Question about Hobart Food Mixers
Hobart mixer A120 motor getting real hot - Hobart Food Mixers
    Top Expert:
  • Hobart Master
  • 77,529 Answers
Does the shaft the motor derives spin freely? Either the motor is being overloaded or the motor is failing.
Posted on May 18, 2017
Hobart A-200 mixer gets hot and weak. Motor housing gets too hot to keep your hand on it. Service tech told me the motors usually don't go out. What other problem could it be?
I'd say you're most likely overloading the mixer. This mixer, and others similar in size, are frequently overloaded by people making pizza dough. If you are making dough, keep in mind the A-200's capacity is 9 lb. of 40% A.R. pizza dough, mixed for 5 minutes maximum. If you need to mix longer, the batch must be cut down even smaller, but I don't even know if you're mixing dough.
Try running the mixer unloaded (i.e. nothing in the bowl) for ten minutes or more and see if it gets hot. If it still gets hot, the motor's start circuit (varies depending upon age of the A-200; Hobart used numerous motors in the A-200 over the years, incorporating different starting circuits) most likely has problems. If it doesn't get hot when operating unloaded, then you're probably overheating the mixer by overloading it.
Dec 20, 2010 | Hobart A200 Stand Mixer
I have a Hobart mixer and need the manual or some info on this specific one Model IS:A120 MLNO:25273 VOLTS:240
240v 12qt mixer... that's pretty unusual.
You'll have to register on this site, but you'll probably find what you're looking for here.
http://www.hobartservice.com/Manuals/
Dec 28, 2009 | Hobart Food Mixers
Mixer catching bottom of bowl model hobart a120
There are several possible causes:1. The blades of the beater/s may be distorted (bent) 2. The beaters are in the wrong way round 3. The bottom tray is not seated down properly - there may be something in the central hole 4. The bowl may be damaged
Sep 22, 2009 | Hobart A200 Stand Mixer
Hobart mixers A120 & A120T.. has an oil leak. Need Seal kit/repair parts info and type of oil to replace.
You need to take the old grease out and replace it with new and then replace the oil seal
by the way it is messsssssy
Jul 17, 2009 | Hobart A200 Stand Mixer
Hobart m-802 mixer won't start up
call Hobart for the correct oil any way and an elcetrican will just add more problems for yoy
May 30, 2009 | Hobart A200 Stand Mixer
Hobart A-200 mixer (OLD!) runs hot & shuts down.
You have killed it by overloading the bowl. Hobart recomends no more than 65% bowl capacity on doughs & 75% on batters or icings. Replace the motor or the whole unit
May 25, 2009 | Hobart A200 Stand Mixer
Hobart A120 mixer bogging down
Hi. If the motor does not turn, the problem is electrical. Trace and test the electrical circuitry with the mixer unplugged. Start with the electrical plug and work your way through to the motor and switch connections. An electric motor technician should be called in if you are not familiar with electrical troubleshooting techniques. Good luck!.
If this solution has assisted you, please rate it. ricardok45
Mar 23, 2009 | Hobart Food Mixers
Service parts list of hobart mixer a120
There is a website called onesharpstore.com that specializes in food processing appliance parts. I saw the hobart model 1812 listed there just today (03/07/09). They even have a number you can call direct. 772-770-4383.
Jan 20, 2009 | Hobart D300 Stand Mixer
Hobart A-200 First Gear is Having Trouble
If the mixers are older the dive key shaft,spring or key are broken,if they are newer the key is sheared.Also check the nuts near the beater shaft and make sure there not too tight.
Nov 13, 2008 | Hobart A200 Stand Mixer
Food Mixers Logo
50 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
