Question about Retail Supplies
SkyBox soda dispenser compressor runs and gets nice and hot but unit does not cool. If the compressor runs, does that mean the relay is working?
    Top Expert:
  • 77,932 Answers
Yes the relay is working.
Posted on May 18, 2017
Testimonial: "I babied it for 8 years and had to slightly turn the temp cooler over the last two years. Now it doesn't cool. I shut it off and left the door open a few days. It runs but doesn't cool. Might you suggest I tap it and add refrigerant?"
  • yadayada
    yadayada May 18, 2017
    How do you baby a machine like this?? Interesting statement.
  • John Sakschek
    John Sakschek May 18, 2017
    :) It is clean as a whistle with no dents or scratches. Has my Milwaukee Brewers logo on the front with two working neon bulbs lighting it up. I paid $70 to have an appliance repairman tell me to throw it away (of course it was 5:05pm and he gets off of work at 5). Do you think that I should add refrigerant?
SkyBox not cooling. I replaced the start capacitor and the relay switches. (It worked a couple years ago but not this time.) Condenser is almost too hot to touch. Is condenser out of coolant? (R134a).
It could either be very low on freon or it could mean that the compressor is out. You should check the compressor out before you put a lot of money into the freon.
Sep 10, 2011 | Maytag SkyBox MBV1976A Beverage Dispenser
Replacement compressor for maytag skybox soda dispenser M#MPV1976AAP
A replacement compressor was NEVER made availible for this product. Be sure the problem is not just the start relay and overload. Buy a SUPCO URCO41 from an appliance parts distributor ( for about $25.00. The installation instructions are on the package.
May 06, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Hi my skybox stop cooling
The SkyBox operates with two individual systems. The dispenser assembly, the LED indicators and the circulating fan operate on a low voltage circuit. The circulating fan runs anytime the SkyBox is plugged in.
The cooling system operates on 120vac. The cold control inside the beverage compartment is an on demand switch that sends 120vac to the compressor when cooling is needed. There are no parts available for the compressor, so if it determined that power is reaching the compressor, the windings are ok, a 3 in1 hard start kit (Supco URCO210) can be installed by a qualified service technician.
Mar 16, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag Skybox not cooling
sounds like compressor relay --- if the fan and compressor come on and then shut off after about 5-10 seconds -- its the relay --- sometimes you have to also replace the transformer and capacitor on the opposite side of the unit --- all items are accesible from the back of the unit
Jan 23, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag skybox start relay is bad
you need to change the overload relay ---- there is a company called
they sell the overload relay unit with all the parts for $26.00
email me back if you cant find it---- put in the model # for the skybox unit and you will see the item
item # 4387835
this is the problem -- if this relay goes bad the compressor will stay on and not supply cold air to the unit ----
Dec 16, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Check the compressor to see if it is running. Is it too hot to touch. If so make sure the condensor has proper air circulation to cool it. If the compressor is cool to touch and running. There is a leak in the refrigerant sealed system.The compressor isn`t doing any work because there isn`t any refrigerant in it, therefore will not creat much heat. A humming and clicking sound is typical of an overheated or damaged compressor. If the compressor isn`t running and connot start. It could be a bad start relay on the side of the compressor or a bad compressor. If you can remove the start relay, shake it and listen for a rattle sound. If it rattles, it is bad.If not. then it is time consider the cost of a repairman verses the value of the appliance. Check the cost of repair to the sealed system or maybe even replacing the compressor.I hope I have been of some help to you.
Nov 12, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Skybox by Maytag not cooling
our skybox just stopped cooling. i think the compressor kicks on but wont cool. can somebody please help me! thanks barbie
Jul 01, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag SkyBox
For the soda name tags, I pulled logos off the internet and printed them the correct size on 20-pound paper. Different paper gives different translucence, so you might have to experiment to get the right amount of light coming through.
PS: thanks for the part no. on the relay
Apr 21, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag skybox cooling
Is it cooling at all? Do you hear the compressor start or just a buzz for a few seconds? This sounds like a compressor or compressor start relay failure. Unplug the machine. Access the compressor and remove the relay that is plugged to the side of it. Shake it and see if it sounds like there are a lot of loose pieces in it. Inspect it for burned spots. If you find either one of these, it is bad. If it doesn't rattle or appear burned then the compressor is probably bad. Even if it seems ok, I would try a new one on it anyway. They aren't usually very expensive. If the relay is not the problem, check your owners manual for the warranty info. The compressor may still be covered by warranty even if the rest of the unit is out of warranty.
Oct 10, 2007 | Maytag SkyBox MBV1976A Beverage Dispenser
Retail Supplies Logo
35 people viewed this question
Top Retail Supplies Experts
Patrick Tinashe...
Are you a Retail Supply Expert? Answer questions, earn points and help others
