Are the old single line codes good for anything
Voyager MS9540 scanner...how do I enable code 93?
Go to www.honeywellaidc.com and click on English under North America. In the search bar type in 9540. You should only get one result for Voyager 95X0 Series of Single-Line Laser Scanners. Click on the heading and under the picture on the tab bar choose documents. Under user Guides choose MetroSelect Single-Line Scanner Configuration Guide. On page 14 you will find the barcode to scan "Enable Code 93" . Page 14 is also labeled as 2-6. Good Luck
Oct 01, 2012 | Metrologic Instruments MS9540 Voyager...
I cannot found driver for my acer veriton m261 windows 7 32 bit help please
There are a lot of places on the internet that have drivers (old & new), such as http://www.drivers.com , and I would try using Google Search for Acer and try to get the headquarters, corporation, etc. Most all brands of PC's still have drivers available for anything they have sold if they are a reputable company and I believe Acer is. Also search with Google Search for (acer veriton m261 for Windows 7 32 bit) all at once, in one line. You will get all kinds of hits on acer, veriton, Windows 7, just Windows, etc. Sounds like you are having a problem, so I wouldn't leave any site unexplored. Also try searching for single words like Acer, Veriton, M261, etc., etc. Good Luck! I'll be checking back to see if you were successful or if I think of anything else. It's kinda late and my old brain running low. -:)
Aug 20, 2011 | Acer Veriton M261 PC Desktop
I have a Canon SX110 about two years old. It has delveloped a single line through the pictures, always in the same place. What if anything can be done.
you probably have a bad cds sensor, flat rate repair in Warranty = 35.00, out of warranty = 165.00
Continental Photo,**************, ask for vic
Jul 31, 2011 | Cameras
Beepcode: single beep every 2 to 3 seconds continuous
Try taking out the ram and reinserting it also anything that is in the PCI Card slots.. other solutios is take and unplug each device and see if the boot up changes it will sometimes give a read code it might help eliminate the problem
Jul 26, 2009 | Dell Vostro 200 Mini Tower With 20" Flat...
Single green line spanning across the screen horizontally
I was just watching TV and all of a sudden the screen minimized down to a single green line spanning across the screen horizontally. The label in the back says it was made in 1996 so it is an old tv. Can anyone help?
Apr 08, 2009 | Mitsubishi CS-27205 TV
Kitchen faucet Remove
All faucets have a hot and cold line input. The single handle units have a mixing valve within the handle. Aside from removing the water lines there is usually some type of connecting bolts for the base plate as well that will need to be removed prior to removing the faucet. Do not forget to turn the shut off valves off at the wall before you remove the water lines.
Good Luck
Dec 03, 2008 | Plumbing
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
