What is the square footage of 1 ton of austin natural flagstone
5 Suggested Answers
  • 308 Answers
SOURCE: Carrier, model 50RMC024EPC3030; serial number---how many tons??
This is a 2 ton unit (24,000 BTU/HR) 50RMC024EPC3030 The proper way to size a cooling system is actually by the Heat Loss Method, but as a rough estamite generly 500-1000 sqaure feet per ton. Hope this helps
Posted on Mar 19, 2010
heatman101
  • 43501 Answers
SOURCE: i have a 4 ton
Depending on the indoor temps. you could add a bit more freon...
I would just add till the line gets cold at the condenser and then quit...
heatman101
Posted on Aug 09, 2010
  • 8064 Answers
SOURCE: what are the keystrokes to get e squared?
You can use the value of e you know and square it, or you can use the exponential function as follows
[SHIFT][e^x] 2 [=]
Your solution is
x=(e^2 -1)/2= 3.19452804946 =3.19
Posted on Aug 23, 2010
  • 639 Answers
SOURCE: can someone tell me what the square footage is in a board 2 inches thick 8 inches wide and 8 foot long please
The total surface area (assuming nominal measures - a 2" x 4" is actually 1.5" x 3.5") would be:
Front and Back - 8" x 8' x 2
Top and Bottom - 8' x 2" x 2
Right and Left Ends - 8" x 2" x 2
I assume the coverage of the stair is in square feet, so let's convert everything to feet so we get our answer in square feet.
Front and Back - 8/12' x 8' x 2
Top and Bottom - 8' x 2/12' x 2
Right and Left Ends - 8/12' x 2/12' x 2
Let me know if you need any more assistance.
Good luck,
Paul
Posted on Jul 10, 2016
How many tons do I need to cool a bldg 20,000 sq. ft.
Determining the total tonnage to cool any building depends on the heat loss calculations. Points to include is the R rating of the insulation, the square footage of the windows and doors, How hot does it get in the summer? Also the materials the building is made of. ie. Steel. concrete, wood exterior walls.
Jan 26, 2015 | Heating & Cooling
Why does it take 8 hours to cool our home?
you have a 4 ton unit what square footage is your house.
Jul 09, 2013 | Goodman PHKJ048-1 Air Conditioner
Air is blowing cold but wont keep up temp
If the system is actually doing everything it can, which I do occasionally run into, then it's time to start looking at other factors like the heat loads. Number one problem I run into is either attic insulation or attic ventilation. One thing that really sticks out in your post though is the square footage and tonnage. Now, to be honest, what the square footage is from the home owner to actual living space always varies. Home owners always get the square footage like a realtor, but includes the garage and other unconditioned rooms. What your looking for is the square footage of only the rooms that have a vent. It is 400cfm per ton, 1 cfm per square foot. So if you have a 2.5 ton system, it is capable of doing 1000 square feet of living space. You said 1500 square feet, which would need a 3.5 to 4 ton system. Hope this helps and gets you to cooler days!
Jul 01, 2012 | Ruud UBHC Air Conditioner
We have a central air unit that is serial number BTR736B100A0 and model number 314127T18. I need to know the size of the unit. What square footage of house is this for?
This is a 3 ton unit. I go tthat from the 36 in your serial number. 36 means 36,000 btu's which equals 3 tons which cools a home 1,500 square feet to 1,700. If this help please rate me and do a testimonial.
May 23, 2011 | GE Heating & Cooling
I have a York A/C. Is it undersized? I have a 2-story home with many windows built in 2005. The square footage is 3302. Model # H2RC042506B Serial # WHNMO43927
Looks like a 3-1/2 ton system or 42,000 Btu's. Rule of thumb is to design a cooling system that can keep up with 15 Btu's per square foot without too much Southern exposure. Not knowing the exact size and location of your windows it is hard to tell if unit is undersized. If south of Conneticut, I would have put in a 4 ton system.
Jan 08, 2011 | Carrier 38CKC042 Air Conditioner
Phone nunber for manufacture of product
Here is some of their contact info:
GHP Group, Inc. 8280 N. Austin Avenue
Morton Grove, IL 60053-3207 Phone:
Fax:
Toll-free: 1-847-324-5900
1-847-583-0890
1-877-447-4768
Email: customerservice@ghpgroupinc.com GHP Group, Inc. 8280 N. Austin Avenue
Fax:
1-847-583-0890
1-877-447-4768
Fax:
1-847-583-0890
1-877-447-4768
Fax:
1-847-583-0890
1-877-447-4768
Email: customerservice@ghpgroupinc.comjohn224_0.jpg
Or an actual link:
http://www.ghpgroupinc.com/
John
Dec 15, 2010 | Dyna Glo "" Natural Gas Heater Mn200tba
SHow much tonage does my house 7 rooms needs?
The basic standard to figure out how many tons of air is needed is to get the square footage of every room that has a ceiling or floor boot. You need at least 1 cfm per square foot. So for example, if you have a 2000 square foot house, you need at least 2000 cfm which is converted into 5 tons of air. You convert cfm into tons with every 400 cfm/square foot being 1 ton of air. This is only residential of course and all ceiling heights at around 8 to 10 ft. Some other factors fall into play, but thats the basics. Hope this helps.
Jun 26, 2010 | Heating & Cooling
Mar 19, 2010 | Heating & Cooling
Brand New Central Air Not Maintaining set temp.
really need a load calculatin and see if you have enough return air vents general rule is 5to600 square feet per ton and the same amount of return vents as supply vents
Jun 05, 2009 | Drifter Poolmaster Detroit Pistons Luxary ...
Heating & Cooling Logo
19 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
