Question about Ford Car Audio & Video
I need a wiring diagram for the female plug-in for the radio/6 CD changer. 2007 Ford Freestar About 20 pins.
SOURCE: Kenwood CD changer wiring diagram
http://www.kenwoodusa.com/Support/Car_Entertainment_Owners_Manuals/#_
Posted on Jan 18, 2008
SOURCE: NEED WIRING COLOR CHART
http://www.the12volt.com/installbay/vehiclewiring/1/yeard/Ford.html
Here you go
Posted on May 31, 2008
AUTOSOUNDINS
  • 232 Answers
SOURCE: 1998 - 2002 Honda Cassette 6 disk CD changer Radio
the cd changer is malfunctioning, the factory cd changers usually don't last that long because of the heavy use and many mechanical puts
Posted on Aug 14, 2008
robshow
  • 367 Answers
SOURCE: kia optima 2004 transmission selector wiring colour diagram
Try this website www.kiatechinfo.com
This will be far more usefull than me just handing you the diagram
Posted on Jan 19, 2009
SOURCE: Clarion 6 Cd Changer 1999 Ford Expedition OEM - NO CD DJ on display
plays and changes song fine just no sound
Posted on Jun 12, 2009
How can 6 CD changer be fixed that stopped working after battery was removed and replaced?
Try putting your radio code back into the system it should be written in the hand book if you don't remember it.
Nov 01, 2014 | 2004 Ford Freestar SEL
Anyone have the 2001 VW Golf speaker wire colors?
If your Golf is the premium sound model here is the list:
2001 Volkswagen Golf Car Radio Wiring Schematic for Monsoon Audio
Car Radio Battery Constant 12v+ Wire: Plug #3, Pin #7
Car Radio Accessory Switched 12v+ Wire: Plug #3, Pin #4
Car Radio Ground Wire: Plug #3, Pin #8
Car Radio Illumination Wire: Plug #3, Pin #6
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Plug #2, Pin #5
Left Front Speaker Negative Wire (-): Plug #2, Pin #6
Right Front Speaker Positive Wire (+): Plug #2, Pin #3
Right Front Speaker Negative Wire (-): Plug #2, Pin #4
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Plug #2, Pin #7
Left Rear Speaker Negative Wire (-): Plug #2, Pin #8
Right Rear Speaker Positive Wire (+): Plug #2, Pin #1
Right Rear Speaker Negative Wire (-): Plug #2, Pin #2
Signal for Anti-Theft Alarm System Wire: Plug #3, Pin #1
Data Link Connector (DLC) K-Wire: Plug #3, Pin #3
Battery Supply Constant 12v+ Wire for Anti-Theft System (SAFE): Plug #3, Pin #5
CD Changer Data In Wire: Plug #1, Pin #13
CD Changer Data Out Wire: Plug #1, Pin #14
CD Changer Clock Wire: Plug #1, Pin #15
CD Changer Constant Battery 12v+ Wire: Plug #1, Pin #16
CD Changer Control Signal Wire: Plug #1, Pin #17
CD Changer Ground Wire: Plug #1, Pin #18
CD Changer Left Line Out Wire: Plug #1, Pin #19
CD Changer Right Line Out Wire: Plug #1, Pin #20
May 18, 2010 | Car Audio & Video
05 G6 radio reads cd changer errror
Im having the same issue ..and actually seen this issue on alot of message board or websites..starting to think its a manufacture issue
Apr 17, 2010 | Buck Pontiac G6 2005-2007 05 Stereo/radio...
Alpine CHM-S620 6 Disc CD Changer Components
sounds like the changer was plugged into the antenna jack of the radio. this means that you can run it through any radio simply by sending a signal to a preset station on the radio and listening to it through tuner. the control unit ran the changer itself. you may be able to obtain replacement cables from pacparts.com
Apr 01, 2010 | Alpine CHM-S630 6-Disc CD Changer
Jammed cds in a 6 cd changer ford ranger 2002
sounds like the tray inside was misaligned when the cd went in. and it probally sent the disc into a occupied slot. you will have to remove radio and disassemble to repair. also try just unpluging radio and plug back in. sometimes it resets the radio and will start ejecting the cds
Feb 05, 2010 | OEM Systems Car Audio & Video
Just need a pic to see what color wire goes to each of the 20 pins on the back of the deck
Wiring Diagram / Color Codes
1. Power Antenna (dark blue wire) - Connect to power antenna or amplifier.
2. Ground (black wire) - Connect to ground terminal or clean, unpainted part of chassis.
3. Memory/Battery (yellow wire) - Connect to battery or 12 volt power source that is always on. The radio will not work if this wire is not connected.
4. Accessory/Ignition (red wire) - Connect to existing radio wire or radio fuse.
5. Left front speaker - White/Black is negative, White is positive
6. Right front speaker - Gray/Black is negative, Gray is positive
7. Left rear speaker - Green/Black is negative, Green is positive
8. Right rear speaker - Violet/Black is negative, Violet is positive
9. RCA Outputs to Amplifier - Black is front, Gray is rear
10. Auxiliary Input Cable
11. Subwoofer Output
12. Antenna
13. CD Changer
The manual is available here:
http://diversesolutions.org/files/CD4610.pdf
The wiring diagram is under the section Wiring.
Jan 13, 2010 | Jensen CD4610 CD Player
Need how to connect cd changer
I think the factory used one wiring harness for all the radio's, on a low cost radio you just plugged in the connectors needed for the radio setup in the vehicle and the rest of the connectors are just laid aside. You can't just buy a radio harness, you buy the entire wiring harness for the cab, in any event check this out on the harness and see if the connectors are their.
Dec 02, 2017 | Car Audio & Video
Wiring diagram needed
The Pioneer website has both the OEM and Install Mauals in PDF format thast will solve your problems... I downloaded both earlier today...
Apr 01, 2009 | Pioneer CDX-FM677 6-Disc CD Changer
Car Audio & Video Logo
24 people viewed this question
Top Ford Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Libran Moreno
Are you a Ford Car Audio and Video Expert? Answer questions, earn points and help others
