Question about The Audio Players & Recorders
Panel will not work
Nothing changes or lights up only the clock but cann't adjust
How do I set panel clock time in hyundai accent 2006? The buttons doesn't seems to work. I press them, but nothing...
You have to take it apart to fix it. Bad contacts in the clock. They can be cleaned up to work, but not for long. Replace it . No fuse for the time set buttons.
Dec 01, 2014 | 2006 Hyundai Accent 1.5
How can I replace the left front fog light unit from a toyota prius from 2009. I cann't find a maintenance manual for this model and year.
Its all attached by clips and screws.Nothing much special.But its all about the procedure.Dont forget the mark the position , location of the screws you remove, so while refitting you don't face any problemTo replace fog light bulb or to replace replace complete fog light unit, click this link below:--- http://technoanswers.blogspot.com/2011/07/how-to-replace-left-front-fog-light.html ---------- This will help.Thanks.Helpmech.
Jul 09, 2011 | Toyota Prius Cars & Trucks
Sony radio/cd/clock under the cabinet. Lost
On the right side there is a push button switch labeled "Clock". It is springloaded so you have to push it in and hold it for a couple of seconds until the unit beeps and the hour position starts to blink. The volumn up and down buttons will control the changing of the numbers up and down and PM/AM. Pushing the clock button again will change the clock to the minutes position and you cann adjust the numbers up or down just like the hours. Push it one more time will lock-in the new time. Your done.
Jul 20, 2009 | Sony UNDER-CABINET LCD-TV DVD/CD CLOCK...
Oven does not work
Open the control panel to expose the clock/oven control.
With a volt meter verify incoming voltage to the clock control.
Check all wires for good contact.
If it still does not work replace the clock.
Remember to unplug the range to check the wires for good contact.
Mar 04, 2009 | GE Spectra JBP78 Electric Kitchen Range
1997 Mercedes C230 clock light and odometer light not working.
You will need to pull out the instrument cluster and replace the bad bulb.
Feb 14, 2009 | 1997 Mercedes-Benz C-Class
Changing the clock time
If you mean simply adjusting the 12 hour LED to the time of day...Push the area on the glass control panel printed "clock". Enter time of day by using same "buttons" you use to adjust oven temps, as in 1-2-0-5, which would be 12:05. then push clock once more. If you meant changing from 12 hour time to 24 hour time, that is complicated, takes two people, and is on page 30 of your owner's manual.
Jan 23, 2009 | Thermador SC302T Electric Double Oven
Will not restart or respond to reset clocks or lights wont work nothing works what should we do
Don't do nothing at all??
If nothing works or no lights come on, try to change the outlet if not working replace the fuse of the MW
May 11, 2008 | Microwave Ovens
How do you set the clock on the panasonic cq-c1121u cd radio.
1 Turn the ignition switch until
the accessory indicator
lights.
2 Press [SRC] (PWR: Power).
3 Press [DISP] (CLOCK).
4 Hold down [DISP] (CLOCK) for more than
2 seconds.
5 Adjust the hour.
[[]: sets the hour ahead.
[]]: sets the hour back.
6 Press [DISP] (CLOCK).
7 Adjust the minute.
[[]: sets the minute ahead.
[]]: sets the minute back.
8 Press [DISP] (CLOCK).
Notes:
¡ "AdJ" is displayed before adjusting the clock.
¡ Hold down []] or [[] to change numbers rapidly.
power off displayPower Off
Press [DISP] (Display) to change the display.
Mar 10, 2008 | Audio Players & Recorders
After changing a blown oven light, the clock works but nothing else turns on, including the fan, light, microwave
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, linked here on Fixya:
http://tinyurl.com/yzjozk
Nov 27, 2007 | Whirlpool MH7135XE Microwave Oven
21 people viewed this question
Top The Audio Players & Recorders Experts
ctlimey
Level 1 Expert
D. E. Hev
AliennoisE
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
