Question about Home
I have an uber haus duel flush toilet and I took the seat off to clean underneath and now I cannot for the life of me put it back together. Help!!
SOURCE: putting back together the trimmer
I Need to kno a answer to this as well
Posted on Apr 25, 2008
  • 357 Answers
SOURCE: took spacebar off to clean up a pop spill...metal bar NOT attatch
There might be a metal wire if it is missing, which snaps to the keyboard, you may need a new keyboard.
If you are unsure, you should probably thake it to your local computer repair shop.
Good Luck.
Posted on Mar 15, 2009
Fixe_You
  • 1800 Answers
SOURCE: how do I put back together the straps on my car seat
would assume you're talking like a booster seat with the back just no 5pt harness. You just buckle them up like you do. If they have those arm rest looking things, the part where it buckels goes under that one arm rest and the shoulder strap should go resting over his shoulder like yours. Some of them have a loop up top for the shoulder strap to go through. Just make sure that the toddler does NOT put their arm over the shoulder part of the belt. If you get into an accident this could break his/her ribs.
Posted on Jul 01, 2009
SOURCE: washed liner, need to know how to put car seat back together
How to put car seat belt around infant car seat?
Posted on Aug 28, 2009
SOURCE: put harness belt back on baby car seat
22880-mtta is an Eddie Bauer carseat. Go to http://www.eddiebauer.djgusa.com/usa/eng/Instructions
Enter the model number 22880-MTTA, and date of manufacture.
Posted on Nov 20, 2009
Just wondering if it is okay to put a duel flush toliet in a basement. We live in Winnipeg Manitoba our house came with the pipes rough in thank you for you time
understand that a duel flush toilet is just a water saving idea and not an engineered specific situation
the flush is 1/2 for one flush or full for the other
the flush action and waste disposal is the same as for a single flush unit
Aug 28, 2017 | The Computers & Internet
MY TOILET WILL FLUSH BUT WONT FILL I CLEANED FLUSH VALVE AND VALVE HAS PRESSURE BUT WONT FILL TANK PLEASE HELP
Make sure the flapper is seating properly. If you can't tell, put some food coloring in the tank part... you will see color in the bowl.
Nov 02, 2014 | Danco Plastic Relief Valve Repair
Bemis duel flush toilet leaking, how do I fix it?
If the leak is inside the toilet, then you have a defective flush valve or flapper Which ever one is in your model toilet.
Jul 25, 2014 | Bemis Home
I have a toto duel Max toilet and the water leaks out of the bowl slowly. By the end of the day, I will have no water. Please help
Check flushing mechanism at the bottom of tank to check if it vopens and closes securely. and nothing blocks it.
Jul 27, 2013 | Toto Aquia II Dual Flush Toilet
How do you put the toto dual flush parts back together
Very carefully!!!!!! Why would you take it apart not knowing how to put it back together again?????? Take pictures next time, after you call a plumber to put it back together again Humpty....
Apr 20, 2011 | Toto Aquia II Dual Flush Toilet
How do i replace the tolet seat
the seat has two bolts that go straight thru the bowl at the back of the seat just loosen the nuts on bottom of the bolts replace same way you took it off
May 09, 2010 | Toto Aquia II Dual Flush Toilet
Cannot remove the lid
Hi and Wlecome to FixYa. I am Kelly
Unscrew the flush plunger assembly on the very top of the tank. It unscrews counter clockwise and then lifts out. Then you can lift off the tank lid.
When you go to put the top back you will have to align the flush pin gears in the slot.
If your talking about the seat.... then there are 2 nuts underneath the water closet at the back that must be removed.
Thanks for using FixYa.
Kelly
May 06, 2010 | Toto Aquia II Dual Flush Toilet
Toto toilet keeps running. water is going into the pipe continuously.I am stupid about fixing this.....or anything.....any SIMPLE help? thanks
Turn of the feed line for the water. Flush the toilet. Then reach in tank and pick up the flapper valve. Clean around the seat of the flapper valve real well. Check for damage on the flapper valve and clean it as well. Put the flapper valve back in its seat and turn the water on to fill the tank. Then bend the rod for the float down a touch. This will put more pressure on the water valve at the top of the pipe in the tank. If this doesn't work, you may need to change your float valve. They wear out. The ones you buy in the DIY stores generally have diagrams and good instructions for installation.
Jan 17, 2010 | Toto Promenade, 1.6 GPF, Elongated...
I have toilet with no visable clog but when I flush water fills the bowl and overflows? How do I fix
Something is stuck inside of the toilet. About the only way to get some of them out is to take the toilet up. Shut off water to the toilet and flush it one last time.You need to use a plunger and push all the water you can out of the bowl. Remove the bolts that hold it to the floor. Youll have a little left over water you'll have to clean up after this next step so get something to soak up water. It may be easier to remove the tank now than to take a chance on damaging the gaskets. Just going to have to turn the toilet over and over and over and see if something falls out into the bowl. To repair this damage you're going to have to clean off the wax ring (messy Job) and get a new wax ring. They're pretty universal 3 and 4 inch are the same. PUt the wax ring onto the bottom of the toilet then set it back over the bolts that hold it to the floor and tighten it back down. Replace the tank and tank gaskets if you took it off. When I fixed mine I found a AA battery inside. That was all it took to plug it up every time you flushed toilet paper.
Nov 29, 2009 | Toto MS950CG-12 Neorest 500 Elongated One...
Toto CST853 cistern will not refill. Was fine yesterday. City is working on pipes and broke a water main last evening, all other faucets and toilets are working....can I clean the water filter or does it...
alot of times you can turn the water off to the toilet and the tops of the fill valves usually pop or screw off. then if you put a small cup over the top of the fill valve you can turn it back on and flush the debris out and put it back together. if its a fluid master type you can pop the top off it. and turn the float arm a 1/4 to half turn and the whole top will come off
Jul 31, 2009 | Toto Aquia II Dual Flush Toilet
Home Logo
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
