Question about HP Boating
Help forum for outboard boat motors have a 1987 115 hp merc outboard the throttle cable will not move the throttle arm but when i take the cable off it works fine and i can move the arm by hand
    Top Expert:
  • HP Master
  • 45,597 Answers
Repace the throttle cable
with use the inner cable wears grooves in the outer case and when tension is applied as when moving the lever , the strands of the cable jam in those grooves
noticable when disconnected as the cable strands just ride clear of the grooves
Posted on May 18, 2017
    Top Expert:
  • HP Master
  • 76,848 Answers
Replace the control cable, they get rusted inside, have seen this many times.
Is there no reverse, goes forward but won't go in reverse
Outboard won't go into reverse ?? - General Discussion Forum ' In ...
www.in-depthoutdoors.com > ... > General Discussion Forum
Aug 9, 2006 - 8 posts - ‎7 authors
There's 2 cables that go into my outboard. ... It would have forward just fine but it would not shift into reverse. Assuming it's a wheel boat does the throttle handle go intoreverse but reverse doesnt work or does it not even ... Here are instructions to recover your old idofishing.com or idohunting.com account:.
Boat won't go in reverse - Lake-Link.com
www.lake-link.com/forums/boats-motors/.../Boat-wont-go-in-reverse
Sep 23, 2013 - 4 posts - ‎3 authors
Fishing Boards - Boats & Motors: Boat won't go in reverse. ... Forward seems to be working OK, but reverse just won't engage. ... I'm not sure if this is something at the throttle control end or something wrong at the motor. Any thoughts ... Looks like there'sa piece missing that's supposed to hold that in place.
Help! Will go in Reverse but not Forward gear! - The Hull Truth ...
www.thehulltruth.com/boating.../526873-help-will-go-reverse-but-not-f...
Jul 30, 2013 - 8 posts - ‎5 authors
Whether you're researching a new boat, or are a seasoned Captain, ... and it was notengaging fully into forward gear, but into reverse just fine. ... I'm a little dumbfounded as to why it will lock the prop when it's not running, but won't go into forward gear when it is ... While your there, change out the bellows. Mercury 125 won't go into reverse - The Hull Truth ...
Mar 17, 2014
Mercury 25 Horse Won't Shift into Reverse
Apr 5, 2009
90hp Yamha won't go in reverse & more - The Hull ...
Oct 4, 2007
Boat wont go forward or reverse - The Hull Truth ...
Jun 6, 2006
More results from www.thehulltruth.com
Dec 16, 2015 | Boating
What will make a johnsonew 50 hp out board motor bog when under load
Evinrude 50 HP Bogs at WOT - MarineEngine
www.marineengine.com > ... > Johnson Evinrude Outboard Archive
Aug 6, 2002 - 17 posts - ‎3 authors
83 50 HP Evinrude - sat out in weather for 4 yrs. Been cleaning ... At WOT, she bogsdown. Up to. ... Yes, this boat/motor is new to me. Actually ... Mercury 50 1987 bogs down when full @ full throttle
Sep 12, 2013
Motor Runs great bogs down under load.
Jun 23, 2011
1984 Johnson 70 idles but won't go
Jun 1, 2011
Johnson 70 hp no power under load Update
Oct 30, 2006
More results from www.marineengine.com
motor bogs down at full throttle Page: 1 - iboats Boating Forums ..
Dec 09, 2015 | Cars & Trucks
I have a 1978 merc 85 hp outboard with a bad pump i purchased a used one that works mine has 4 hoses
Mercury Outboard Fuel Pump - Mercury Outboard Forums
forums.iboats.com/Mercury-Outboards/Fuel-Pump
5, 2004 Mercury 225 four-stroke EFI no power to Low Pressure fuel pump. Why please help · Mercury & Mariner Outboards. 13, Mercury 850 (85hp) - Gas pumps through the top carb - Failed fuel pump? ... 1, 1969 7.5 H.P. Mercury (Bad fuel Pump)? ... 1971 · 1972 · 1973 · 1974 · 1975 · 1976 · 1977 · 1978 · 1979 · 1980 · 1981 ...
Fuel Pump Diaphragm replacement Mercury outboard 110 ...
? 4:18
https://www.youtube.com/watch?v=vufekxTVZd8
Jun 22, 2012 - Uploaded by Brad Clark
My last test run of this motor lead me to believe I had fuel pumpissues...so in ... Mercury 9.8 h.p. 110 Outboard Motor WaterPump Repair and ...
How to remove the lower unit on a Mercury outboard motor ...
Dec 01, 2015 | Boating
115hp mercury outboard
there sould be a rubber primer bulb in the fuel line . squeeze it several times till firm.
Jul 04, 2014 | Boating
Need a free service or repair manual for a 20 hp mercury outboard
what u need to know i am the 20/25 merc man 20 years on 20/25 mercks
Oct 25, 2011 | Light Outboard Motor Boat Bass Fishing...
1971 MERCURY OUTBOARD ENGINE REVS WHEN PUT IN REVERSE
is that on the remote control lever ? if yes then adjust the throttle cable to push against the throttle stop on the engine end so when you select gears it only moves when you go to accelerate ! mite need to adjust the carb pickup to align with mark on main lever that moves the timing rod to the trigger under the flywheel !
Sep 30, 2011 | Light Outboard Motor Boat Bass Fishing...
I'm looking for a diagram to help me reinstall a throttle cable into a tiller arm on a 1994 Johnson 9.9 outboard
You might be able to find what you need here: http://www.crowleymarine.com/brp_parts/2526.cfm
You can check into the catagories and they have diagrams of all of the parts in an exploded view.
Dec 18, 2009 | Light Outboard Motor Boat Bass Fishing...
Our 40 Merc Won't open all the way up under load.
A couple of possibilities are the spark advance and the fuel line. Carburetors can do it as well as a clogged screen on the fuel pump. So can a bad coil.
Look for electrical parts under the flywheel area of the motor. When you move the throttle there should be movement of the stator to advance the spark. Check for binding wires or disconnected linkage.
See if the spark is jumping strong to the plugs for coil strength or have it tested.
Check fuel pump screen and diaphram.
Before messing with carbs-disconnect cables for throttle on boat. Work by hand directly at motor. You may have cables restricting movement.
Thats about all I can think of. Let us know of outcome.
Aug 13, 2009 | Light Outboard Motor Boat Bass Fishing...
Boating Logo
27 people viewed this question
Top HP Boating Experts
Dennis Boxerman
Are you a HP Boating Expert? Answer questions, earn points and help others
