Question about Harman Kardon Audio Players & Recorders
Harman kardon go play speaker - Harman Kardon Audio Players & Recorders
SOURCE: harman kardon soundsticks II
use a clear silicone based sealant (similar to the type used for caulking and in fish tanks) I'm guessing you used CA or superglue, and thats what melted your plastic, you're using too much also most likely.
Posted on Sep 25, 2007
Open SKy
  • 620 Answers
Orastie
Wow, general problem here, but the most near your problem could be, power failure, or the Power adapter is bad, or a energy failure at home, time to buy a new adapter.
Carl
Posted on Dec 30, 2007
Benimur
  • 6966 Answers
SOURCE: Harman Kardon go + play problem
Hi and welcome to FixYa,
Appreciate the direct "Ask Me".
Initially, pls try cleaning the battery terminals. In some instances, it may be necessary to scrape them to remove corrosion. Still there are times they may have to be bent or stretched to ensure that they provide more pressure to the batteries. Alternately, pls try to confirm that the AC adapter is working by checking for the presence of voltage on the plug/connector with the use of a voltmeter.
Should the above not address your concern, then it is most likely that the problem is internal electronics and the unit is simply going into protective mode. You then have a choice of performing a DIY (do-it-yourself) or seeking the services of a qualified professional.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 22, 2008
billfox1966
  • 231 Answers
SOURCE: removing cover from speaker
pull off the cloth cover by using your nail or a screwdriver to get behind it. its simply a push fit cover.then you can acess the screws. there are 4 deep in the holes where the cloth covers connected to the speaker and there are 4 holding the actual speaker to the face that are plainly visible once cloth front cover is removed.
Posted on Jul 24, 2009
  • 4 Answers
SOURCE: AirPlay won't connect to harman kardon receiver
My iPhone has a button at the bottom right-hand side of the screen (next to the volume control), that gives me the option to listen on the phone or to have it run on the Harman Kardon airplay. It automatically turned on the receiver and played the sound of the video in surround sound. It looks like a rectangle with a triangle at the bottom of it.
Posted on Mar 11, 2013
Can i bluetooth pair my harman / kardon stand alone speaker with my ps3?
Harman Kardon AVR products and how to connect to devices
? 6:02
https://www.youtube.com/watch?v=3aPKTDlOlf0
Mar 11, 2010 - Uploaded by hyperconnected life
What I originally wanted was to have a bluetooth microphone that ... I have the av 1700 with harman Kardon ...
Esquire - Harman Kardon
www.harmankardon.com > Wireless > Portables
Harman Kardon
Rating: 4.7 - ‎16 reviews
Esquire is a Bluetooth®-enabled speaker with a built- in conference phone system ..... the sound will bounce and the bass gets a little nicer...but stand alone in the ... able toconnect it to my iPad Air as of yet; it will not recognize it on Bluetooth.Missing: ps3
[PDF]Owners Manual - Onyx Studio - Harman Kardon
br.harmankardon.com/...//harman-kardon/.../Owners%2...
Harman KardonBluetooth pairing mode automatically when it is turned on. NOTE: The speaker's Bluetooth device name is HK Onyx Studio and password is 0000. Introduction ...Missing: alone ‎ps3
Dec 16, 2015 | Audio Players & Recorders
Harman kardon go and play don't have video out port
If I understand you correctly the Harman Kardon does not supply the output video and usb ports. Since this is a go and play they pobably felt it was not needed. to impliment these changes would require a complete design change.
Mar 28, 2012 | Harman Kardon Go + Play Portable Speaker...
It runs so hot why?
Possibly lack of ventilation or excessive volume through difficult speaker loads.
http://media.onecall.com/Image_Products/Harman%20Kardon/harman-kardon-hk990.pdf
See page 6.
IMPORTANT: When connecting two pairs of speakers, determine the impedance of each pair
by looking on the back of the speakers, in your owner's manual, or by contacting your dealer or manufacturer.
You can listen to two pairs of speakers at the same time ONLY if the impedance of EACH speaker is NOT LESS THAN 8 Ohms.
WARNING: Do not play sets of speakers simultaneously except as recommended above.
Amplifier may overheat.
Jul 09, 2011 | Harman Kardon Harman HK 990 Amplifier
My harman kardon soundsticks base light flickers, no sound
Ok this needs careful observation to determine this type of problem
Please unplug these speakers and plug it into an mp3 player and write back to me if the speakers work ok? I'll tell you more from there
Mar 15, 2010 | Harman Kardon SoundSticks II Computer...
Need driver for harman/kardon CN/04N567-48220-324-01QL desktops speakers
There is none. What you need is the audio driver for you desktop or laptop. Go to the manufacturer site and download the audio driver. If your audio is working it will play thru any speaker.
Dec 06, 2009 | Harman Kardon HK19.5 Computer Speakers
Garbled sound
Your Codec is damaged. Reload your drivers for your sound card. First uninstall the old ones. Moving your non working speakers and they play fine says they are good. I have a problem that you have new speakers and the problem went away. Drivers do not care what speakers are on the other end. It only produces output. Now that your second pair is working correctly, put back the Harmons and see if the problem comes back
Mike
Apr 23, 2008 | Harman Kardon SoundSticks II Computer...
Harman Kardon Sound Sticks Sub Problem
Oh well, buy new ones. What are harmon kardon sticks anyway?
Mar 09, 2008 | Harman Kardon Harmon Kardon SoundStick II...
Harman Kardon Soundsticks II left speaker
Hi, Kazim
Firts things First:
1) check connector for 2 way sound. you can use a headphone for this.
2) you also buy Ipod dock sound speakers, there is Ihome speakers, great ones, for less than 25.00 dollars.
3) you have to see balance on those speakers.
good luck
Jan 21, 2008 | Harman Kardon SoundSticks II Computer...
23 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Electro Med Services...
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
