Question about Garden
Briggs 12.5hp vanguard stopped n smoke at rear.
Briggs 12.5 hp vanguard stopped n smoke at rear. found exposed wire. spliced n repaired. still no crank
  • 3 Answers
Its possible that the spark caused an in-line fuse to blow. Try following the wires from the battery to the ignition switch to the starter. There is probably at least one fuse in that path.
Posted on Jul 25, 2009
I have a 7.8 HP Briggs & Stratton Vanguard Engine that won't start and there is no spark.
check the coil and air gap
if visible ..check over the stop wire system
comes up horizontal cant see a set of points listed for this motor
Jun 17, 2016 | Briggs & Stratton Tools & Hardware -...
Vanguard briggs and stratton 14 hp engine blowing oil out of the air filter what can it be? did change the head gasket.
broken oil ring compression ring ok just broken oil ring letting oil pass to blow out intake should have light smoke to coming out
Sep 23, 2014 | Briggs & Stratton Garden
Will not start. but if I pour gas in carburetor it will. stop after the gas is burn of carburetor
Could be that the needle is stuck in carb, or else the fuel pump diaphragm is bad. Check the pump, thats what I would check first.
Jan 24, 2013 | Briggs & Stratton Briggs Stratton Vanguard...
Vanguard Briggs & Stratton won't shut down
Your kill wire from the switch to the coil is bad,disconnected or connections dirty...or switch is bad...try disconnecting the kill wire on the coil and using a jumper ground the coil directly to the engine or frame it should shut down if it does it is the wire or switch do the same at the switch if it shuts down it is the switch..if not the wire has a break..good luck..
Feb 04, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
27 horse power briggs on poulan pro. It smokes,
Very likely, the piston rings are badly worn or stuck. There may even be a small hole in a piston. In any case, you will need a major tear-down to repair this one. This is usually caused by lax oil-changes. It might be better to purchase a replacement engine than try to fix everything that could be wrong with the present unit if you take into account parts and labor. Hope this helps!
May 24, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
Engine smokes and looses power
Check the air filter, replace.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jun 26, 2009 | Briggs & Stratton Briggs Stratton Vanguard...
Garden Logo
85 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
