Question about Brother Computers & Internet
I had to use a Brother Wordprocessor for a form. I must have hit something and now it continuously beeps and nothing works.
Continuous beeping
You have a faulty key on the keyboard. Replace the keyboard, they are not expensive. Look at ebay for prices.
Feb 06, 2014 | Computers & Internet
How to make a brother typewriter/ wordprocessor 680 to type in Spanish?
Go to BROTHER.COM clicl on support you will find a manual there if your T/W has that feature it's there.
DickyO
Apr 13, 2012 | Brother EM-530 Typewriter
MANUEL BROTHER WORDPROCESSOR BEM-530
Go to BROTHER.COM click on support, poke around there and you will find a manual.
DickyO
Oct 10, 2011 | Brother EM-530 Typewriter
It won't let me install brother hl-2140 on windows xp, says the software has not passed windows logo testing
When you get that dialog box - Isnt there a button that says "Continue Anyway"? Or something like "Do you want to Continue anyway?"
If you get either of these options, then hit "yes, continue anyway"
Mar 30, 2011 | Brother HL 2140 Laser Printer
I have a 99 Chrysler Sebring. My brother changed my water pump and timing belt. Now it won't start. He tried to reset the timing, but he can't get the steering bracket off to check the top timer. The motor...
Your Chrysler has what is called an "Interference" engine. This means if the Timing is off the Valves will hit the pistons. That is the "sounds like something is hitting inside" noise.
You should NOT continue trying to start you car until the timing of the cam shaft and crankshaft is guaranteed correct. The valves and pistons may already be hurt, but if you get everything timed right you may get lucky. Really nothing to lose by timing it right and see what happens.
I am sad about this situation, especially when a brother is just trying to help out.
Wayne
Feb 09, 2011 | 1999 Chrysler Sebring
Sony vaio pcg k 15 notebook beeps on starup
If you hit some keys and then it starts - it indicates a stuck key on the keyboard. Check the keys to make sure they are all fully up and nothing has been spilled on them or gotten stuck under them. Keys can be removed usually by prying gently under the edge and replaced by pressing down firmly. Probably what is happening is the if a program opens and you see a series of 4's is that the "4" key is the one sticking partially and preventing boot up. The beeeep is simply to tell you something is wrong with hardware, ie: keyboard, mouse, memory will all generate a long beep or several short beeps. The owners manual will list beep codes to help you determine where to look to find the problem.
Apr 29, 2009 | Sony VAIO PCV-W600G PC Desktop
Replace Fuser error will not go away
With in 2 seconds you have to hit Menu,*,2,8,6,4
Continue even though you hear the 3 beeps.
When it does into maint mode press 88
That is parts counter reset
Scroll to the part and hit ok.
Press 99 to exit Maint mode
Dec 14, 2008 | Brother MFC-8870dw Wireless Multifunction...
Old brother word processor/electric typwriter WP-3550, any idea how to get it to type? is there a command? any place i could find a manual?
Hit the TW/WP key on the top row of the keyboard. TW/WP stands for typewriter/wordprocessor. This toggles between using the word processor manually (like a typewriter) and using the monitor to enter text and then automatically print it out (like a word processor on a computer). My guess is, you do not have the monitor that came with the word processor. I believe it will still work once you press the TW/WP button. Hope this helps.
Apr 16, 2008 | Computers & Internet
Computers & Internet Logo
27 people viewed this question
Top Brother Computers & Internet Experts
shaun
shaun
Are you a Brother Computer and Internet Expert? Answer questions, earn points and help others
