Question about Electronics - Others
Comes up 7 flashes on control panel - Electronics - Others
The control panel flashes its lights and chair wont move
When my Pronto did this, it was diagnosed as a failure of the controller. Replacement was about $1200. Good Luck.
Dec 09, 2014 | Health & Beauty
Tip
How to Change or Remove Windows 7 Password?
Windows 7 allows you to create a strong Windows 7 password to protect your data on computer. Meanwhile it also provides you solution to change or remove Windows 7 password. So you are able to change Windows 7 password if you forgot Windows 7 password or intend to reset Windows 7 password for other reasons. Here are guides on how to remove or change Windows 7 password.
Solution 1: Change or remove Windows 7 password through Windows 7 control panel
If you can log on your computer with Windows 7 password, you can remove or change Windows 7 password easily through Windows 7 control panel.
To change Windows 7 password, please follow the steps:
Step 1: Click on Start > Control Panel > User Accounts and Family Safety > User Accounts.
Step 2: Click Change your password.
Step 3: In the screen comes up, type your current password, the new password you would like to start using and a password hint. (password hint is optional)
Step 4: Click Change password button to confirm your Windows 7 password change.
Now your Windows 7 password has been changed, and you must use your new password to log on to Windows 7 from this point forward.
To remove Windows 7 password, it is also very simple. Just follow the below steps:
Step 1: Click Start > Control Panel > User Accounts and Family Safety > User Accounts.
Step 2: Click Remove your password.
Step 3: Type your current Windows 7 password in the text box on the following screen.
Step 4: Click Remove Password button to confirm that you'd like to remove your Windows 7 password.
Now your Windows 7 account password is removed. And you will no longer need to log on your computer with Windows 7 password.
Solution 2: Remove Windows 7 password with Windows Login Recovery
If you are locked out of computer as you forgot all Windows 7 passwords, what should you do to remove or change Windows 7 password then? At that time, you need the help of Windows password recovery software to remove your lost or forgotten Windows 7 password. Windows password recovery software allows you to remove lost or forgotten Windows administrator password, standard user password on all popular Windows OS, including Windows 7. By burning a bootable CD/DVD or USB flash drive, you can easily regain to computer again.
Here are the steps to remove Windows 7 password with Windows Login Recovery Professional:
Step 1: Download Windows Login Recovery Professional and install it in any computer.
Step 2: Run the program and burn an ISO image file into the blank CD/DVD or USB flash drive.
Step 3: Start your locked computer from the bootable CD/DVD or USB flash drive.
Step 4: Remove Windows 7 password by following the instructions.
And now you can access to your computer without password. And you can easily remove or change Windows 7 password according to the steps in solution 1.
Of course, you can also change Windows 7 password if you have a password reset disk in advance. If you don't know how to create one, You could follow the guide of Microsoft's official website.
on Oct 14, 2010 | Computers & Internet
No sign of life to our 5 year old D/W except flashing "CLEAN" L.E.D.
7-1 heating circuit problem control programmed to shut down machine when no rise in water temp during heat cycle, you either have an open heating element or wire burnt a shorted thermistor or a bad control not outputing 120VAC to the heater you can reset the control by placing the machine into diagnostic hit cancel button to turn off all the lights press heated dry-normal, heated dry- normal within 6 seconds lights should come on press cancel unit should start it will run till same part of cycle reached and lock out again if it has not been removed the little black panel below the door remove should have the tech sheet in a plastic pouch which explains how to check the components mentioned earlier,
Apr 03, 2014 | Whirlpool GU2800XTV Dishwasher
How to remove write protection of usb flash drive for windows 7?
click start click to open on my computer you should see your usb drive E: right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
click start right click on my computer select open
Right click the icon of your usb drive (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
hope this helps you
Feb 25, 2012 | Electronics - Others
Television does't come on, the lights on the control panel flash.
buy a new bulb. they don't come cheap and you'll have to go online for it
Dec 30, 2011 | Philips Magnavox 51MP392H Rear Projection...
The panel is stuck on pots/pans for cleaning and wont let me run the dishwasher. the pots/pans light keeps flashing
To reset the dishwasher push in this order the,
HIGH TEMP WASH- HEATED DRY- HIGH TEMP WASH- HEATED DRY - CANCEL/OFF
the control will be reset...but more importantly how many times in a row does the light flash..it will indicate what error code its displaying??
example if it flashes 4 times then a pause then flashes 4 times again its displaying the error code#4
7 flashes then pause then 7 flashes its displaying the error code#7 ect ect
GENE
Sep 06, 2011 | Whirlpool 24 in. DU1055XTPS Stainless...
Flashing f 7
Hi
Thanks for using FixYa. Error F7 means that the control panel has gone bad and should be replaced with a new one. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 03, 2010 | GE JRP15 Electric Single Oven
''clean'' light flashing (whirlpool Dishwasher GU2300XTLS1 model)
I had the same problem recently and a repair person came to my home to fix the dishwasher. He said he had to reset the control panel. He did this simply by making sure the soap dispenser door inside the washer was closed, then making sure the main dishwasher door was closed and locked. Then he quickly pushed the Heated Dry button and the Hight Temp wash button alternately. He said each button needed to be pushed twice within five seconds. After he did this all the lights on the control panel came on, then turned themselves off before the washer went in to a test cycle. This simple reset fixed the whole problem. Works great so far.
Mar 26, 2009 | Dishwashers
Electronics - Others Logo
23 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
