Question about Plumbing
How do you tighten the handles on a omen T 394 bathroom faucet
  • 374 Answers
SOURCE: Bathroom Faucet Handle Fell Off
There is a small allen screw in the base of the handle- the part the stem screws into to turn the water to the on position. If you have lost the one for your handle call moen at 1-800-289-6636 in the US. Their hours are Mon-Fri 8-8 EST and Sat 8-18:30 or follow this link MOEN. In Canada 1-800-465-6130 and hours are Mon-Fri 7:30-17:00 EST.
Posted on Mar 13, 2009
  • 490 Answers
SOURCE: faucet handles fell off
there are supposed to be screws in the handle thru to the stem on the faucet that hold them on
Posted on Apr 21, 2009
  • 332 Answers
SOURCE: Can't tighten single handle moehn kitchen faucet
there is supposed to be a nut with a washer under the sink in the center, the metal plate is just for decoration, the nut and washer have to be installed before the sprayer is attached the stem that it connects to has threads on it for the nut your faucet should have came with a long socket made of plastic to install the nut
Posted on May 30, 2009
  • 349 Answers
SOURCE: I have a loose handle on my Moen two hanlde
Take handle off and check out the inside to make sure it not striped out and on the top of the handle it may have a plastic cap to pop of to access the screw holding in in place you amy have to use a knive to get it off .
If you can't see a set screw it may have a screw in handle on top.
Posted on May 03, 2010
SOURCE: need step by step directions to replace cartridge
If this is a Moen 1225/1200 cartridge, try this link at the Moen site for instructions. You can even click on a link at the top of that site for a step-by-step Animation Enhanced turotial that is very helpful.
If it is a different cartridge, try searching that site for the specific number of your cartridge for instructions.
Posted on Oct 07, 2010
Where is the grub screw that has to be removed as I can't find it?
plumbing - How do I remove a stuck faucet/tap cover ...
Apr 18, 2011 - Anybody can ask a question; Anybody can answer; The best ... There are total six faucets in a bathroom, two made into a bathroom basin ... The other possibility is that there's a small plastic "decorative" cap covering the screw.
How-To: Replace A Shower Faucet Cartridge ' Toolmonger
Dec 1, 2009 - In many modern shower faucets like Delta and Moen (which is what I have) .... About a year ago, one of the bathtub faucets in my other bathroom jammedopen. .... the exact faucet I have in my shower, so you answered my first question, ...I can tighten and loosen the screw but the handle just won't come off!
Problem Removing Handle Off Of Delta Monitor 1400 Series ...
May 20, 2009 - 15 posts - ‎12 authors
... from a Delta Monitor 1400 series tub/shower single handle faucet. ... sorry for the REALLY sxxxxx question. which way to turn (loosen) the set screw. ... only suggestions i have on the issue. when a setscrew will not back off i ...
Feb 03, 2016 | Home
How do I tighten the hot water handle on a moen 4720 bathroom faucet?
many two handle faucets have either a cover button on top or on the side, top button types generally can be tightened with a screw driver while the side button style typically requires an allen wrench (hex key)
Oct 19, 2014 | Plumbing
Hansgrohe bathroom faucet handle is loose. how do I tighten?
remove the cover in the center of the handle and you should see if it is a phillips screw driver or some other fastener type.
Oct 20, 2010 | Hansgrohe Plumbing
There is a cap on the top of the handle which can be removed by popping it out with a knife or a small flat tip screw driver. Inside you will see a screw which holds the handle to the faucet. Tighten this and replace handle cap.
Sep 01, 2010 | Moen & Villeta Two Handle Lavatory Faucet
Handle is loose water flow weak
to tighten handle, you hold lever(top of handle) while unscrewing round piece below, entire assembly should come off.look down and should be screw down there, tighten it up. flow problem could be the areator, unscrew and clean if need'd. check supply tube's,shut off valve's, (if you have them)make sure they are wide open.
Mar 22, 2010 | Moen Bathroom Sink Faucet - 4-inch...
I have a Moen Monticello type T4572CP bathroom faucet that has a loose hot water handle.How do I correct problem.Thankyou
Pop off the plastic cover in the center of the handle to find a screw that you can tighten
Feb 26, 2010 | Plumbing
Loose handle
There should be a set screw that will tighten up handle.
Oct 02, 2009 | Moen Bathroom Sink Faucet - 4-inch...
Delta faucet is loose ;moves right-left/wobbles. Tightening?
Try tightening the allen set screw behind the spout "you need a special (allen keys) to do this, and one should have came with your faucet". You can also buy or borrow an set of them.
Copy and paste this to your address bar for directions.
Jan 30, 2009 | Delta Victorian T2755-NNLHP Bathroom Roman...
Plumbing Logo
27 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
