Question about Hard Computers & Internet
My toshibia satelite laptop show that it cant find any hard disk drives and to run a manufactured diagnostics ???? What do i do.
    Top Expert:
  • Hard Master
  • 77,932 Answers
You must obtain the recovery disc set and reload the operating system. If that fails the hard drive may be faulty or the mother board.
Posted on May 18, 2017
  • 1183 Answers
SOURCE: primary hard drive not found
since you already tried removing and reseating the hdds . The problem could be the motherbaord slot. To troubleshoot the same
1. First Disconnect all hardrives and optical drives from the system
2. Go to the system setup or BIOS
  1. Turn on (or restart) your computer.
  2. When the blue DELL™ logo appears, press <F2> immediately.
If you wait too long and the operating system logo appears, continue to wait until you see the Microsoft® Windows® desktop. Then shut down your computer and try again.
3. Hold down the ALT key and press "F"
4. Hit ESC , save changes and exit .
5. SHutdown the system
6. Reconnect the HDD IDE cable to the optical drive connector on the motherboard.
You can refer to the following motherboard diagram
7. Check if the hdd , is getting detected in the system setup
You can refer to the following link on how to read system setup screen
Posted on Jan 30, 2009
  • 1223 Answers
SOURCE: how to format acer aspire 4710 with xp
actually there is no need to touch anything in hardware please do not touch ur hardware without any reason i know what eactly is the solution is now follow this :
Problem : When Windows XP was made there was no concept of SATA drives now ur drive is SATA and ur installation disc does not contain drivers for ur Hard disk thats why it is unable to find ur hard disk as it doesnt recognize it u need sata raid drivers on ur windows inst cd
this specific model Aspire 4710 was shipped with vista OS and drivers now u are downgrading it to XP it depends on the installation disc if it is new one like SP3 included then u would have never faced this issue in ur case u should get a RAID driver from and then include them in ur copy of windows XP cd to load them at the startup of installation , so u need them in the first place to carry out installation, u have to do some job here download RAID DRIVERS from select ur board and chipset Mobile Intel® 945GM Express download SATA RAID DRIVERS and then download nlite a software used to integrate these drivers to ur inst disk , u can also include SP3 thru this software in ur current win xp cd
just download sata drivers from intel and nlite from the link and install the software integrate these drivers and burn ur cd incl them and then install normally as u were installing them earlier now it will recognize ur drive simple for more info how to do check this out
important tutorial links
pls let me know if i can help u more
Posted on Feb 23, 2009
  • 114 Answers
SOURCE: Compaq 6720 Hard Disk replacement
I agree, take a Seagate 500 GB 7200 RPM drive for laptops. The standards for the connections are same. So that would not be a problem. Make sure its for laptop and not the desktop one.
Posted on May 14, 2009
SOURCE: Dell Latitude C610 doesn't recognize hard drive
when you took out the old hard drive
there is a black hard drive connector
this would have holes to push on to the new hard drive
without this, it will not plug into the motherboard
be careful if one of the pins breaks the hard drive wont work
Posted on Jul 21, 2009
  • 180 Answers
SOURCE: DELL INSPIRON 1545 (Windows 7) My
It seems that the Hard Disk is disconnected from it's connectors
It needs to be fixed and installed correctly.
To do that, there are screws in the back, remove them and disconnect the hard disk, and reconnect, fix it correctly.
If it's difficult to you, go to technician to do that.
Please, Tell us your results.
Good Luck
Posted on May 20, 2011
No diagnostic utility partition found to run diagnostics
Think about this for a min.
The Primary hard disk cannot be found by the System.
The Diagnostic Utility is ON the Primary hard disk.....OF COURSE IT WON'T FIND IT...
Since the motherboard is not able to even detect the drive as being present, there is nothing YOU can do to get it 'going' unless you replace the BAD hard drive with a new one.
[PS: I hope you've backed-up any important data....]
Aug 31, 2012 | Dell Latitude C640 Intel Pentium 4-M...
Whenever back up or defrag laptop goes off
Three things you can try:
1. Disable automatic restart on System failure.2. Boot your laptop to safe mode and run a hard drive diagnostic program3. If the test fails, the replace your hard drive:a) Order the recovery disks for your laptop from the manufacturer of your laptop. Call them to order it.
b) Take your old hard drive to a big name electronics store such as best buy, and ask them to sell you a similar hard drive.
c) purchase a USB to SATA cable (sold in most electronic stores) to turn your old hard drive into an external drive that plugs into your laptop's USB so you can transfer your data.
d) Reinstall Windows using the recovery disks and after your done, plug in your old hard drive and transfer all your data.
Let me know if this helps.
Best regards,abdielcomputer repair plantation
Oct 23, 2011 | Toshiba MK2529GSG (HDD1F07) 250 GB SATA...
Iv switched my toshiba laptop on and its says no bootable device insert boot disk and press any key? do you know why this might of happend and how i should repair it?
sounds like hard drive
  1. determine what brand of hard drive you have.
  2. Go to that manufacturers support site.
  3. Download their self booting diagnostic CD iso image.
  4. Create the disk according to the instructions.
  5. Boot to the disk and run the most exhaustive tests available to determine if the drive is bad or not.
Jan 17, 2011 | Toshiba Satellite A215-S5818 Notebook
The laptop say's failed disk read, on start up. I did a system check and got this error reading. I am unable to start the laptop, just get the failed message. Would much appreciate a reply with a...
NTFS Read/Write Bootdisk And Bootable CDs
I bought this iso file from here. He charges $4 which is a bargain for this tool. Download the ISO on a working PC with a cd burner and create the boot disk. Boot the problem PC from the CD rom and run chkdsk from the black dos screen.
If this does not fix the problem then open the access door to the hard drive on the bottom of the laptop and find the make and model of the hard drive. Go to the hard drive manufactures web site and download a bootable ISO with the diagnostic utilities for the hard drive. This will tell you if it is fixable. Are you still under warranty? The laptop maker's web site may have a diagnostic tool you can download as well. This will give you a code which the manufacturer's help desk will need to authorize a replacement Hard drive. Other wise find a replacement drive from ebay or other suppler.
Sep 27, 2010 | Computers & Internet
I have a laptop which it does'nt detect the hard drive what is the problem?
The problem could be one of these -
The hard disk needs reseating to make proper electrical connection.
The hard disk is faulty.
The BIOS has not detected the hard disk.
The hard disk controller is faulty
To determine the fault -
Reseat the hard disk and boot up the laptop.
Check the BIOS configuration - does it detect the hard disk. The BIOS may have a hard disk diagnostic, if so then run the diagnostic.
For a further hard disk test - remove the hard disk and connect it to an USB hard drive adapter and plug it into a working computer's USB port. If the hard disk is OK then this computer will detect it as an external hard drive and you can open the folders and files.
If not then the hard disk is confirmed faulty.
To get the Gateway working, install a new hard drive and install Windows, the laptop's device drivers and your programs.
Sep 05, 2010 | Gateway 450ROG Notebook
While i am opening the windows it showing that bootmgr is missing and press ctrl+alt +del. but after pressing them nothing will i need the solution what to do.
This is often caused by two things:
  1. A virus
  2. A bad disk drive
Since you cannot get into the computer your left with checking the disk drive. Disk drive manufactures have diagnotic programs you can download. On another computer, download Seagate disk tools from their web site. Burn a CD and boot your laptop with it. Run diagnostics.
If it says you don't have a Seagate disk, it will tell you the brand. Go to that brands web site, repeat above.
If you have a bad disk, then you need to replace it. On laptops it is fairly straight forward but you also need to restore your system. If you don't have restore disks, you'll have to buy them from the laptop manufacture.
Aug 22, 2010 | Computers & Internet
Cant play movies from my toshibia laptop
There are several reasons why a movie won't play, so I will run a few suggestions by you:
Hopefully ;you have a DVD drive or a DVD RW drive ?
If you insert a DVD or CD into the drive, your computer should recognize that a disk is inserted. If not the drive might be bad
You must have some sort of Software installed to make movies play, such as WinDVD, or PowerDVD
Oct 29, 2009 | Toshiba Satellite A15-S157 Notebook
Hi,toshiba satelite pro L20 beeps when start up
Run check disk for hard drive errors. I recommend immediately backing up all your data that you can, wiping it, and reinstalling your programs. The rebooting problem smells like a bad hard drive. I just went through it with a Compaq at work.
Sep 16, 2009 | Toshiba Satellite Pro 6000 Notebook
Hard drive making noise
The diagnostiocs cd is generally provided by the manufacturer or sometimes it is within tour own computer{like dell computer},,best way to know it is u call up the tech support guys of Sony and ask them tohelp you..
English: 239-768-7545{sony support}
24 hours a day / 7 days a week
best of luck,,a good rating plz
May 15, 2009 | Fujitsu AMILO PC Laptops
Unable to boot into windows
what are the things that you added recently, hardware(additional hdd, memory, video card) or software (antivirus, office, etc games.) try running a hard drive diagnostics, usually computer manufacturer install a hdd diagnostics on their BIOS that you can run. hit me back on the results.
Apr 28, 2009 | Dell Inspiron mini 9 - Black , Intel® Atom...
Computers & Internet Logo
Top Hard Computers & Internet Experts
David Clark
David Clark
john smith
Are you a Hard Computer and Internet Expert? Answer questions, earn points and help others
