Question about Samsung Televison & Video
I have a samsung 50 inch plasma tv ..my tv just shut of and when I tried 2 turn it back on it just made a clicking sound a few times anyone know how 2 fix it
jerryg50
  • 1673 Answers
SOURCE: panasonic 50 inch plasma
You should call for warranty service. If the set is very new try to get it exchanged.
There are some very heavy duty power supplies and many high power matrix drivers used in Plasma sets.
The description sounds like the noises are very loud. It is normal with any of these TV sets, if you put your ear right up to the back of the set at the vent holes you will hear some noises. These would be some acoustic harmonics from the power supplies and related circuits.
I am wondering if it is possible that there is something that is becoming less stable. If the set is working very well without any failure, so-far this is a very good sign. Before it gets to be a problem, I would have this checked.
On many models of these sets, they use fans for cooling specific areas. A bad fan can cause noise.
Jerry G.
Posted on Apr 14, 2008
SOURCE: Broken Plasma TV
I'm looking for a broken screen HP-S5053 to buy from someone. I have a new screen that needs a home. I need one that is complete and working other than the screen. Or I would sell my screen to you. Thanks, Wade wade@engineeringexperts.us
Posted on May 21, 2008
  • 35 Answers
SOURCE: My samsung plasma suddenly made clicking noises and tuned off
I wish to tell the world about the simple cheap fix for your plasma! . Please let me know if I helped. I have a 50" Plasma that deicded after a year it didn't want to turn on anymore. It just blinked red LED. Which made me see red! It took me a year to find this inexpesive fix I hope this information will be helpful to you.... These are spendy items and none of us were thinking that after a year (seems like a scam to me) the TV just won't turn on anymore.... Then they say your no longer covered under warranty or you are and they send you to some repair shop 1-2 hours away and always and I mean always tells you the part is on back order.
Lukster is right it is a power supply problem. However you don't need a new board nor do you need to pay someone a ridiculouse abount of money to fix this. I fixed mine for 40 cents.
You more than likey have bad capacitors.
Unplug the TV from power. Remove the back cover. (some models require a star srewdriver) You power supply board is right in the center. A bad cap is bulgded or raised. A good one is flat. caps have an X on the top of them. More than likely you will see a bulding or just straight raised edges on the X on the top of the caps. Cap 3300uf 10v is the ones you are looking for. Once you find them replace them with 3300uf 16v caps. If one cap is not raised replace it anyway. These caps need to be a higher voltage that why the tend to pop. 16V is plenty, don't go any higher in voltage than that.
The caps need to be soldered on. You have 2 options do it yourself or unplug all the wire harness from the board then unscrew the board take your power board (dont forget your new caps) down to a pc repair or tv repair and have them solder them on for you. It will take less than 10 minutes. I do recommend putting the board in an anti static bag. You can buy these caps at radio shack or buy them on ebay.
After you get it repaired replace your board plug all power supply wire harness back onto the board (I recommend numbering the wires as you remove them), replace the back panel cover. Plug her in and fire her up. and BAM it works. then turn it on and off a few times in complete amazement at how simple and inexspensive this was to do. Then get angry cause your repeated calls to tech support was wasted breath.
Semper Fi
Posted on Feb 07, 2009
SOURCE: my 50 inch samsung plasma tv turns off and on by
My Samsung 52" plasma TV will shut off while watching TV. It will do it repeatedly and we have to turn it back on. Is it overheating and shuts down? How can this be fixed?
Posted on Dec 19, 2009
  • 8457 Answers
SOURCE: my vizio 50 inch plasma tv will not turn on. what
Tries unplug,replug about an hour,see if it reset itself.Not than must replaced the signal tuner board.Plasma have this problems alot.
Posted on Jan 08, 2010
Will not turn on I have already replaced the Samsung plasma TV pn60e530a3fxza pwr supply
Samsung Plasma TV - Won't turn on - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I have Samsung 50" plasma tv model HP-S5053. The unit would not power on and blue light was out. Tried a different power source which did not change result. Samsung TV LN52A650A1FXZA won't turn on, keeps clicking
Jun 11, 2015
Samsung TV won't turn on
Jun 11, 2015
Samsung LCD TV LN32A330 power won't turn on
Jun 11, 2015
TV won't turn on
Jun 10, 2015
More results from www.cnet.com
Samsung 50 inch plasma wont turn on - YouTube
? 0:59
https://www.youtube.com/watch?v=Uo-SazF_G9Y
Jan 9, 2014 - Uploaded by 8Jallin
Samsung 50 inch plasma wont turn on. 8Jallin ... Up next.samsung plasma tv not working, wouldn't turn on, FIXED, repair, diy - Duration: 14:56.
Feb 09, 2016 | Samsung Televison & Video
Plasma tv repair
? 0:59
Samsung 50 inch plasma wont turn on ... samsung plasma tvnot working, wouldn't turn on, FIXED, repair, diy - Duration: 14:56. by Matthew ...
Plasma TV Repair Tutorial - Common Symptoms ... - YouTube
? 7:13
https://www.youtube.com/watch?v=gnkyAGyI7GA
Oct 9, 2013 - Uploaded by ShopJimmy.com
Plasma TV Repair Tutorial - Common Symptoms & Solutions - How to Fix .... Samsung 50" Lcd tv model#Lf501EM6f Im not sure if its plasma or ...
WHAT Plasma TV BOARD CAUSES NO PICTURE REVIEW ...
? 4:10
https://www.youtube.com/watch?v=DC_75FfrR9w
Nov 8, 2012 - Uploaded by Tampatec
WHAT COMMON PART / TV Board IS BAD ON SAMSUNG Plasma ... a gamble. it the cost of repair is over 300 just buy a new 50 inch tv for 600.
Samsung 50" Tv Power Supply Boar...$34.00eBaySAMSUNG UN60EH6002FXZA...$23.00TV Parts Guy42% price dropSamsung 50" Pn50c550 Pn50c45...$18.99eBay
Dec 21, 2015 | Samsung PN60F5500 60-Inch 1080p 600Hz 3D...
My Panasonic plasma Tv does not have sound. How do I fixed that
Sound no picture on 50 inch samsung plasma ps51d450a2m - HDTV ...
www.tomsguide.com/.../58009-4-sound-picture-inch-samsung-plasma-ps...
Jul 1, 2015 - 4 posts - ‎3 authors
There is sound and no picture on plasma tv, remote works at times but ... My pioneer elilte has this mode, and it is pretty easy to completely turn ... When I connect my Laptop to my TV thru HDMI cable I ...
Feb 22, 2015
Problems with blu ray player and plasma tv - HDTV ...
Nov 16, 2014
I do not have audio out on my tv how do i connect so ...
Dec 18, 2013
All channels on my tv have sound except channel 3 ...
Jun 29, 2010
More results from www.tomsguide.com
No picture or sound in my Panasonic TH-P42UT30A plasma ...
Dec 07, 2015 | Panasonic Viera Th-50px60u 50" Plasma...
LG 50 inch plasma has trouble powering up. have
Power supply board have dead capcitors.Know how to solders?These capacitors usally bulge or pop open,replaced these capacitors will solved this problem.Or tries websites Shopjimmy.com,Ebay.com to buy a Whole reburbish power supply board for the replacement.
Mar 04, 2010 | LG 50PX5D 50 in. Plasma HDTV
My 50 inch samsung plasma tv turns off and on by itself. it also clicks while this happens.
Oct 27, 2009 | Samsung HP-R4262 42 in. Plasma Television
My 50 inch plasma
We have a 50 inch magnavox plasma screen. We found and used a fix from fixya! It only costs us $34.00 campared to the $300.00+
anyone wanted to look at it. The problem was on the powerboard but was two little capacitators with the model #3300 10v. We carefully took the back off the tv and removed the power board, went to a local electric supply store and bought the 2 parts for $2 each, we then found someone (tv repair shop!) to sauter the new ones on! Got it home put it back together and it stayed on, no depressing shutdown after a few seconds! you can find a picture of a fried capacitator on yahoo images, they are supposed to be flat but if defective will be bubbled at the top or even split! I am calling Magnavox today to complain that they are not recalling this part that should have been a better quality capacitator! Hope this helps some people!!
May 23, 2008 | Philips 50PF7320A 50 in. Plasma HDTV
TV turns off by itself & won't turn back on til unplugged, then plugged back in
Well, first your model number is the 42 inch, but I digress...
I had a similar problem with a Viewsonic 27 inch, with the blinking power light on a failed power-up. It turned out that replacing the power transformer was the ticket. However, as I have the 50 inch Panasonic plasma, I know that the transformer is built into the set itself. I'd still suggest that this is what needs replacing though, as this is different from a set being on but having no picture.
Apr 18, 2008 | Panasonic TH-50PX75U Plasma HDTV
Flickering
I would suggest to call Samsung to get the Plasma repair under manufacturers warranty. The flickering will not go away until the hardware failure is corrected.
Good Luck.
Apr 15, 2008 | Samsung HP-T5044 50 in. Plasma TV
Plasma will not turn on
Sounds like u might have a bad power supply
Apr 05, 2008 | Televison & Video
Televison & Video Logo
Henry  Thomas
Henry Thomas
