Question about Fast Garden
Where can I find the idle adjusting screw on my T25vw petrol as it's running fast
    Top Expert:
  • Fast Master
  • 77,932 Answers
On the carburetor throttle linkage.
Posted on May 18, 2017
Idle adjustment. idles too fast and will not shift
The idle adjustment screw on the carburetor usually has a spring on the shaft. Turn it counterclockwise to lower the idle speed. It probably won't shift because the gears are turning too fast...assuming that it's an automatic.
May 07, 2016 | ATVs
It idles fast if I turn the idle down it stalls running rich on top end at fast idle sometimes it will drop to a very low idle and shut off
adjust the idle mixture screws first and then adjust the idle speed screw to compensate
adjusting the idle mixture screws will alter the idle speed but when properly adjusted then adjust the idle speed screw,
Aug 24, 2015 | Motorcycles
How do i stop the engine running at a fast idle
Assuming it is a completely mechanical system with no electrical or electronic control there is no actual fast idle facility unless it is provided by a Waxstat cable device fitted into the cooling system.
I think what you mean is the engine idle speed is too fast rather than it is running at "fast idle" which is a term used for a raised idle speed when an engine is cold and decreases as the engine warms until at normal operating temperature the idle speed should be normal. On an old diesel engine it is the Waxstat device if fitted that provides this facility or a hand operated throttle. Very old cars and trucks had hand throttles for fast idle but later this function was provided by the choke or strangler mechanism. Some luxury cars had an electrical device fitted but the fast idle of modern engines is invariably provided by electronics.
I expect you need to adjust the throttle stop screw of the injection pump. This is at the lever where the throttle linkage connects to the pump and there is generally two stop screws fitted that limit the travel of the lever. One screw limits the maximum travel of the lever and therefore the maximum engine speed and this is generally set during manufacture or remanufacture and sealed to prevent tampering.
The other screw is the idle screw which the lever is pulled against by a spring when at rest.
Before adjustment it is necessary to ensure the throttle linkage is not maladjusted and preventing the lever contacting the stop. Disconnecting the linkage until the idle speed has been adjusted will ensure this and then slacken the stop screw locknut, start the engine and turn the screw in or out as applicable until the desired idle speed is achieved, allow the engine to warm up and make further adjustment if necessary and tighten the locknut and reconnect the throttle linkage. Do not adjust any pump screw except the idle screw.
What are the air and gas settings for a poulan micro XXV chain saw
adjust the L screw in fully till right in,then out 1.5 turns,same with H screw.Then start saw,adjust L screw in or out slowly till you get max revs.You may need to lower idle via idle screw if revs too high.When screw cant acheive better revs,reset idle.Then,rev saw to max revs,adjusting H screw to get max revs,then when max revs acheived,turn screw anti clockwise 1/4 turn out.That gives it enough petrol to cool the tip of the plug
Aug 12, 2014 | Garden
I have a 1986 GMC 1500 with a 5.0 and stock rochester carb. The truck will start but you must keep gassing it as it won't idle. It kicks off every time. Any suggestions on how to fix this cold natured
fast idle speed screw, works off the fast idle cam which the choke adjustment sets, it works together by linkages. This is the raised idle speed setting you need to keep a cold engine running. First you set the idle speed by the idle speed screw with engine at normal operating temperature. Then you set the linkage up so the cam is on a raised step, throttle will be held on that raised step. then you can turn the idle speed screw to get idle at about 1500-1800 rpm. Now when you start engine cold, choke will set the fast idle cam on that raised step- when engine starts and runs it should be running at your fast idle setting. That's how it supposed to work, you just have to get everything adjusted right. I hate carburetors, they never stay adjusted right. Considering their complexity and small mechanical parts, no wonder.
Dec 24, 2013 | 1986 GMC C1500
What is carburetor setting on a2.3 chainsaw
There is no fixed carburetor setting on these engines, just two screws to adjust low-end and high-end operation. Special tool may be required, there are about a half-dozen screw head standards. Check eBay for tool. Get the engine to run and idle fast (idle adjust) so it doesn't stall, adjust low-end screw so that engine doesn't hesitate or sputter when accelerated. Adjust high-end screw to run fast and smooth on full throtle. Readjust idle to normal.
Oct 28, 2013 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
I need a diagram of the location of the idle screw/adjuster for a Toyota Hiace 1997 2.4 petrol automatic engine. The idle speed has been set way too high eg I can reverse quite fast out of my level...
its probably not the idle screw being the problem, if you can smell fuel perhaps there is a carb or manifold gasket gone which will cause high revs and cut out
Apr 28, 2011 |
What kind of carb does the 76 c10 4x4 come with need to adjust
mcdevito75 here, The fast idle is needed when the engine is cold to make the air and fuel mixture rich to keep the engine running while cold, the carb. choke doew this with a bi-metalic spring in that balck round box on the side of the carb, a screw also hepls keep the choke closed until warm up, this screw can be adjusted tpo control how tight it holds the choke cloesed, here"s how to adjust this screw to slow fast idle speed, Locate on the carb, where the gas pedal connects, have a friend operate the gas pedal with the engine off, once you locate the linkage, you"ll also see 2 screws with springs around them, 1 is for fast idle the other for regular idle, you want the fast idle screw, notice this screw will lay against and Half moon shaped tab, while the other screw lays against a shaft, you need the screw that lays against the half moon shaped tab. Start the engine and step on the gas pedal slightly and relaease, at the screw that lays against this half moon, simply turn it counter clockwise or toward you just 1 2 or 3 turns very slowly, you'll hear the fast idle come down but you don"t want the fast idle to low, listen to the engine very carefully, slow it down just a bit, it should still race though but not out of control. Of course for a full carb, adjustment the shop should handle that., but this info will help.
Mar 29, 2010 | 1978 Chevrolet C1500
1984 toyota corolla 1.6 engine. How do i adjust
Carbureted models have a fast idle cam on the throttle,It is a screw that sets against a movable part,called the cam,when the engine heats up,the cam will drop upon tapping the gas pedal.Set the carb,while the engine is cold,by tapping the gas pedal,then adjust the fast idle cam screw by turning it in,with the engine running.Start out by turning the screw in a full turn before starting engine so it will run,then adjust the screw as the engine runs.
Nov 26, 2009 | 1984 Toyota Corolla
Carburator settings
If you have played with them the only way is to get it going pretty well is" ....
find the idle screw - usually larger - and turn in 1/2 a turn - hopefully that will keep it running - then find the 'slow' running screw turn it in until it stops then turn out 1 and 1/2 turns. Leave the fast one alone.
Get it started then adjust idle screw so its faaster if need be.,, now slowly turn the 'slow' screw in then out say 1/2 turn and listen for it either speeding up or slowing down leave it at the point where it sounds ok and try giveing a few 1/2 speed rev ups. If it goes back and idles as before - leave it.
The fast screw... (first make sure your exhaust outlet is totally unblocked - the slightest restriction here will cause it to never run right at high speed). Start it up and then try full throttle - same thing as before try adjust the fast screw first in a little then out until it runs well at what seems the faster speed it can - then check that it accelerates well from idle to full speed. If not adjust it a little more until it does.
Once it will idle ok and return to idle and also run full speed, then you can back off the idle screw until it will idle without the chain racing arond the bar.
Bear in mind th chain wil be racing around while you adjust it so keep fingers kids and idiots well away..because you are adjusting it with that chain moving..
Nov 07, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Garden Logo
21 people viewed this question
Top Fast Garden Experts
john h
Are you a Fast Garden Expert? Answer questions, earn points and help others
