Where can I buy water pump for AF-351 Air Cooler
2 Suggested Answers
emissionwiz
  • 77499 Answers
SOURCE: I need to get a water pump for AF-351 cooler
Sorry we do not sell parts or do we have the means to locate them for you.
Posted on May 18, 2017
May 18, 2017 | Cars & Trucks
We have the AF-351 plugged and ready to turn on but it doesn't turn on how do we turn it on.
http://cache.air-n-water.com/manuals/newair-af-351-manual2.pdf read this manul might be of use
Jul 13, 2013 | Heating & Cooling
Need parts, pump for a ED630J adobe swamp cooler in las vegas, nevada
A swamp cooler PUMP is not really model specific. They are basically small submersible pumps. Contact ANY swamp cooler dealer in LV, tell them you have a 4500 CFM unit and need a pump.
The pump part number for this size cooler is: PN 110436 (there are several alternates)
Contact these folks and tell them what you need:
National Cooler ' Swamp Cooler
3046 Vegas Dr.Suite 1
Las Vegas, NV 89106
(702) 638-8800
If they can not help you... just look under cooling and air-conditioning in the yellow pages and find a dealer near you. This pump is common to nearly every brand in LV. You can most likely buy one at the local home depot, menards, or lowes.
There is also a Little Giant CK-5 "UTILITY"pump that is used for swamp coolers.
Thanks for choosing FixYa,
Kelly
Jun 15, 2011 | AdobeAir Mobile Swamp Evaporative Air...
Swamp cooler works i can hear the pumpon water is turned on but not getting cool air
just because the pump is on dose not mean its moving water. impellers can break and pump can get air lock
Aug 01, 2010 | Mastercool 67680 Evaporative Cooler Air...
I have a 84 351 windsor that runs way to hot i put
seems to me that you could have an air lock, try loosening the rad cap slightly and run car until fans kicks in, squeeze upper rad hose a few times to push any air out. Careful with hot hoses. see if this helps.
Apr 27, 2010 | 1991 Ford Mustang
Swamp cooler is not blowing cool air
is the units Disturbing the water over the pads!
if not check the water pump!
are the pads old and worn out, buy new ones.
and if the Humidity is to high they do not work well
Jul 16, 2009 | Heating & Cooling
Evaporated cooler is not filling up with water
yes ur water pump is not working properly..
ur will have to check it
Jun 29, 2009 | AdobeAir Mobile Swamp Evaporative Air...
Air coming out of an adobeair portable evap cooler isnt cold
paula298,
A new unit will take a while for the pad to become wet and more efficient. Remember, there may be two switches: fan and water pump. The unit must be full of water and the pump ON to work correctly.
If the unit has a water pump only setting, run the pump without the fan for about 20 minutes. That will get the pads nice and wet and you should get a good result. A rule of thumb in the desert is 20 to 25 degrees of cooling compared to the ambient air.
Don't use a cooler in closed area. The cooler will simply act like a room humidifier. Use in an open garage or porch for the best result.
I hope that helps.
Ed Phillips ed@azalmanac.com
May 12, 2009 | AdobeAir Evaporative Cooler Direct Drive
Evaporative cooler not getting water from water line
The pump is probably gone. the way it works is a float allows the water level to stay the same in the reservoir so check that. Water is pumped up to the hoghair and trickles down into it. A big old blower pulls the wet outside air into the room. We call that one a swamp cooler down here on the gulf. Go outside and spray some water on the unit to cool down the house till you can get the pump replaced.
May 10, 2009 | Heating & Cooling
My portable air conditioner has stopped pumping water to the tank
this would be a swamp cooler.if you have water in it and its not pumping.its going tobe the pump but i would see if the pump is getting voltage first before i bought a new pump.where doyou live that your worried about a cooler?
Jan 01, 2009 | Heating & Cooling
Heating & Cooling Logo
22 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
