Question about Moen Plumbing
How do you tighten the handles on a Moen T394 bathroom faucet?
  • 374 Answers
SOURCE: Bathroom Faucet Handle Fell Off
There is a small allen screw in the base of the handle- the part the stem screws into to turn the water to the on position. If you have lost the one for your handle call moen at 1-800-289-6636 in the US. Their hours are Mon-Fri 8-8 EST and Sat 8-18:30 or follow this link MOEN. In Canada 1-800-465-6130 and hours are Mon-Fri 7:30-17:00 EST.
Posted on Mar 13, 2009
goofduck
  • 490 Answers
SOURCE: faucet handles fell off
there are supposed to be screws in the handle thru to the stem on the faucet that hold them on
Posted on Apr 21, 2009
  • 94 Answers
SOURCE: leaky moen 2 handle faucet
if memory serve's me,you will need to remove a stem extension,screw in center,and you may need a tool #103462 to remove cartridge.1'st stem ex't is red,(hot) blue (cold), remove, look down,white piece w/ 2 notch'es, this hold's cartridge down, ya might try needle nose plier's to remove,a little lube help's upon re assembly, carefull w/plastic thread's
Posted on Apr 26, 2010
  • 349 Answers
SOURCE: I have a loose handle on my Moen two hanlde
Take handle off and check out the inside to make sure it not striped out and on the top of the handle it may have a plastic cap to pop of to access the screw holding in in place you amy have to use a knive to get it off .
If you can't see a set screw it may have a screw in handle on top.
Posted on May 03, 2010
SOURCE: need step by step directions to replace cartridge
If this is a Moen 1225/1200 cartridge, try this link at the Moen site for instructions. You can even click on a link at the top of that site for a step-by-step Animation Enhanced turotial that is very helpful.
http://www.moen.com/consumer-support/installation-help/tutorial?id=moen0133
If it is a different cartridge, try searching that site for the specific number of your cartridge for instructions.
Posted on Oct 07, 2010
How do I tighten the hot water handle on a moen 4720 bathroom faucet?
many two handle faucets have either a cover button on top or on the side, top button types generally can be tightened with a screw driver while the side button style typically requires an allen wrench (hex key)
Oct 19, 2014 | Plumbing
HAVE MOEN MODEL INS792A WIDESPREAD 2 HANDLE BATHROOM FAUCET - LOOSE HANDLE ON LEFT SIDE - KEPT INSTRUCTIONS (PICS ONLY) - CAN'T FIGURE OUT HOW TO TIGHTEN LOOSE HANDLE - HELP??? THNX!
There is a cap on the top of the handle which can be removed by popping it out with a knife or a small flat tip screw driver. Inside you will see a screw which holds the handle to the faucet. Tighten this and replace handle cap.
Sep 01, 2010 | Moen & Villeta Two Handle Lavatory Faucet
My single pull up type faucet is stuck and I cannot turn it on?
http://www.moen.com/shared/pdf/4621pt.pdf This web site has a parts break down of the faucet.
This web site has more information for your faucet.
http://www.faucet-warehouse.com/Moen/chateau/bathroom-faucet/4621p
I hope this will be help full to you in how it is put together. If you have to take it appart to work on it.
Jun 06, 2010 | Moen 4621 Chateau 1 Handle Bathroom Faucet...
Handle is loose water flow weak
to tighten handle, you hold lever(top of handle) while unscrewing round piece below, entire assembly should come off.look down and should be screw down there, tighten it up. flow problem could be the areator, unscrew and clean if need'd. check supply tube's,shut off valve's, (if you have them)make sure they are wide open.
Mar 22, 2010 | Moen Bathroom Sink Faucet - 4-inch...
Ihave a two handle Moen bathroom faucet that the right handle came off showing a broken plastic part inside, how do I get the broken part out?
There is a little cap on the top of the handle, after removing in there is a philips screw under that and that will release the broken plastic part.
Mar 18, 2010 | Moen Kingsley Two Handle Bathroom Sink...
How do I get to the valve cartridge to replace it?
how to replace moen cartridge for two handle kitchen faucet ... cartridge for two handle kitchen faucet exporters,how to replace moen cartridge for two handle kitchen faucet suppliers,how to replace moen cartridge ...cn-faucet.com/ kp-how-to-replace-moen-cartridge-for-two-handle...
Mar 17, 2010 | Moen Bathroom Sink Faucet - 4-inch...
I have a Moen Monticello type T4572CP bathroom faucet that has a loose hot water handle.How do I correct problem.Thankyou
Pop off the plastic cover in the center of the handle to find a screw that you can tighten
Feb 26, 2010 | Plumbing
I have a Moen Monticello bathroom faucet. I am
Moving left to right: I am not an expert, but I have installed a fair number of faucets. Seems like a basic issue of just getting under the sink and tightening up. Make sure someone is topside to assure the faucet stays straight and does not move as you tighten up below. It is never easy to get a wrench and your hands in the proper position to tighten up the nut, but don't give up try a smaller Channel lock wrench if necessary.
Sink Stopper: http://www.lowes.com/lowes/lkn?action=howTo&p=Improve/PopUpStop.html
Jan 02, 2010 | Moen Bathroom Sink Faucet - 4-inch...
Loose handle
There should be a set screw that will tighten up handle.
Oct 02, 2009 | Moen Bathroom Sink Faucet - 4-inch...
Mar 11, 2009 | Moen Bathroom Sink Faucet - 4-inch...
Plumbing Logo
Top Moen Plumbing Experts
john h
Donni Steen
Don Numinen
Don Numinen
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
