Question about Janome Sewing Machines
I have a janome MB4 and was having an issue with the first needle showing a thread breakage error.
After taking the machine apart and cleaning out the bobbin casing, it is no longer showing the error but it skipping huge chunks of stitches.
SOURCE: Bernina 1130 not catching bobbin thread
there will be a adjustment in that you should select the stiching mode and in that give the straight mode the problem will be solved
Posted on Jun 05, 2008
SOURCE: Janome Memory Craft 9500 Troubleshooting
The solution that I found last night was the thread tension. I have never touched the dial, only had it set on 'auto." When I started playing with it, I realized the top thread should be really easy to pull through the machine and it wasn't. I started turning the dial (to 3 or 4) and the thread slid through the machine perfectly. No more birds nest! I really thought it was bobbin initially because of the horrible sound it was making.
SewExpress
  • 41 Answers
SOURCE: Picking up the bobbin thread
A few suggestions:
  1. Rethread top of machine from scratch with the presser foot raised, i.e. remove thread completely from all thread guides & paths and start from scratch, making sure thread is securely seated between tension disks. Once the needle is re-threaded, lower the presser foot and give the tail end of the thread a tug to make sure there's tension on it.
  2. Make sure the bobbin is turning the correct direction for your machine - and that the thread tail is under the tension plate or bobbin tension guide (depending on machine).
  3. Blow out any fuzz.
  4. Insert a new needle, making sure needle is pushed all the way up.
  5. Oil machine (in locations recommended in your owner's manual).
If the basic cleaning and re-threading (above) don't help, your machine(s) may be out of time or have another mechanical issue that will require a repair technician. We recommend a tech trained on your specific brands - they'll be better trained and able to get any repair parts that may be needed.
Hope this helps narrow down your stitching problems.
Happy sewing,
Kim & Linnette
Posted on Jun 27, 2008
  • 5 Answers
SOURCE: Bobbin problems
Are you using a size "A" (Class 15) bobbin? If you are using pre-wounds and they are not this size... they will jump around alot. The size of an "L" is very similar, but they are not as tall (height off the table when laying flat on the round side... like when sitting in the bobbin case.) There are tricks to using the thinner bobbins... See if you have a "taller" size "A"/Class 15 and if that corrects the trouble. tjsews2008@gmail.com
Posted on Mar 02, 2009
SOURCE: janome straight stitch loose
I don't know if this is the right answer for any of you, but thought I'd put my 2 cents worth in. Often this can be the bobbin in backwards. It needs to unwind a certain way depending on the machine. I've heard a phrase for this: Mind your p's and q's which means some wind off to the right like a q, others to the left like a p. Mine has to unwind one way then be slipped backwards into a little slot or it does that loose bottom thread looping and bunching someone here mentioned. It seems everytime I get that problem I rethread the top thread 100 times before it clicks again and I remember it could be the bobbin thread. Either your manual will tell you the correct way, or you could experiment and try one or the other. Once you figure out whether you're a p or a q, mark it on your machien somewhere to remind yourself.
Good Luck and Happy Sewing!
Posted on Apr 04, 2009
My mb4 is stitching designs off centered and when i started the machine it hit the hoop and broke the needle. i replaced the needle but now the thread keeps breaking?
Remove the thread and rethread. Usually, thread breakage occurs when the thread is not following the thread path. However, there could be other reasons:
Sewing Machine Problem 1 Thread Breakage
Nov 14, 2016 | Sewing Machines
I have a Janome 1600P and the top thread keeos breaking
There are several common reasons for upper thread breakage.
Check that the needle/thread/fabric are compatible.
All About Needles
Remove the upper thread from the machine, install a brand new needle, ALWAYS RAISE the presser foot, and rethread from the beginning. Verify the thread path is correct. Set the upper tension to the midway point.
NMSU Checklist of Common Machine Troubles
Sewing Machine Thread Keeps Breaking
Why Does My Thread Keep Breaking While Sew
Oct 29, 2016 | Janome Sewing Machines
3rd needle sews for 5 sec then shows needle breakage but no actual thread breakage. If you restart machine it repeats same process, how can I solve problem?
Hmm, I'm wondering if maybe the thread on that needle is hanging up on something or the tension is too tight. Sewing for a few seconds and then breaking sounds like the thread is tightening and then breaking the needle.
The BEST recommendation I've ever read is, if the machine is not serging properly, the thread breaks, or pulls out of the needle: Remove ALL the thread, RAISE the presser foot, and rethread every thread from the beginning. Make sure you are threading in the proper order (it will most likely never work if the step-by-step threading process is not followed!). When threading, grasp each thread below the thread tree and with the other hand grasp it below the tension disk and give it a little tug to make sure it is seated in the tension disk.
Set all the tension dials to the midway area between the high & low numbers and retest.
Changing that needle to a heavier needle may also help although some sergers recommend not using a needle larger than a size 90/14.
HINT: Be sure you are frequently oiling your serger. Because they sew much faster and create a lot of lint, it is important to keep them lubricated, ie once every garment. And be sure to use oil recommended by the manufacturer.
Jan 10, 2016 | Janome MB4 Four Needle Embroidery Machine
Why does my Janome mb4 keeps shredding its top thread?
Change your needle and if it continues to happen, change the thread. Most likely your needle and thread are not compatible, ie the thread is too large for the needle's eye. Also, inexpensive thread will shred.
Sep 05, 2015 | Janome MB4 Four Needle Embroidery Machine
Janome mb4
I suggest you call a Janome dealer and ask them your question.
Sep 02, 2014 | Janome MB4 Four Needle Embroidery Machine
Janome mb4
are you using a good thread and the same thread on the top and in the bobbin, different threads will sometimes act up. I also can not sew one brand of thread on my machine, try Mettler or gutermann's you can get them at JoAnn's or Fabricland. hope it helps good luck K
Sep 23, 2017 | Janome MB4 Four Needle Embroidery Machine
Janome MB4 wont sew breaks threads really bad?
1--thread breaks really easy if it is a couple of months old
may be new to you but in the shop for a long time
2---thread breaks easy if the incorrect needle eye size is used for the thread thicjness
3-- thread breaks easy in the needle tension is incorrect
4-- thread breaks easy if the needle is threaded from the wrong side ( look for a small groove down the back of the needle and thread from that side so the thread sits in that groove )
5-- thread breaks easy if the needle /hook timing is a bit out as the hook pierces the thread instead of picking it up cleanly from the recessed section at the eye
find another repair shop because if the dealer couldn't fix it under warranty, they sure cannot fix it when out of warranty and for money
Aug 06, 2017 | Janome MB4 Four Needle Embroidery Machine
Why does my Janome MB4 Jump in mid pattern and finishe 1" up or down?
This is usually caused by the y axis movement system. Occasionally this system can come out of sync, and cause the issue you described. Your y axis pulse motor may be going bad as well. In either case it would be best to take your machine to a Janome dealer for repair.
May 04, 2014 | Janome MB4 Four Needle Embroidery Machine
Janometroubleshooting
checks that the strip wire and strip wire sensor, this worked well.
(the strip threads is the small spring by which you spend the thread to thread)
Jan 04, 2014 | Janome MB4 Four Needle Embroidery Machine
Sewing Machines Logo
57 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
