Question about Makita Saws
Makita MLT100 table saw when stop button is pressed the motor switches off saw seems to be running really roughly and the the blade takes an age to stop spinning. Normally blade stops really quickly.
    Novelist:
    Scholar:
  • 86 Answers
I can't find this saw at Makita; so, generally. Follow all safety precautions. :-)
If the saw is running rough, the first thing I'd check is the brushes for the motor, especially if it has any age. These are fairly inexpensive and will solve a lot of woes. The next thing would be to check the thumb switch, if it has one. This is the switch that allows you to pull the trigger to run the saw, if it's just a button, then check the actual trigger switch to make sure it's working properly as it probably, not always, also engages the brushes to reverse the motor for a second, to slow it down so it stops faster.
So, check the brushes on the motor, if they show any signs of wear, it's probably them. 2nd, check the switch. Please let me know and if I've helped, give me a vote up. Thanks.
Posted on Jul 04, 2017
3 Suggested Answers
  • 8 Answers
SOURCE: How do I change the blade on my Makita MLT100 tabl...
take the top cover off where yr blade is, make sure blade is in the highest position, take the 2 wrenches it came with and undo the nut.
Posted on Aug 18, 2010
peterm1610
  • 6 Answers
SOURCE: faulty table saw
I had a similar problem with one of my MLT100's.. I figured the usual suspects were to blame (fuse, or circuit breaker)..but they checked out fine.. The next thing to do was give the switch & wiring a good look over, as they'll usually blow a hole through the side.. All seemed well with both.. Eventually I woke up to the fact that the switch 'did' blow as expected, but hadn't bothered to give any outward indications.. So I'd suggest replacing the switch before looking for anything major..it's always the small simple stuff that gets us..
Posted on Apr 20, 2016
Craftsman model 137.415030 10 in portable table saw won't turn on. It is getting power the switch sounds like it is working ok but it won't turn on. The reset button ,does not appear to do anything.
My table saw motor just stopped.. What do I do? - The WoodenBoat ...
forum.woodenboat.com/showthread.php?...table-saw...I...
WoodenBoat
Apr 6, 2013 - 23 posts - ‎20 authors
Does the motor have an internal thermal cutoff switch? ... Auto reset on a table saw, now that would be scary. ... A Craftsman, I think. ... The saw is a Grizzly 1022Z contractor-style saw about 10 years old. .... After the motor cools down the switchneeds to be pressed to restart the motor, it won't start suddenly ...
My table saw stopped, the reset button won't reset. What ...
www.shopyourway.com > Manage My Life > Questions
It is a Craftsman Table Saw Model 137.248880. ... I pressed the reset button and the saw restarted. I continued ... My table saw stopped, the reset button won't reset. ... One was just the switch the other the rocker switch, identical except in cost.
Craftsman 10 table saw motor stalled - Yesterday's Tractors
www.yesterdaystractors.com > Discussion Forums > Tool Talk
Dec 25, 2015 | Craftsman 21802 10-inch 13-amp Portable...
Faulty table saw
I don't have table saw but my guess would be power shortage. Maybe try plugging it in different amp circuit and see if that makes difference.
Jun 04, 2013 | Makita MLT100 TABLE SAW FOR 220 VOLTS
Switch wiring
Did you manage to get in contact with the manufacturer of your saw? They would surely help you with your problem.
May 03, 2013 | Makita MLT100 TABLE SAW FOR 220 VOLTS
My 71/4 table saw is week can't cut blade stops
Sounds like the motor is wore out! Or maybe the belt if its belt driven
Jan 14, 2013 | Makita Saws
How do I lock the height adjustment on makita mlt100
You almost answered your own question.. As you've already discovered, the blade will slowly move as you're feeding stock to cut, so you can either locate the missing locking nut/screw, or buy a replacement from the nearest Toolshop.. Or dig out a 50-75mm machine bolt from your junk box & use this as a temporary replacement.. You'll have to check for the correct thread size 1st as they may differ from country, but I'm sure that'll solve the problem for now..
Aug 17, 2012 | Makita MLT100 TABLE SAW FOR 220 VOLTS
Wiring diagram for switch on makita mlt100 saw
ring Makita on 01908 210710 and ask for technical
May 30, 2012 | Makita Saws
How do I change the blade on my Makita MLT100 table saw?
May 19, 2010 | Garden
MAKITA #2703 table saw 10'' to rise and lower blade it
i would say the table is twisted then, strip it down first and if you need to "bend!" it back so it works
Mar 27, 2010 | Makita 2703 10" Table Saw, Electric Brake
I have an old Makita table saw and need to change the blade. It is a circular saw mounted under a table. I can't find the stop that allows me to unscrew the fixing nut on the blade. It is Makita Model...
This link will take you to Makita and display an owners manual where you will see that the saw should have came with the necessary wrenches to change the blade. If they are not available I have used two different methods. Take care with either, that blade is just waiting to getcha. 1. I have clamped a pair of vice grips directly on the blade and let them stop against the saw top to keep the blade from turning or 2. I have levered a peice of soft wood against the blade to keep it from turning. According to Makita the thread is righthand, so you can apply the righty tighty lefty loosey rule to determine which way to loosen the nut. Good luck I hope this helps.
Nov 22, 2009 | Dishwashers
Saws Logo
466 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
