Question about The Computers & Internet
Where is the fuse for the PowerPoint located - The Computers & Internet
Location of cig lighter fuse in 2004 ranger 2.3
I don't think they call it a cigar lighter it is a powerpoint or auxiliary power outlet socket.
Jan 11, 2017 | 2004 Ford Ranger
Powerpoint 2003 corrupt problem
1. Go to the directory where the file is located.
2. Right click on the file
3. Select properties
4. The Type of File, should be PowerPoint Presentation
5. Opens File field should be PowerPoint.
If it doesn't have this, then select the change button & select PowerPoint from the list of applications.
6. Select Ok & then Apply and OK again
7. In case this guide wasn't effective for you, then make use of professional online recovery service for corrupted .ppt and .pptx files https://onlinefilerepair.com/en/powerpoint-repair-online.html PowerPoint repair online
Jul 27, 2015 | Microsoft PowerPoint 2003 for PC
PowerPoint Viewer error 32-bit
Try PowerPoint Repair Toolbox is powerful .PPT repair software, resolving any problem, causing the damage of PowerPoint files.
For more: https://www.pptrepairtoolbox.com/
Apr 09, 2015 | Microsoft Office Professional 2007 Full...
How do I recover a corrupt PowerPoint 2013 presentation?
You can try:
PowerPoint Repair Toolbox is powerful .PPT repair software, resolving any problem, causing the damage of PowerPoint files. This tool guarantees the compatibility with all available software configurations therefore PPT on repair of reinforced concrete structures works anywhere in the network.
For more information: https://www.pptrepairtoolbox.com/
Mar 02, 2015 | Microsoft Office Computers & Internet
Message in Powerpoint: Part of the file is missing. How to fix it?
your powerpoint file seems to be severely corrupted. You may try to open this file in PowerPoint Fix Toolbox http://www.powerpoint.fixtoolbox.com/
If if it useless follow the steps 1) Open a new presentation and use Insert --> Slides --> From existing presentation to pull in the slides from the corrupted file. This works about 50% of the time.
2) Try using the Clone Me add-in from Microsoft. It may work, it may not.
Or see more http://www.filerepairforum.com/forum/microsoft/microsoft-aa/powerpoint/679-could-you-help-me-with-recovering-ppt-file
Feb 06, 2015 | Microsoft PowerPoint 2007 for PC
Where can I get a diagram that shows Auxiliary Powerpoint fuse location?
Easy fix is to check all fuses and replace any bad ones.
Sep 19, 2014 | 2011 Toyota Camry
My sony bravia NSX-40GT1 is dead....no lights...nothing. (lightning strike) If I replace the P/S board will that get it up and running?
First things i would check are the powerpoint and then the fuses
a lightning strike at the powerpole may take out a fuse at the fuse box thus no power at the powerpoint,a power surge could take out the fuses on the powersupply board but check all fuses ,be sure to unplug the set from the wall first.
good luck.
Len
Sep 06, 2014 | Televison & Video
2010 ford fusion-how can i replace fuse for cigarette lighter
look under hood for fuses & should be Ft Aux fuse.
Dec 25, 2013 | Ford Fusion Cars & Trucks
Somebody connected my battery the wrong way my time does not turn on and neither does the radio and it just clicks
'PowerPoint Viewer 2003 lets you view full-featured presentations created in PowerPoint. This viewer also supports opening password-protected Microsoft PowerPoint presentations. You can view and print presentations, but you cannot edit them in the PowerPoint Viewer 2007.
http://www.softwarepatch.com/software/powerpointviewer.html
I hope this helps and good luck!
Please remember to vote 0abf13b.jpg and leave a testimonial. Thanks.
Nov 03, 2009 | 2004 Lexus GS
Unable to locate powerpoint on my pc
Powerpoint is a part of Microsoft Office, not a part of Windows XP. Maybe you will have to buy Office to get Powerpoint.
Oct 31, 2009 | Microsoft Windows XP Home Edition
Computers & Internet Logo
18 people viewed this question
Top The Computers & Internet Experts
Ed Watson
Level 1 Expert
Alex Krenvalk
Alex Krenvalk
mukhtar21 shaikh
mukhtar21 shaikh
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
