Question about The Health & Beauty
Victory 10 3-wh, very slow in reverse, every thing else works normally. How do i adjust the reverse speed?
    Loyalty:
    Visited the website for 30 consecutive days.
  • The Master
  • 923 Answers
Hi that's normal the 130xl is the same::: u need a plug in computer to adjust the speed .a pride dealer will have to do it cheers
Posted on May 19, 2017
Troy built storm 2890 snowblower slow in reverse
There is an inspection pan on bottom of snow blower remove the 2 or 4 bolts and drop pan
inside you will see an aluminum wheel (drive wheel) also a rubber faced wheel whitch runs on the aluminum wheel at a right angle (like a needle runs on a record on a record player.
Clean plate and rubber wheel using brake clean to degrease surface .
Also there is an adjustment to move the rubber wheel farther to the left for more reverse speed but in doing that you might lose top speed forward.
Mar 02, 2015 | Garden
2006 Victory Kingpin bucking at low speeds
VICTORY OF CAROL STREAM
26 Miles Away
  • 106 N Schmale Rd
  • Carol Stream, IL 60188
  • 630-690-3333
Jun 09, 2013 | Victory Motorcycles
Scooter slow in reverse
The drives on most scooters are programmed to be slow in reverse for safety reasons.
Jan 17, 2012 | Pride New Mobility Victory XL 4 Wheel...
My Pride Legend 3 wheel scooter will not go forward. It goes in reverse with no problem. Help
Hi, sounds like the speed pot that is attachment to the throttle lever is worn and needs replacing, this is normally a 5K pot,
Regards
GeWiz.
Feb 13, 2010 | Pride Mobility Victory 3 Wheel Electric...
I have a Pride Legnd..the scooter started loseing speed, I would adj the speed pot and the unit would stop, adjust back down and unit would run, but slow. I left the speed speed controller alone and unit...
hi, first you need to check the connections to the batteries then to the motor controller, and don't dismiss the speed pot, disconnect the speed pot and try a normal 5K pot inplace of it, if the scooters responds you find the problem just a case of getting the right speed pot. Check the freewheel switch, normally it located on the motor side.
Regards
GeWiz.
Dec 15, 2009 | Pride Mobility Victory 3 Wheel Electric...
I have a pride victory scooter and at low speeds it shutters and gets worse when it gets hot and worse in reverse..
that could be the speed pot , try moving the throttle lever upwards to see whether it stops shuttering, if not check the motor brushes.
Regards
GeWiz.
Oct 04, 2009 | Pride Mobility Victory 3 Wheel Electric...
Tickover when at normal temp,the bike runs fast can it be manually adjusted to slow it down? the exhaust sensors are working fine,it just the annoyance engaging first gear with a crunch! thanks tony
hi buddy is it carbered or injection also try a different oil this can cause due to wrong oil also adjust chain and clutch cable and get back to me
Sep 30, 2009 | 2005 Victory 8-Ball
Goes in reverse but not forward
hi, that sounds like the scooter
a. the speed pot is faulty (Wig wam) thumb throttle , check just in case there a reverse switch,
b. been taking apart and reassembled incorrectly.
Regards
GeWiz.
Jul 03, 2009 | Pride Mobility Victory 3 Wheel Electric...
Health & Beauty Logo
Top The Health & Beauty Experts
Motshidisimary
Motshidisimary
Level 1 Expert
Stacy Harrison
Stacy Harrison
Level 1 Expert
Dave Jacobs
Dave Jacobs
Level 1 Expert
Are you a The Health and Beauty Expert? Answer questions, earn points and help others
