Question about Belkin N Wireless Modem-Router F5D8633au4A
Belkin N1 router doesn't want to work...
I purchased a Belkin N1 Wireless Router yesterday (F5D8231-4 version 4.011). I'm running 32 bit Windows Vista on a Toshiba Satellite, with a "Scientific Atlanta 2100" cable modem through Cox Cable.
When I plug my modem directly into my computer, I'm able to connect to the internet and everything works great.
When I plug my router into my modem, I get blinking blue lighs on the "router" and "modem" icons, and the "wired" icon blinks in a whitish color.
I try running the setup for the router on my computer, but the wizard tells me that the router is set up incorrectly.
The setup for the router is pretty routine and I've checked it about 25 times now, and I'm sure that it is all set up correctly.
I'm not sure why the router isn't working. It seems like it may be having trouble connecting to the modem. Anyone have any ideas as to what may be going on and how to fix it?
I've tried using the troubleshooting phone number, but they weren't able to help (although they did try for more then an hour).
Any help would be VERY appreciated. Thanks everyone.
YNSN Michael P. Traynor, USN
    Genius:
  • 1,269 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Configuring router for Cable Internet
To configure your router for Cable you will need to set your router's WAN (INTERNET) port to 'Dynamic IP' (DHCP) option. The router is set to this option by default.
Configuration steps:
Step 1 Connect the cable modem to the WAN (INTERNET) port of your router. If the modem has USB connection make sure that it is NOT connected to any computers via the USB cable and that the modem is switched to Ethernet (not USB). Only the modem's Ethernet port should be connected to the router's WAN (INTERNET) port.
Connect your computer(s) to the router's LAN port(s) or establish connection to it wirelessly.
Step 2 Open your Internet Explorer and log into your router by typing in its IP address (in most cases the default IP is http://192.168.2.1 ). Note that you do not have to be on the Internet in order to access this address because you are just connecting to your router's address. Specify username and password for your router, default is `admin' and password is password.
Step 3 After logging into the router select Setup. Set Internet Connection to 'Dynamic IP (DHCP)' option.
Step 4 Click on SAVE SETTINGS and then on REBOOT THE DEVICE to apply the new configuration.
If you are having difficulties accessing the Internet, you need to:
- Select the MAC Cloning option. Click on Clone MAC Address button. Do this from the computer which the cable modem was directly connected the last time. This will place the MAC address of your computer into the router. Save settings and reboot the router. Reboot your cable modem as well.
- Log into the router and go to Status page. Note what IP address it is getting on the WAN (INTERNET) interface. If the IP address you see under WAN (INTERNET) appears to be in the same range you are using on your network (e.g. 192.168.2.x), you will need to change the range you are using on your LAN to something different, e.g. 192.168.88.x. You can do this on your router under Setup > LAN Setup. Note that after changing the IP of your router you will only be able to access it through its new IP, e.g. 192.168.88.1.
- Uninstall your antivirus/firewall software (sometimes disabling or closing the software is not enough) and reboot your PC. After establishing the Internet connection through the router, reinstall your antivirus/firewall software.
Posted on Jul 25, 2009
I have a belkin f5d8636a.4 wireless router and need to connect it to a new computer running windows 7 using a belkin f5d8053uk usb stick. i need to know are both these items windows 7 compatable or do i...
The Router supports a variety of networking environments including Mac OS® 8.x, 9.x, X v10.x, Linux®, Windows® 98, Me, NT®, 2000, XP, and Vista®
usb stick OS Compatibility: Windows® 2000, Windows® XP 32 bit, Windows Vista® 32 bit
Nov 28, 2017 | Computers & Internet
I am trying to install F5D7051 Wireless G Plus USB Adapter on windows 7 but i have several problems .i tried to install the drivers from the cd that came with the package but i couldnt run the program.i...
You don't actually need a driver to set it up. Just plug it into your network, then browse to its URL (likely 192.168.1.1, but could be 192.168.0.1, or 192.168.2.1). Then just follow the prompts to configure it. Hope that helps.
Feb 20, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin n adaptor will not work with windows 7
Download the Drivers For Vista2_bing.gif 64 Bit From
www.belkin.com/support
Step 1 : Right Click on the exe File And select Properties
Step 2 : Click The Compatibility Tab
Step 3 : Select Run this Program in compatibity mode For Win Vista SP12_bing.gif
Step 4 : Click Apply
Step 5 : Now try to install it
Nov 08, 2009 | Belkin N1 Wireless USB 2.0 Network Adapter...
Belkin N1 Wireless Modem Router I cannot connect to Tiscali HELP
I had this with Bt Internet and this exact same router, you have to phone Belkin up and they give you a complete set of new settings that you manually have to put in during setup. If i remember rightly its a free phone number and the operator who answered spoke semi-english so not all bad, hope this helps.
Chris E
May 17, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Cannot connect to belkin N1 wireless router
It seems like your router is configured once without any issues. Ignore that error message if you are connected with the internet. The setup couldnt find the Network adapter or the router because it is know more a factory default settings. It is been configured already
Apr 03, 2009 | Belkin (F5D8231-4) Wireless Router...
Belkin N1 wireless network not working
It might be an idea to upgrade the firmware which can be downloaded from manufacturers' website
Mar 20, 2009 | Belkin N1 Vision Wireless Router
Belkin router is working with desk top computer. add laptop
It's asking for the security word that you entered into the router when you set up wireless security. You will need to enter both the wireless SSID, and the security key to make the system work.
Jan 24, 2009 | Belkin N1 Wireless-N Wireless Router
Connecting my router
windows vista is probably too new for the belkin wireless g router u bought. did u see if the logo on the box is compatible with the windows? 2nd if its a weak signal then you might have to buy a N1 router member it depends how much the signal can spread
Jun 23, 2008 | Belkin (F5D7230-4) Router (587009)
Belkin N1 Wireless not STAYING connected
change channels to 1-6-or 11. Make sure you change all of them.
Jan 07, 2008 | Belkin N1 Wireless USB 2.0 Network Adapter...
Can not identify Belkin N1 Wireless USB Adaptor on PC
Hi, A couple of things: 1. Have you tried all the USB ports of your desktop PC (front and back)? 2. What is your desktop PC brand/model or at least the motherboard? and What OS please?; 3. If running Windows in the desktop PC, can you please check in your Device Manager if your USB are 2.0? 4. Are you using a USB hub or directly connected to the PC's USB port? Hope this be of some idea/help. Pls post back with your desktop brand/model/motherboard. Good luck and kind regards.
Sep 16, 2007 | Belkin N1 Wireless USB 2.0 Network Adapter...
Belkin N Wireless Modem-Router F5D8633au4A Logo
885 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
