Question about Car Audio & Video
I cant figure out how to remove the stereo in my bronco because I cant find any visible attaching hardware. how do i remove the stereo?
  • 50 Answers
Most models have 4 holes...one in each corner...if its a factory stereo...a special tool can be bought to remove it or you can find some thing like a coat hanger..cut it into 4 pieces about 4 inches long..insert into all 4 holes and give it a little pry and it should slide out.
Posted on Jul 25, 2009
How do you remove the pillar trim and scuff panel in a 1996 jeep grand cherokee
If there is no visible screws, just pry it up with a flat screwdriver
Feb 02, 2018 | 1996 Jeep Grand Cherokee
I installed a steering column in my 87 Bronco from another one. There is a wiring harness coming from the steering wheel about 16 inches long with a female plug on the end. There is no visible male plug...
there should be a one under the dash that it hooks to, kind of a half moon shaped connector. perhaps it still attached to the one that came out of it?
Jul 30, 2010 | 1987 Ford Bronco
Oil pan leak on 1994 bronco with a 5.0 liter
Oil Pan Removal
  1. Remove the bolts attaching the fan shroud (8146) to the radiator (8005) and position the fan shroud over the fan assembly.
  2. Raise vehicle.
  3. Remove exhaust manifold-to-exhaust pipe.
  4. Disconnect the oil cooler line at the left side of the radiator if equipped with an automatic transmission (7003).
  5. Remove the nuts and lockwashers attaching the engine support insulators to the chassis bracket.
  6. Drain the crankcase.
  7. Loosen transmission mounting nuts.
  8. Raise the engine (6007) and place wood blocks securely under the engine supports.
  9. Remove the oil pan attaching bolts and lower the oil pan (6675) onto the crossmember.
  10. Remove the oil pan from the vehicle.
Apr 07, 2010 | 1994 Ford Bronco
I bought replacement drivers for Mission 780 speakers...how do I replace them...no visible screws...does the cover plate come off?
Screws are hidden under the plastic plugs where the covers slot in. remove cover, then maybe use a pencil and fingers to prize out the rubber "holes". Once all four removed, unscrew the four screws visible. Carefully lift off baffle, note that tweeter will be attached to the baffle. You then have easy access to the driver, again another four screws holding that in. You may find erosion on the terminals.
Jan 10, 2010 | Mission 780 Main / Stereo Speaker
1994 bronco eddie bauer. I have no brake lights
I think there are 2 switchs on that brake pedal. You are right tho about the brake switch causing your problem.
If you fix your brake light problem your other problem will be fixed also.. check to see if the wires at the brake pedal switch are energized. I am betting on a ground problem.
Dec 22, 2009 | 1994 Ford Bronco
Changing Drive belt On Troy Built Tiller
You have to remove the engine (4 bolts, no big problem), then remove the bolt in the center of the pulleys, then remove the pulleys. Slip the belt(s) (2 if you have the Super Bronco model) onto the pulleys, re-attach the pulleys with the bolt, re-mount the engine, and you're home free.
May 20, 2009 | Mtd Troy-Bilt Bronco OHV Tiller
Cant figure out how to open Tray 1 to clear paper jam
Leave Tray1 closed. Remove tray 2. Push down on green arrows visible after removing Tray 2. You should see the jammed paper on the plastic tray which becomes accessible after pushing down on the green arrows.
May 05, 2009 | HP laserjet Cp2025dn color Card Printer
Fuse for 88' Ford Bronco
Fuse #1 20amp: Headlight Flash-to-pass; Daytime running lamps ( Canada Only ) OR Fuse # 19 40 amp maxi.; Headlamps.
Jan 21, 2009 | 1988 Ford Bronco
1989 BRONCO XLT WITH A 5.8 351 CLEAVLAND
The Bronco did come with the 5.8L. It's a 351 Windsor though. Ford quit making the Cleveland engine back in '74. You should have a vacuum diagram under the hood of your truck.
Aug 11, 2008 | 1989 Ford Bronco
Car Audio & Video Logo
44 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
