia 37" LCD Flat-Panel HDTV
Is there a mute feature? Using the speaker phone w/mute?
Dec 22, 2008 | Toshiba DKT3020SD Corded Phone
Mute button
stuck on mute no callers hear me talking
Jul 19, 2008 | Apple iPhone Smartphone
Computers & Internet Logo
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
