Question about LG Televison & Video
Polaroid wireless speaker not pairing to LG stylo 2 phone..shows device and once selected it does nothing except red light on speaker blinks
Lost the manual????
SOURCE: lost owner manual
Press the Mic-Mute Button longer as 10 seconds!!!
Greets Jens
Posted on Apr 06, 2008
  • 10 Answers
SOURCE: Wireless headset pairing
With the Samsung WEP210 this is a common problem (which is actually just a user error)
This is what you do:
1. Of coarse make sure the headset is charged
2. Make sure the bluetooth headset if OFF
3. PRESS and HOLD the top/middle (on/off) button until the light stays on (it will blink then should stay on continuously). That means it is now in pairing mode.
4. Tell you phone to search for bluetooth devices.
5. It should find the headset, and by default type "0000" to pair your new headset**
**You can use whatever pin code you like......but I would recommend the default which is four zeros.
Posted on Dec 10, 2008
SOURCE: Trying to pair omnitech 2.0 bluetooth headset without manual
before attempting to pair your headset with another device, be sure that the bluetooth headset is in the off position
  • press and hold MFB until indicator light flashes blue and red. The headset will also beep twice
  • to pair your device to the bluetooth headset use the bluetooth pairing instructions from you device's instrucition manual.
  • input ID code 0000 when requested by the device
  • the headset and device are paired correctly when the blue and red indicator light flashes blue only.
Any questions email: Subject: omnitech bluetooth
Posted on Mar 09, 2009
  • 5 Answers
SOURCE: Need to re-pair bluetooth to phone
Go to ur phones bluetooth settings - activate pair new device - at the same time press and hold the on button on your blue tooth head set for about 10-15 seconds - this will enter the device into pair mode - on your phone - click on pair with new device etc etc, the default access code is either 0000 or 1234
Posted on Jun 29, 2009
  • 2359 Answers
SOURCE: Blackberry curve 8900, red light
The battery is drain.
DO NOT use the USB cable to charge your Blackberry.
When the PC/Laptop/Mac go to power saving/SLEEP mode it will cut off the charge to the Blackberry.
Use the official AC charger to charge the Blackberry.
Make sure the AC power is not switch off to the power pack at night.
The mini USB connector can be loosen over time.
Plug in the cable and check for connectivity.
Posted on Nov 01, 2009
I have a portable wireless speaker model AWSBT7 will not go into the connect mode when pressing the button to sync up device I do not get the two beeps or the light does not flash faster
Hi Jerry, Are you using this method to pair your device?
The Bluetooth-enabled device that you wish to stream audio to your speaker system must
fi rst be paired to the speaker. The process is simple, and in most cases the pairing process
needs to be done only once.
To pair your Bluetooth-enabled device with the speaker:
1. Make sure your device's Bluetooth is turned on. See the wireless and/or network settings
menu on your device to check.
2. If the speaker isn't already on, press the On-Off button to turn it on. You will hear a beep
to indicate the speaker is turned on. The indicator light on the back of the speaker starts
fl ashing blue.
3. Press and hold for 3 seconds the Pair button to enter pairing mode. You will hear 2 beeps
to indicate pairing mode is entered. The indicator on the back of the speaker starts blinking
4. Open the Bluetooth settings menu on your device. Select "AR SPEAKER" from the list of
devices available (you might have to scan for devices). If your device asks for a password,
enter "0000".
5. A confirmation screen will appear on your device once the speaker and the device are
successfully paired. The blue indicator turns solid blue to indicate successful connection.
The speaker is now ready for you to stream audio from your device.
Oct 24, 2014 | Audio Players & Recorders
I can't get my Polaroid Bluetooth wireless speaker to work!
hold the button down and it will change to blue, then you need to make sure your phone is connected to the speakers bluetooth. then when you play music off you phone it will come out the speaker. the red light is for aux mode - where you plug your phone or ipod in.
Jan 27, 2013 | Polaroid Radio Communications
My lg cu920 can't read my plantronic 220 what can i
Do you mean it "can" or can't connect to your CU920?
If your CU920 is already paired to a computer or other device this first pairing must be stopped before the steps below will work.
On the Bluetooth headset: 1. Turn your headset ON. 2. Hold down the headset power button until the power indicator light blinks an alternating red & blue.
Then using your CU920.... 3. Turn Bluetooth ON, 4. Search "New Device," 5. Under "devices found" select your headset. 6. Select "Add." The CU920 will ask for a passcode. 7. Enter "0000" (four zeros) the default for the Explorer 220.
The Plantronics earpiece should automatically "pair" with your CU920.
Oct 11, 2009 | Plantronics Explorer 220 Bluetooth Headset...
Headset not going into pairing mode.
Hold down round button on earbud for 5-6 seconds until the lights blink alternating red and blue.....then, enable your phone/device to connect in pairing mode. This will be a "find device" command or something similar. Once they recognize each will send you a screen to enter a code. This will be 0000.....enter that...and once they are good to go.
Aug 07, 2009 | Plantronics Explorer 220 Bluetooth Headset...
Cannot place LG-HBM-710 in discoverable mode
It sounds as if the device is not paired with your Chocolate. Press and hold the button on the face of the HBM-710 headset for approximately five seconds, or until the light comes on and stays on steadily, then discover the device with your handset's Bluetooth screen. Once it shows up in the list of devices, select in and pair it with your phone.
Jul 07, 2009 | LG HBM-710 Wireless Headset
I cant connect it to my lg shine i lost the manual
press left soft-key to go into menu, scroll down to menu number 9; bluetooth, check that bluetooth is switched on (1st submenu), 2nd submenu 'search for new device'. To add a new device, press the left soft key [New] 1. Select the [New] key to search the device that can be connected and which is within range. 2. If you want to stop searching, press the right soft key [Cancel]. At this moment you press and hold the big button on the headset (supposed it was off), until the little light stays blue fixed (not blinking !!! it will blink when it turns on but you hold the button pressed until the light stays on permanently !!). At this time the phone should give a message "device found" or even "H350 found" or it will say it didn't find anything and should it "scan again". if so select yes. 3. All of the devices found are displayed in the pop-up menu. Select the desired device by pressing the OK key, and entering the password 0000 (4 times zero). The permanent light on the headset should go off and blink once every couple of seconds. The phone and headset are now paired. when you switch the headset back on (after having it switched off) it will be automatically recognized.
Jun 13, 2009 | Motorola Mobility H350 Wireless Headset
I purchased a aliph jawbone 2 from for $69.95 and it won't pair up with my treo 755p. It's not my phone because I can pair up with my wifes Motorola headset. I even tried my coworkers...
Palm Treo 755p
To pair the Palm Treo 755p handset with the Jawbone, perform the steps listed below:
  1. Set the Jawbone to Pairing Mode.
    • For the Original Jawbone, press and hold down the Noise Shield button for at least three seconds until the LED Indicator Light flashes red.
    • For the New Jawbone, press and hold down both the NoiseAssassin™ Button and the Talk Button for at least three seconds until the LED Indicator Light flashes red and white alternately.
  2. Press Applications and select Bluetooth.
  3. Select Bluetooth On.
  4. Select Setup Devices.
  5. Select Trusted Devices.
  6. Select Add Device. (The Discovery icon appears, indicating that the discovery process is active.)
  7. Select the Show pick list and select Nearby devices.
  8. Select Jawbone from the Discovery Results list, and then select OK.
  9. Enter the PIN "0000" (be sure you are entering four zeroes and not the letter "O".) and select OK.
  10. Select Done, and then select Done again to return to the Bluetooth screen.
Your phone should now be paired with the Jawbone.
Feb 21, 2009 | Palm Treo 755p Smartphone
How do I connect my HBH-608 head set?
just turn on bluetooth in ur mobile and then turn on ur bluetooth headset by holding the power button for atleast 5 sec and if blinking green light show up it means that it is turned on,if it shows blinking red and green then it is ready to get paired with ur mobile phone so u can straight away connect the bluetooth by selecting handsfree and new device and in the list of divices select hbh608 and get it paired.if it shows a blinking green then hold the volume increase and decrease button at the same time for 5 sec and then the light turns blinking red and green and then u can go to handsfree and new device and select HBH608....its easy try doing workss....
Jan 03, 2009 | Sony Ericsson Sony-Ericsson HBH608...
Free Pulse
The following procedure will re-establish the communication link between the Headphones and the Wireless adapter, this is called "pairing". Before you start please make sure both the headphones and the wireless adapter are fully charged and turned off.
Note: The headphones and the wireless adapter come pre-paired from the factory.
1. Press and hold the power button on the headphones. See Figure 1.
Figure 1
2. Continue to hold the button down until the LED starts flashing red/blue in an alternating pattern. Release the button when the LED starts flashing red/blue. See Figure 2.
Figure 2
3. Once the headphones LED is flashing red/blue, press and hold the power button on the wireless adapter. See Figure 3.
Figure 3
4. Hold down the button until the LED starts flashing red/blue in an alternating patter. The LED will blink blue, then turn off for a few seconds then blink red/blue. Release the button when the LED starts flashing red/blue. See Figure 4.
Figure 4
5. Once both the headphones LED and the adapter LED is blinking red/blue, press the volume up button once on the headphones. See Figure 5.
Figure 5
Once the headphones is paired with the adapter, the LED on the headphones will blink blue once every two seconds. See Figure 6.
Figure 6
When the adapter is paired the LED will be solid blue. See Figure 7.
Figure 7
The adapter may continue to blink red/blue for a few seconds even after the headphones LED starting blinking blue. This is normal; the adapter may take a few additional seconds before the LED turn solid blue.
Once the headphones and the adapter are paired, it is not necessary to pair them again even if the batteries on both units are completely drained.
Additional Note: Repeated pairing will not improve the sound quality or give the headphones and the adapter a cleaner connection.
Mar 11, 2008 | Logitech FreePulse Wireless Consumer...
Bluetooth pairing
1.Explore blue tooth devices from your motorola phone. will sure find your blue tooth headset.
3. Make sure your blue tooth headset is on pairing function select your blue tooth headset
Dec 22, 2007 | Motorola Mobility Bluetooth Hands Free...
Televison & Video Logo
16 people viewed this question
Computer Repairing
Computer Repairing
