Question about Goldstar Dehumidifiers
GHD30 - how does i connect a hose to the bucket? i don't see a whole in the bucket which others have mentioned is there.
  • 115 Answers
You probably have a hose fitting above the bucket take bucket out and see if there is one where the water drains into bucket
Posted on Jul 25, 2009
Whirlpool AD50USS Dehumidifier WILL NOT DRAIN THROUGH HOSE
I have a similar model. There are two drains, one for the hose and one directly into the bucket. The hose one is supposed to be lower, but I had to put a 3/8 inch block under the right side of the unit to get the water to favor the hose instead of the bucket. Another possibility is that the far end of the hose is higher than the near end. If you can't lower it, you can put the whole dehumidifier up on blocks. One other thing to check is that the hose has a rubber washer in it where it connects to the unit. Use a tissue to see if this connection is dry. If it leaks, it will just drip into the bucket.
Jun 04, 2012 | Whirlpool AD50USS Dehumidifier
Model GHD30 will not run. Have power to the board. I can hear a click noise when turning the switch on. I electricially checked the compressor and fan both ok. PCB board?
Jim, you may also want to check the water bucket installation, too. If it is not properly installed, the unit will not turn ON. Also, check the float valve in the top of the bucket. It may be stuck in the UP position. In which case the unit will not start. Giggle the arm of the float valve to get it to return to the DOWN position.
Hope this helps you to further troubleshoot & solve the problem. Thanks for choosing FixYa.
Jul 27, 2011 | Goldstar DH504EL Dehumidifier
Cannot connection drainage hose because of blocking cap. Do I have to disassemble whole cabinet?
The cap should just screw off the hose connector. You may have to carefully drill a 1/4" hose in the center of the threaded hose connector, once the cap is unscrewed. Some models require that, others don't.
Jul 08, 2011 | Haier 45-Pint Dehumidifier
I don't know where the pipe connects to the dehumidifier, the threaded pipe which will bypass the collection bucket. I inherited the unit (sans manual) from my sailor son who used it in his boat.
Jeremy, you will either find it on the back of the unit. It will have a screw off plastic cap on the connection. OR when you remove the water bucket, you will see it inside that cavity, that the bucket is insert into. In both cases, it will look like a garden hose connection. The hose you attach, should not be longer than 5 feet. It relies entirely on gravity to drain.
Hope this helped you. Please let me know. Thanks.
Jun 12, 2011 | LG LHD659EBL Dehumidifier
I have an LHD6594EBL dehumidifier that won't run and it keeps saying the bucket is full but the bucket is empty, we have a hose attached and don't use the bucket,
Sue, if you haven't noticed any water draining from the hose recently, it may be that the hose connection and tubing of the unit are clogged and the drained water pressure is causing the unit to show "Bucket Full." Also, if the bucket is not properly in place, whether you use the drain hose or not, it will cause the unit to stop functioning. You know how to correct that, so I won't go into detail on that issue.
To unclog the drain, you will need an 18" long, plastic Zip Tie or something similar (NO wire coat hangers though) that will fit into the hose connection. TURN THE UNIT OFF AND UNPLUG IT. Then carefully insert the Zip Tie and continue to push it in until you reach the bend in the tubing. You will have to carefully work it past this bend, until it either bottoms out or you run out of usable Zip Tie. Now, while rotating it, slowly pull it out and be prepared for some water to follow.
Hope this helped you troubleshoot and solve the problem.
Jun 01, 2011 | LG LHD659EBL Dehumidifier
I have a lg lhd45elt8 dehumidifier i bought used i want to hook up the hose connection i see on the back a plastic chip that needs to be removed and the hose pipe is just inserted? then connect a drain...
I own this dehumidifier. To connect it to a garden hose for drainage you first need the special connector pipe/adapter that comes with the unit. It's white plastic and about a foot long, It may be stored in the top of the bucket drawer, where it ships from the factory. Your hose connects to the threaded fitting on one end. The other end is inserted into the hole in the back of the unit. You slide it straight in until it mates with a drain connection inside the unit. You can see this black pipe connection if you pull the bucket drawer all the way out and look in the very top right hand corner of the opening of the unit. Once the white tube is fully and correctly inserted you'll find two plastic tabs on the tube near the hose connection. The larger tab points straight up and blocks the tube from being inserted too far. The smaller tab points down and hooks into the slot in the bottom of the round opening to keep it from getting knocked loose. Your dehumidifier should now drain through the hose instead of into the bucket. Of course, be sure your hose is routed across a floor to a drain or sump pump located lower than the unit, since the water flows by gravity.
Apr 27, 2011 | LG LHD45EL Dehumidifier
Product Goldstar Dehumidifier GHD30: Machine runs when red button is depressed by hand. Return water bucket and machine stops. Set theromstat controller on max, and when button is depressed it works and...
Hi
You need to check that the bucket is clean and that the sensor for the water level in the bucket is clean.
An old toothbrush and some warm soapy water can sometimes achieve a great result.
Failing this you may need a new sensor, be careful and either draw or photo the old wiring route with your cell phone to make it easier to fit the new sensor
Hope this helps
Gordon
Apr 17, 2011 | Goldstar DH304 Dehumidifier
Won't come on
Definitely check the air filter, it has a sensor and will stop working if it's dirty. Easy to clean by running water through it.
Jun 09, 2010 | Goldstar DH304 Dehumidifier
I have a Goldstar GHD30 dehumidifier. I have not used it in awhile. I plugged it in to run it today and it does not turn on. I cleaned the screen and tried different outlets, nothing works. HELP!
Check the condensate collection bucket. If the bucket is not inserted correctly the dehumidifier might think the bucket is full and thus not turn on.
Aug 30, 2008 | Goldstar DH504EL Dehumidifier
When hose is attached, bucket fills up
yes: hose allowed the bucket to be bypassed yes: bucket was there only for the switch to power can you pass a finger through the hole where the hose connected? probably not, right? most of these buckets have a knockout area inside the hose connection. Try prying it out or even drilling it out if required. remember that once you remove hose, you must purchase a plug hose end connector to continue bucket only useage.
Sep 05, 2007 | Whirlpool AD70USR Dehumidifier
Dehumidifiers Logo
192 people viewed this question
Top Goldstar Dehumidifiers Experts
Gil Shultz
Michael Youngman
Michael Youngman
Jerry Greenberg
Jerry Greenberg
Are you a Goldstar Dehumidifier Expert? Answer questions, earn points and help others
