Question about Exercise & Fitness
Fitbit alta is not holding the charge It is fully charged then it says it has low battery
bmwrider
  • 215 Answers
SOURCE: Low battery indication
You have either a faulty charger, a faulty battery or a fault in your camera. I purchased 2 batteries for my Sony 505v and from new one of them kept flashing an empty battery sign right in the middle of the display. Actually it was fully charged but Sony batteries have a little circuit inside them which tell you how long the batteries will last. In my case I could continue to use the battery but put up with that flashing icon. I returned it to where I purchased it and it was replaced Immediately. Please ,next time give us a little more information as to what battery type it is and which camera it goes in. Some cameras can develop a natural short circuit over time. BMW
Posted on Jul 02, 2006
SOURCE: Sansa E250 Battery Low always when charged fully
throw the damn piece of ******* **** out the window
Posted on Apr 05, 2008
  • 36 Answers
SOURCE: BATTERY IS CHARGED, BUT SYSTEM DOES NOT RECOGNIZE BATTERY
this is a common problem. the battery itself is bad and needs to be replaced
Posted on Apr 30, 2009
SOURCE: Battery will not hold a charge
I had the same problem and then went to the website to find that you have to have the off/on switch in ON position. This solved it for me. Hope it's that easy for you too!!!
Posted on Aug 19, 2009
BillB-SA
  • 2761 Answers
SOURCE: low battery icon
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
Posted on Oct 31, 2009
What do the characters on the Alta represent?
Solved: symbols and their meaning - Fitbit Community
https://community.fitbit.com/t5/Charge-2/symbols-and-their-meaning/td.../1721698
Dec 29, 2016 - 20 posts
Solved: Hi Everyone, As I flip through my watch, I see some symbols that I do not know the meaning of... is there a photo of ... Ionic, One, Charge 2, Alta HR, and Aria 2 ' Windows 10 ' Android Moto G4 .... And what does active minutes mean? What do the symbols on the Fitbit mean?
Jul. 12, 2017
Alta HR faces
Mar. 18, 2017
no limit for text character
Jan. 19, 2017
Can't understand display icons
Apr. 27, 2016
More results from community.fitbit.com
Jun 01, 2018 | The Computers & Internet
How do I reset the time on my fitbit alta
Theoretically the Fitbit should keep the time updated though syncing, but there are some things that throw it off. I would try these steps in this order. Check after each step to see if you have the correct time before doing the next step.
1. Re-sync your Alta to your phone/computer
2. Check your settings on your dashboard to make sure you have the correct time zone selected.
3a. If you sync to a phone make sure you do not need to update the app then try disconnecting and reconnecting the Fitbit (in your Bluetooth settings).
3b. If you are syncing to a computer, then try re-syncing your Fitbit. you might need uninstall/reinstall your software and make sure you are running the most recent version.
4. Try removing the Alta in the Fitbit app (should be under device settings) and then reconnecting it.
Hopefully one of those steps will get you on the right time, but if not, try resetting your Alta by doing the following:
  1. Plug in your Alta in a USB (computer, or adapter) as you normally would to charge it. It should begin charging.
  2. Press the button on your charging cable three times within eight seconds, briefly pausing between presses. (The button is on the end of the charging cable).
  3. Eight seconds after the first button press, you'll see the Fitbit logo on the screen. This means Alta is restarting.
  4. After you see the logo you can unplug your tracker from the charging cable.
Oct 20, 2017 | Exercise & Fitness
How do I reset the time on my Alta fitbit?
Theoretically the Fitbit should keep the time updated though syncing. I would try these steps in this order.
1. Re-sync your Fitbit to your phone/computer
4. Try removing the device in the Fitbit app (should be under device settings) and then reconnecting it.
Hopefully one of those things will get you on the correct time :)
My Fitbit Alta is showing incorrect time. How can that be changed?
Oct 12, 2017 | Exercise & Fitness
New Fitbit blaze fully charged will not work when in watch screen only comes on when on charge
How to Charge Fitbit Blaze: Step-By-Step
  • Plug in the charging cable into the USB port of your computer.
  • Find the tracker from the wristband. To do so, impulse the screen slightly so that it removes from the frame.
  • Place the tracker inside the charging cradle with the screen in front of you and the four gold prongs associated.
  • Adjacent the cradle cover.
  • Watch for a large battery icon that acts momentarily on display to let you know that charging has in progress. It gives a hint of how low your battery is to start, and a small battery icon persists in the top left corner while charging so you can check progress. When the green battery icon is fulfilled, then your Fitbit Blaze is fully charged.
How to Charge Fitbit Blaze The Definitive Guide for you
Sep 20, 2017 | Exercise & Fitness
Can the screen cover on a A Fitbit HR Charge be replaced
It can!
(6-Pack) EZGuardZ Screen Protector for FitBit Charge HR (Ultra Clear ...
https://www.amazon.ca/6-Pack-EZGuardZ-Screen-Protector-FitBit/dp/B00SVW2DPO
  1. Cached
Pack of 6 Brand New EZGuardZ™ Screen Protectors; Precision Cut for your FitBit Charge HR, NO Cutting Necessary; No worrying about sticky residue; Thin, ...
Screen Protector And How To Get Scratches Out - Fitbit Community
https://community.fitbit.com/t5/Charge-HR/Screen-Protector-And-How.../835469
  1. Cached
Jun 21, 2015 - If you have a Fitbit Charge HR, I highly recommend getting a screen protector. The plastic screen is not strong at all, and it is also very easy to.
Best screen protector brand for Charge 2. - Fitbit Community
https://community.fitbit.com/t5/Charge-2/Best-screen-protector...Charge.../1543173
  1. Cached
Sep 2, 2016 - Wendy ' California. Retired Classic, Ultra, Charge,Charge HR. In use One, Charge 2, Surge, Blaze, Alta and Aria ' Windows 10 ' Android Moto ...
Amazon.com: XtremeGuard™ Screen Protector for FitBit Charge HR ...
https://www.amazon.com/XtremeGuardTM-Screen-Protector-FitBit-Charge/.../B00SV...
  1. Cached
Buy XtremeGuardTM Screen Protector for FitBit Charge HR (Ultra Clear): Screen Protectors - Amazon.com ? FREE DELIVERY possible on eligible purchases.
FitBit Charge & FitBit Charge HR Watch Front INVISIBLE Screen ...
https://www.amazon.com/INVISIBLE-Protector-included-Protection.../B00UMAXNJS
  1. Cached
Buy FitBit Charge & FitBit Charge HR Watch Front INVISIBLE Screen Protector (Front Shield included) Military Grade Protection Exclusive to ACE CASE: Screen ... screen cover on Fitbit HR Charge Google Search
Nov 16, 2016 | Exercise & Fitness
Can the screen be replaced on a fitbit charge hr
  1. Cached
  1. Cached
  1. Cached
  1. Cached
  1. Cached
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
