Question about Teac RW-D200 / RW-D250 Dual-Deck CD Player and CD-R/CD-RW Recorder CD Player
Recording I can't find my manual and I have forgotten how to record by programing the songs I want with my remote control. I remember it is really easy, but I can't remember the steps. The remote control unit is RC-781. Can you help me?
Re: recording
How do i use the finalize button to finalize a cd after recording?
Posted on Feb 23, 2008
0 characters
3 Points
I have a Phillips CDR 775 2 -disc cd recorder and my track time is automatically set to 20 seconds. How do I increase this time per track? Also, I cannot seem to get the auto track to work when...
It's all in the manual...
20 seconds is the amount of digital 'silence' the machine will let pass during recording before it marks a new track. t will Pause and wait one minute for a digital signal to resume. (Page 21)
On digital copying it will automatically increment track numbers as the source advances.
For analog sources you should switch Auto Track to OFF and manually press Track as applicable. (Page 28)
Jan 21, 2011 | Philips CDR775 2-Disc CD Recorder
When recording canyou programme manually without
You can find the manual on Just register and download it.
The Program key on the front panel will alow you to proram tracks to be recorded from the CD player to the CD recorder.
Mar 16, 2010 | Marantz DR-4050 2-Disc CD Recorder
Yes, but you, like I could use an owners manual for this thing, as it isn't as easy to operate as the Philips Audio CD recorders. Owner's manual anyone?
You can just press input select for analog, press record, wait then press 'play' to start recording.
Aug 04, 2009 | Koss CDR200 2-Disc CD Recorder
Im trying to records mix cd but isnt changing
• To switch off the Auto Track function you have to enter
Menu mode.
If you wish to increase track numbers manually, press
TRACK INCR(ement) on the remote control. For further
instructions see Menu mode.
ON (AUTO): The track increments are automatically taken over
from the digital source material or after 2.7
seconds silence during analog recording.
OFF (MANUAL): While recording track numbers can be
incremented manually by pressing TRACK
(Minimum track length is 4 sec.) (This can
also be done in Auto track ON mode.)
May 01, 2009 | Philips CDR770 CD Recorder
When I record a vinyl album on a CD it all winds up on one track.
Pause each song for every recording to separate the tracks.
Feb 23, 2009 | Denon CDR-W1500 2-Disc CD Recorder
Tray B of my RCA CD Burner does not recognize any CDs
Are you using the correct disc type??
The manual states that only discs that are labeled:
"Compact Digital Audio Disc Recordable" (Audio CDR)
"Compact Digital Audio Disc Rewritable" (Audio CD-RW) can be used.
The popular discs labeled "Compact Recordable" and Compact Disc "Rewritable" are for use in computers, and can NOT be used on the recorder.
Page 16 of the manual shows the graphic of the logos detailed above. The manual can be downloaded for free below:
Feb 23, 2009 | RCA CDRW120 2-Disc CD Recorder
I need to know how to increase track external recording.
download a freeware program called "audacity" and use that to cut toe audio file up into seperate tracks.
Dec 24, 2008 | JVC XL-R5010 4-Disc CD Recorder
RCA CDRW 140 dual deck CD recorder
Place cd you want to copy in tray A (EVEN WHEN YOU WANT TO GET ONE SONG COPIED )
Blank Disc in tray B .
Program tacks in any desired sequence
Press the TIME SET / PROGRAM button on recorder or remote..."WAIT" appears then "01" flashes to let you know the unit is ready for the first track.
Enter the first track you want to program using the numbers buttons on the remote .
or SKIP / SEARCH button on recorder.
When the track flashes PRESS TIME SET / PROGRAM on remote or recorder.
to select it , "OK " appears
Oct 08, 2008 | RCA CDRW120 2-Disc CD Recorder
CD Players Logo
409 people viewed this question
Top Teac CD Players Experts
Jaime Hernandez
Are you a Teac CD Player Expert? Answer questions, earn points and help others
