Witch light tell me the air conditioner is on
My CP06E10 airconditioner cools non stop without cycles .Goes on Cooling beyond set temp risking burn-out. Apparently thermostat stopped working. What can I do?\r\nThanks. abul It started a few days...
The thermostat is built into the touch pad,along with transistor board,the part replacement is almost as expensive as the whole ac unit,I dont know witch wire to tell you is the thermostat,wire,but it may be marked thermostat,if so,put,in line on that wire a manual thermostat for and older model ac,none of the new ones will have a manual thermostat.So ask for a manual thermostat control,I hope this helps.
Jul 11, 2011 | Friedrich CP06C10 Wall/Window Air...
Weather King 10aja1801
The answer is yes however you will want to change the indoor coil in the furnace also.
You would look for a 1.5 ton matched set.
Jul 19, 2010 | Weather King 10AJA1801AH Air Conditioner
Reset button on plug will not stay engaged
Ether the unit has a short in it,or the reset plug,is bad,you will need to have the unit checked out to make sure witch is the problem.
Jul 05, 2010 | Goldstar WG8000 Air Conditioner
I am losing head pressure and subcooling when the sun goes down....then the a-coil freezes up..
sounds like it's undercharged witch would mean you have a leak or possibly a dirty outside coil
Jun 15, 2010 | Carrier 38CKC042 Air Conditioner
Air conditioner is tripping after one hour
clean filter and Evap coil and condensing coil. also some units have a gfi breaker at the plug witch some times go bad
Apr 08, 2010 | Samsung AW1203B Air Conditioner
I dont have my celestial KFR-28GW\A remote control
Hi, the best way to tell without the manual, would to be to pick up a anolog thermometer, and insert it into the face of the a/c. This will tell you which setting will give you cooler air temperature. They are very inexpensive, and you can get them at most any hardware store or appliance parts store. This will be useful in your auto a/c, refrigerator and so forth. Best of Luck, and Happy Holidays,
Shastalaker7
Dec 17, 2009 | Heating & Cooling
Electric coil in a 7 year old unit continues to leak even after being replaced. appears to be a manufacturing problem. what is going on with the coils to cause them to leak?
most likely couse is the indoor fan stops working
the elements get to hot they should be a safty for each element some snap to open the circuit
or they have things that look like gray resters
that may be open but you can not tell witch an ohm meter to check if they are good
Sep 30, 2009 | Goodman CLQ36AR49 Air Conditioner
I have the same Ruud Achiever unit & it's not working.
It sounds like it will need a hot surface igniter. This is the part that glows when furnace is turned on, and tells gas valve to release gas for it to ignite. At that point funace is lit, it heats up flame sensor witch inturn tells fan to start.
Sep 30, 2009 | Ruud UBHC Air Conditioner
Fan will not start on it's own
The fan only has one capacitor. The other two are for the compressor, one is a start capacitor and the other a run capacitor. A schematic should be on your fan motor telling you witch two wires run to the start capacitor for the fan motor.
Jul 22, 2008 | Coleman Mach 15 Air Conditioner
Heating & Cooling Logo
16 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
