Question about Dishwashers
Have 4 yo Newair under counter ice machine. The ice machine runs through its normal cycle but there is no ice made only cold water is dumped into the ice bin.
Free standing machine with direct water supply
    Problem Solver:
  • 13 Answers
According to Newair, the ice maker may be leaking coolant, which requires a "qualified technician" to fix. Check to see if there are any oily substances leaking from the device. Also, the device may be in too warm of an environment (but if it has been working in the past where it is placed now and that environment's conditions haven't changed, I personally don't believe this is the issue). On another note, the water in the reservoir may be too warm, so try filling it with colder water.
http://www.newair.com/articles/how-a-portable-ice-maker-works/
Posted on May 18, 2017
New icemaker will work manually, water and cycle but will not fill after it dumps ice.
Try vacuuming the condenser coils of lint. The icemaker resets and harvests by a thermostat. If the freezer isn't cold enough it may not reset for a harvest. The icemaker could also be just bad.
Mar 12, 2015 | Refrigerators
My Ice maker doesn't make ice anymore
90% of ice maker problems are water related. Sounds like water may be continually seeping in from the inlet water valve (normal thing to do if the water level is low). This will not allow the water to get down to freezing temperature. You have to identify the reason that water is constantly running in. It's probably "leaking" out at the dump valve. Or does that unit have a float valve that may be leaking. Check your drain to see if water is leaking out during the freeze cycle.
Jul 07, 2014 | Hoshizaki Freezer Commercial Ice Machines...
Why does water not shut off after making ice
Is the bin drain line and dump drain line tied together. If so then it is melting ice from the bin. now when ice machine starts up it will dump the old water in sump tray so it will be fresh water during new freeze cycle.
Jun 25, 2013 | Scotsman CSW45 15" Ice Maker with 26 lb....
I have a whrilpool refrigerater the ice maker will not fill with water?
Bonjour,
Ice makers can clog. The water valve can stick open or closed or even not work at all. The water fill nozzle can clog with ice or food. If the unit has been moved the water line could be kinked or the water filter may be clogged. Maybe the water valve for the ice maker water line is turned off. Is there one under the sink? Inside most ice makers there is a thermostat that tells the ice maker that the water is frozen and it's time to dump the ice cubes. That starts a geared motor running to dump out the cubes. And in some cases a mold heater is turned on to help break the ice cubes loose. A lot of ice makers have a cam attached to the motor that turns with the shaft. When the ice cubes are gone the cam starts a timer to refill the ice maker with fresh water to make some more ice cubes. Most "fill" cycles of ice makers are "timed fill". The fill cycle has to start and stop to get fresh water into the ice maker. There may be another thermostat that monitors the air temperature where the ice maker is mounted. If that thermostat thinks the air is not cold enough to freeze water nothing happens. If all the steps don't happen at the right time no ice cubes are made.
Jul 11, 2012 | Refrigerators
2 problems one water escaping to the drain freeze cycle short
first, freeze cycle too short because you are loosing water. Water may be leaking thru the dump valve. Look at drain while machine is running and see of alot of water is draining. The dump valve spring may be week or there is trash in the dump valve preventing it from seating properly. drain water first before pulling dump valve apart.
Aug 29, 2011 | Hoshizaki Freezer Commercial Ice Machines...
My counter top ice maker is screaming loud and I am wondering which part is making all the noise. I am looking at the condensor cooling fan and it spins without binding. The motor that dumps the ice works...
the noise is came from your compressor due to long uses or operation the mechanical inside possible for wear and tear you need to replace compressor before you replaced try to observe its operation.
Mar 12, 2011 | NewAir AI100R Compact Portable Countertop...
Kenmore refrigerator model 2535466940A, stop making ice, stop dispensing water, replaced filer, held filter reset, still no water. Don't know if ice is making
ICEMAKERS OFTEN STOP DUE TO A WARMER THAN USUAL FREEZER TEMPERATURE. MEASURE THE TEMP AND IF IT IS UNDER 10 DEGREES F. IT SHOULD BE DUMPING ICE. (IT WOULD HAVE FASTER PRODUCTION IF SET TO O DEGREES.) IF IT HAS A "NO WATER" PROBLEM YOU WILL HEAR IT HUM FROM TIME TO TIME AS IT CYCLES BUT DOESN'T DUMP ICE. THE EASY WAY TO CHECK FOR A 'NO WATER' PROBLEM IS TO TIE A 10 INCH OR SO PIECE OF LIGHT TWINE ONTO THE SHAFT AND CHECK IN A FEW HOURS TO SEE IF THE SHAFT IS WINDING THE TWINE UP ONE TURN PER CYCLE. IF TEMP IS COLD ENOUGH AND IT IS CYCLING THEN THERE IS NO WATER GETTING TO THE ICEMAKER. POUR A CHARGE OF WATER IN THE TRAY/MOLD AND IT MAKES ICE AND DUMPS ONLY THE ONE LOAD IS ANOTHER WAY OF CHECKING. THE NEXT MOST LIKELY PROBLEMS MIGHT BE A WATER LINE FROZEN DUE TO A SUPER COLD FREEZER OR A BAD SOLENOID VALVE. I HAVE NOT SEEN IT BUT I WOULD CHECK THE WATER FILTER ALSO. IF THIS DOES NOT SOLVE THE PROBLEM-YOU NEED TO GET THE MODEL NO. AND SERIAL NO. OFF OF THE NAMEPLATE. I BELIEVE YOU HAVE TAKEN IT FROM THE BOOKLET AND YOU ARE SHORT SOME DIGITS.
HOPE THIS HELPOUT , GOOD LUCK IN SOLVING THE PROBLEM
Aug 02, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Not making ice. Please help
HOPE THIS HELPOUT AND GOOD LUCK......
Aug 02, 2010 | LG 26.0 Cu. Ft. Side-by-Side Refrigerator...
Whirlpool refriigerator ice maker not working
With ice makers it is almost always one of two things. The ice maker itself, or the water valve. Figuring out which one is easy, and I will help explain.
First thing is the frig has to be cold enough for the ice maker to even start working. I'm assuming we have the cold part taken care of. Next, the machine will start a cycle and ask for water. Here is where the valve comes in. The ice maker energizes the valve and it opens allowing water to rush up the back of the frig and into the ice maker. After the ice freezes the ice maker goes into harvest and dumps the ice.
In conclusion, you either have an ice maker that stalled at some point during that cycle (in which case you need a new ice maker). Or the water valve is not opening, thus no water enters the ice maker and you get zero ice.
If you have ice in the ice maker and it is not dumping, you need a new ice maker. If it is empty, you have to either wait for it to ask for water or manually advance the ice maker into cycle so you do not have to wait.
At this point you will hear the water valve energize or not. If it never energizes, the ice maker is not working right, if it energizes and you get squat, the valve needs to be replaced.
If you have experience with a multimeter you could detach the harness going to the ice maker and simply hook up your leads. When the ice maker asks for water, you should get 110v reading on the meter. If you do, the valve is bad and needs to be replaced.
If I can be of any further assistance please let me know. good luck!
Oh, and the valve probably sells for between $50 and $100 depending on where you buy it. The ice maker should run between $100 and $180.
May 29, 2010 | Whirlpool GS5SHAXN Side by Side...
Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine: my hoshizaki under the counter ice machine gradual...
Check condenser coil which is the coil on back with fins, sometimes with metal.mesh filter. If dirty or clogged up clean filter, blow out with air or brush and rinse out, careful not to bend fins. Sounds like issue to me. Unless the dump valve may be leaking by
May 18, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Dishwashers Logo
22 people viewed this question
Top Dishwashers Experts
