Fisher RS280 will power up but no sound - Washing Machines
Fisher & paykel gw612 washer constantly trying to drain
The pump triacc in the motor control board needs to be replaced
by a technician, it's cheaper than getting a new board.
Apr 22, 2013 | Fisher and Paykel Fisher & Paykel Washer
I have a fisher Paykel IW709AU wahing machine, it does not drain the water after the washing cycle ends, but a buzzing sound starts from the water pump for about 30 seconds and the power cuts out. the...
If you wired the pump directly with a lead and 230V supply and it works ok, then doesn't work when powered by the control board, I would say that there is a problem with the control board not supplying a full 230V to the pump.
Dec 04, 2017 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher Price Step & Play Piano lights up but no sound.
I assume
No sound when baby steps on the keys (with high volume setting)
You have used alkaline batteries
You have tried replacing your betteries
Tried sliding the power and volume switch off and then back on
If you answer yes for all above then it is time to call Fisher price and ask for replacements.
May 01, 2011 | Fisher Price Step and Play Piano
We've been hearing a ticking sound coming from the basket area of our Fisher & Paykel washing machine for several days. The sound does not change whether the machine is on or off. It is harder to hear...
It does sound as if there maybe something in the filter, although you say it occurs even when switched off. If you switch off at the power point does it still occur?
Jan 02, 2018 | Fisher and Paykel WL26CW2 Top Load Washer
My fisher plow wont move
Sounds like pump is not working, check all fuild lines. Unless the plow is all electric, then the ground
Feb 26, 2010 | 1998 Chevrolet C1500
Fisher & Paykel ED56 Dryer alarm on. Nothing else works
Replaced electric control panel. Looks like power spike fried the works
Feb 27, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Fisher and Paykel (NZ) tumbler dryer
Try switching off the power to the machine for 5-15 mins and then re-switch power on
Had same symptoms with my multi-temp F&P front load dryer.
Andy
Nov 30, 2007 | Fisher and Paykel DEGX1 Electric Dryer
Fisher Paykel Washer Machine
sounds like the main board has died check for water leaks near board or motor/pump.
Nov 29, 2007 | Fisher and Paykel GWL11 Top Load Washer
Open Questions:
Samsung Washer WT1101cw will not drain. Originally had a OE error. Running "Spin" or "Rinse Spin" cycles but pump cycles on for less than 1 second and goes into spin with water in it. _Laundry loaded with a OE error and water not draining. _I manually drained the system, took apart the drain and did not find a clog or anything to prevent the motor from turning. _Pump motor reads continuity. _Ran multiple SPIN cycles and then a RINSE and SPIN cycle and actually had the pump run for a few seconds and even for a minute or so one time but could not repeat and hasn't since. _checked the Pressure Switch and see continuity between common and outside contact. Tried to increase pressure by blowing into the tube using a straw on the end of tube but saw no change. Not sure how the pressure is created inside the bowl. _There was no overfill condition originally and I have not tried to run a normal cycle because the washer is in an upstairs location and draining is difficult and messy. ___I believe that something is preventing the voltage from being sent to the pump motor but I have am not sure what logic conditions need to be satisfied for this to happen.I keep looking at the pressure switch because the drum will perform a load sense and then go into a spin cycle with water in it which sloshes around. Questions: --Shouldn't the drain pump normally be running prior to the spin? --what causes the change in the pressure switch? Does the switch only change at a "full" level? Please only answer if you have a clear understanding of the system. I am trying to avoid excessive expense in this repair and swapping parts unnecessarily. I am beginning to think that it is the control board and do not want to spend hundreds of dollars if it is not. Thanks.
Apr 23, 2018 | Samsung Washing Machines
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
