Question about Vizio Televison & Video
I have a vizio TV and the right side of the TV is coming in dark. it looks like the right half comes in but dark. can anyone one help me to determine what part I need to fix it.
    Top Expert:
  • Vizio Master
  • 77,499 Answers
A new screen.
Posted on May 18, 2017
  • 1694 Answers
SOURCE: MITSUBISHI VS-4543
PVAT!!Look for bad connects--start w/easy first. Power supply,then vertical IC pins,then regulators.Take your time,be thorough.
Posted on Oct 01, 2007
  • 1779 Answers
SOURCE: VIZIO P42 plasma, half screen ok, other half showing blank
First you have to check if voltage and data are ok at the Y sustain board and the Y driver boards are not running hot. Even if you know how to replace these panels you must have a scope to adjust the v-set up and v- down. Not just a simple PNP. Trouble shooting a plasma is not a short time process to do it correctly. Please let a service center look at it for you.
Posted on Feb 18, 2009
SOURCE: Vizio LCD Green Pixels
Our Vizio started doing the same thing after only three weeks, except it was also showing green pixel when we watched DVDs.  After checking this site and others and trying all the "tweaking" advised, I finally called Vizio's customer support.  They were extremely polite and tried to help over the phone, but had to send someone to the house to make the repair (anything 40 inches or larger earns a house call). The tech arrived on time and was extremely professional and pleasant -- he had to replace the daughter board and LVDS cables.  So far, so good.
Posted on Jun 29, 2009
sams_trix
  • 93 Answers
SOURCE: Red 2 inch vertical line on right side of Vizio TV
That problem caused by a connection between LCD crystal and matrix driver,no tools yet to reconnect that metal to crystal connector,Claim warranty right away that will multiply or became larger.
Posted on Aug 30, 2009
  • 4 Answers
SOURCE: My 50" Vizio plasma tv has no power.
Mine did a similar thing (VP322), I would go to turn it back on after it having been off for a while, and it would turn on, then off, then on... Over time it would cycle on and off even longer... Eventually it stopped working, would not turn on and made a clicking sound.
Mine was past it's warrenty, so I opened it up and inspected the switchmode power supply board (where AC connects, and two voltage ribbon cables going to screen circuit and main circuit). On the side going to the main circuit board I noticed that five electrolytic capacitors were bulging at the top (a clear sign of overheating) and when this happens, their values (in farads) tends to drop, which can cause voltage instibilities.
The capacitor values were:
2 x 25V 1000 uF
2 x 10V 3300 uF
1 x 10V 1000 uF
I replaced them with spares and reassembled the unit, and it now works.
Hope that helps!
Posted on Sep 03, 2009
I have a 70in vizio smart tv & there is a dark spot in the bottom right corner. Tv is only a yr & half old. Please help!
Sounds like you may have accidentally.turned on the Pip. feature go in to settings and check the PIP setting and make sure it is off.
Aug 13, 2015 | Vizio Televison & Video
Vizio e322ar won't turn on
My Vizio E322AR White Vizio Light comes on when plugged in, then slowly fades to "Off". I unplugged and replugged - same. I held down the power botton on the side, and plugged in... same. Vizio light comes on (White) and over 5 seconds or so... fades out to nothing.
Remote doesn't do anything, buttons on the side don't do anything.
Going to pull the back off and look for bad Capacitors, and test fuzes for continuity. Wish me luck ... will report back later with results.
Feb 21, 2014 | Vizio E322ar
Vizio lcd flatpanel tv with dark background
If half screen is affected it will be either a board (LCD and Plasma have different names) but in those one board drives each side of the screen unit--worst case is the display panel itself which is fatal from a cost point of view.
May 25, 2012 | Vizio VT Televison & Video
I have a vizio 46 in lcd model # VW46L FHDTV10A and it started with the whole left side going dark and then it would get better after an hour or two. then about a week later the entire left side of the...
I would suspect the backlight inverter is faulty:
I would try to look on the power supply first for popped capacitors that supply the 24v rail for the backlight inverter.
Having sound is a positive when it comes to repair. This means that only your screen is not lighting.
If you repair the 24v line and check the 5v feed also going to the BN_on (on) the backlight inverter and you still have no picture...you will need a new inverter.
This could also be the CCFL bulbs that are aging and need replacement. Those are around $20 each for a bulb
Hope this helps! Please rate :)
Mar 14, 2011 | Vizio VW46LFHDTV10A 46 in. LCD TV
Vizio 42 lcd gets large dark spot. it will go away if you tap on side of set but comes back sooner ao later
HI...
It's probably a loose flex cable inside. Look on the web and find someone near you
Have a service tech check it inside for you
Apr 22, 2010 | Vizio VU42L 42 in. LCD TV
Right half of the screen mostly green and red with vertical strip
It sound like there is a problem with the mainboard. What is the model number of the TV?
Feb 05, 2009 | Vizio GV42L 42 in. LCD Television
Televison & Video Logo
29 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
