Question about Electrical Supplies
Westinghouse 315P047A motor wiring diagram - Electrical Supplies
2 Suggested Answers
SOURCE: looking for westinghouse wiring diagram
I have just removed one of these motors today. The cabinet has the wiring diagram on it. I will be back on site once I find a replacement motor and can get the diagram then.
Any idea what motor replaces this one?
Posted on Dec 21, 2010
Testimonial: "i found a fasco d262 motor on shortys hvac supplys website [www.shortyshvac.com] that will work for me.look for a fasco d151 this may work also "
Hi, I have a similar problem with my fj383 and I also turned the knob down he back on the left hand side. Now i just have a timer type sound coming from that box and the freezer not running. thankyou
I did not quite understand your question, ... "I have a similar problem?"
DO a GOOGLE SEARCH for: "Westinghouse fj383" freezer troubleshooting and find 1,260 results!
westinghouse fj383 freezer troubleshooting Google Search
Then do THIS GOOOGLE SEARCH for even more!
"westinghouse fj383" manual (WITH the quotes)
westinghouse fj383 manual Google Search
1,300 results ~ but many may be duplicates?
Then this interesting (to me) GOOGLE SEARCH in "IMAGES" for "westinghouse fj383 wiring diagram".
westinghouse fj383 wiring diagram Google Search
... where I found THIS part:
There is NOT that much (electrically speaking) else that would make the sounds you describe!
Looks like a Frigidaire Refrigerator Defrost Timer 215846604 may be the puppy you need for about $8 plus shipping OR
Defrost Timer for White Westinghouse WWTR1502KW7 Refrigerator
HOPE this helps!
Anthony
(say Thank You!)
Apr 17, 2018 | Refrigerators
Can i get a wiring diagram for a westinghouse type FJ motor. it has a B145 frame; 1 phase; 110 v; westinghouse part #NO-1008
because it is 110 volts any work by yourself will be dangerous. take it to an accredited electrical motor rewinder for what you want and be safe.
Mar 06, 2015 | Miscellaneous
Wiring on a 1/2-1/6 hp ac motor
should be a diagram on the side of motor if not check with who sells them
Apr 18, 2014 | Pool & Spa
2 speed switch wiring dieagram
The motor will have wiring diagram and voltage on nameplate.
You can re-post question with information that shows on nameplate for more exact information, or keep reading below:
If motor is rated for 240Volts, then it will not work with 120V.
If motor is rated for both 120V and 240V, then either Low voltage or high voltage will work, and one wire will be common, and 1 wire will for 120 and other wire for 240.
If motor is rated 120Volt two speed, then one wire will be neutral, and 1 wire low speed, and other wire high speed. You can connect your wire to either low of high, and cap other wire.
If motor is 240volt two speed, then one wire will be common, and 1 wire low speed, and other wire high speed.
If motor is rated 3-phase, then all three wires are connected to the voltage shown on nameplate.
If motor is rated 3-phase two speed, you may need electrician to wire the motor correctly.
http://waterheatertimer.org/pdf/AO-Smith-motor-wiring.pdf
Jun 08, 2012 | Westinghouse Electric Westinghouse...
Dishwasher Westinghouse SB915 fills with water for wash cycle but does not wash.
Contact Westinghouse directly to request the wiring diagram.
May 30, 2017 | Dishwashers
I am trying to get a wiring diagram for a westinghouse transfer switch style 06t7038 atsbp20400gs/12/93 voltage 220
Where can I get a wiring diagram of a Westinghouse Automatin Transfer Switch, Style# 3T4090, Catalogue# ATSBP20070WJ
Aug 27, 2011 | Heating & Cooling
Looking for westinghouse wiring diagram for blower motor model number 319p798
Dec 20, 2010 | Heating & Cooling
I have a motor with no wiring diagram. It is a westinghouse motor serial number Q167411.
how many wires ?and the colors of them ...their should be a diagram on the motor unless.its unreadable..let me know ..good luck plus what is the motor off of ?/joe/
Aug 26, 2010 | Heating & Cooling
Westinghouse fridge thermostate replacement
Without drawing a diagram, and assuming you have the controller, you need to do two things: Power the controller by finding a wire pair in the fridge that is always hot, and finding the wire that the resident thermostat uses to interrupt the operation of the compressor. This thermostat is usually located behind a panel in the top part of the refrigerator section and has a bulb that resides in the freezer. . Your controller should have an on and off range; that is, it should cut the fridge on at, say 61, and cut back off at, say, 60. You'll need some kind of range, thereby giving the compressor some "off time" of more than a couple of minutes. If you don't do this, you will reck the compressor, or it simply won't start. (Refrigeration systems need to equalize so that the compressor motor won't have to start when the pressure is really high. At equal pressure between evaporator and condensor, the motor can start easily.) . You have quite a project ahead of you. I suggest when you get into the nitty gritty of it, enlist your neighborhood MacGyver type. It shouldn't be that hard to pull off this project.
Nov 25, 2009 | Westinghouse Refrigerators
Electrical Supplies Logo
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
