Question about RCA Office Equipment & Supplies
How can I get a manual for my RCA Table #RCT6873W42? I don't have a printer to print one of the computer
    Top Expert:
  • RCA Master
  • 77,947 Answers
Then you are out of luck.
Posted on May 18, 2017
How to update the RCA voyager7 inch to Android Nougat no root.
Go on YouTube there is information about that.
Mar 28, 2017 | Tablets & eReaders
Several tips for your printer troubleshooting
<span style="font-weight: bold;">The Paper Jam</span><br /><br />We have all had this one happen. You are printing merrilyaway when all of a sudden you hear that distinctive crunch of paper gettingeaten by your printer. You immediately cancel the print job, leap from yourdesk and flip open the printer. "Ugh," you say as you notice the crinkled edgesof paper wrapped around god knows what. Okay, so you have found the problem,but what do you do?<br /><br />The best way to remove a paper jam is to gently pull thepaper in the direction of the paper path-with power off, of course. Whateveryou do, don not pull the paper backwards. You could damage your printer foreverby doing so!<br /><br /><br /><span style="font-weight: bold;">The Missing Driver</span><br /><br />This is another common problem. You are all geared up andready to print but your computer can not find the right driver to "talk to" theprinter. Why is this? Not all drivers are pre-installed on all operating systemsand as new operating systems are released, you will need to install driversyourself. Consult your printer manual. You can also most likely find thecorrect driver online at the printer manufacturer's website. If not though, asimple web search should help you find what you are looking for. Tryingsearching for your printer manufacturer, the model and "printer driver."<br /><br /><br /><span style="font-weight: bold;">The Printer Picks Up All the Paper</span><br /><br />This is a frustrating one. You are trying to print outsomething and the printer feeds in the whole paper stack rather than just onepiece at a time. For starters, make sure you fan the paper edge before puttingit in the printer feed tray. This helps separate the sheets. Also, be sure tostore your paper in a cool, dry place as humidity can contribute to this peskyproblem.<br /><br /><br /><span style="font-weight: bold;">The Blank Page Syndrome</span><br /><br />So you have just installed a new printer ink cartridge andyou print a document only to see a blank page come out. Aggravating, no? Butthis usually has a simple solution. Make sure you completely removed thatlittle sticker from the ink cartridge before installing it. If it is removed,run the clean print head function on your printer to make sure all air bubblesare removed. Just whatever you do, don not remove the cartridge once it is beeninstalled!<br /><br /><br /><span style="font-weight: bold;">The Color and Print Quality is Diminished</span><br /><br />This usually happens when one ink well is running low. Ifall of your images start to look a bit purple, blue or orangish, this may beyour problem. The usual solution for this problem is to replace the wholeprinter ink cartridge, unless you can refill the individual ink wells.<br /><br /><br /><br /><span style="font-weight: bold;">The Smudgy Printout</span><br /><br />This happens a lot when you print out pages with a lot ofimages with bright, vibrant colors. The cause is usually having the wrong papersetting selected. If you are printing text documents, don not print at thehighest quality. And if you are printing on photo paper, make sure you don notuse the regular printer setting.<br /><br /><br /><span style="font-weight: bold;">The Computer Won not Talk to the Printer</span><br /><br />Once you rule out that it is not a printer driver issue,check to make sure you are using the right cables to connect everything. Onceyou confirm everything is connected properly, read your printer manual and yourcomputer manual-at least the part that pertains to printing. Older printersmade for Macs may need a serial cable to work while PC printers an IEEE 1248cable.<br /><br /><br /><span style="font-weight: bold;">The Blinking Light</span><br /><br />While there is no surefire answer to this problem, it is acommon enough one that it should be included. Each printer has a differentreason for its dreaded blinking or orange light but some general reasonsinclude a paper jam, a printer cartridge problem or a problem with the printerhardware. It could also be an indicator that the computer is not talking to theprinter. Check your printer manual to see what specific light errors mean foryour model.<br /><br /><br /><span style="font-weight: bold;">The Printout Looks Misaligned</span><br /><br />Problems with alignment have a lot to do with maintainingproper print head alignment. You can run a simple diagnostic to fix thisproblem. If the ink seems to be going onto the paper improperly or you noticeuneven coverage, try aligning the print heads before you bring out the bigguns.<br /><br /><br /><span style="font-weight: bold;">The Printout Looks Grainy</span><br /><br />This may have nothing to do with the printer at all. In factit may have more to do with the quality of images you are using than the printer@squality. Make sure that when you print photos that they are of print quality,meaning 300dpi. Anything lower than this will appear pixilated and lower thanphoto quality.
on May 09, 2011 | Office Equipment & Supplies
I am needing a manual for rca voyager 7 16gb tablet with keyboard Any idea where to find one?
There is only one page for the RCA Voyager at . The manual is available on that product site: . Scroll down and look for the Download the Manual button. The direct link to the manual is . The model given in the manual and the site is RCT6873W42. This model has 1 GB of internal memory for running apps and 16 GB of storage and the Marshmallow (Android 6.0 OS).
The manuals for other RCA tablets are available here: . Manuals Lib may also have the manual. Please add a comment with the model number and/or Android version to get a manual for your specific manual if the above links don't help.
I hope this helps.
Jan 10, 2017 | Tablets & eReaders
A friend gave me her HP psc 2210 AIO. She did not have the owner's manual. I have it hooked up. It turns on, but won't print. I need the operating instructions to get it going. I have a newsletter...
Hi Peggy,
Have you already installed the printer driver to your computer? This is one of the first things you should do when installing the printer aside from hooking it up to your PC. If you don't have the driver don't worry because you may download it by clicking on this link. Then follow the steps below:
1. Select your operating system (ex. Windows XP) then hit on Next.
2. Afterwards select Driver Product Installation Software.
3. Then hit on Download.
4. Once driver is downloaded, install it .
5. Lastly, restart your computer.
For your instruction manual download it from here.
Hope this helps.
Thank you for using FixYa.
Oct 23, 2011 | Office Equipment & Supplies
I have a hp officejet multifuntion v40xi printer. How do I make it print? There are no print buttons. There are only scan, copy, and fax buttons.
You don't start a print from the printer. The program you're printing from (Word, your e-mail program, Adobe Reader, etc.) sends the print job to the printer and the printer automatically begins printing. Those other buttons are there so you can manually start the operations that need your control.
You'll need to make sure the proper driver software is installed on your computer so your operating system will be able to use the printer. You can find those drivers at HP's website. Pick your operating system from the drop-down menu and you'll find the appropriate software. You can also download the manual and find other information at the site.
Aug 23, 2011 | HP WanProbe V-Series Network Monitoring...
When I print a one page document, tray 1 prints on multiple papers at a time. 1 page prints on 5 pages.
If you don't have a manual, you can find one here
My guess is either on the printer or the driver. Skimming the manual, it doesn't seem that you can set the default number of pages printed per sent print job on the printer, but that is something I would look into. This is a nice office printer, perhaps the printer is set to print multiple copies of everything it is sent. You could determine if it is the printer or driver/computer by printing to it from another computer.
If it is the computer, go into the control panel and select the properties for this printer. In there, check if the number of copies is improperly set to 5. This would happen for every print job sent from this system.
Does it print 5 copies of documents sent from different programs (i.e. Web Page, Word, Excel)? Quite possibly, one time you set it to print 5 copies and that application retained that as default. In that application, rather than clicking "print" click "printer setup" and look through the settings to see if it is requesting multiple copies.
I am 95% sure one of these three solutions will solve your problem.
May 05, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
We have a Laserjet P2050dn that is experiencing a problem with printing. If you print out an excel document titled 'ABC invoice', the 2050 will print the invoice. If you then print another document...
Clear the pending jobs on print spooler
Choose RUN
Type the letter "cmd"
Type the word "net stop spooler"
Go to C drive
Choose to Windows Folder
Click show content
Choose system32 folder
Choose spool folder
Choose printer
And delete all printing jobs pending
Again go back to CMD window and type the word "net start spooler"
Restart your computer also turn off your printer and switch it on.
It will work fine right now
I hope it helps you
Mar 21, 2011 | HP Office Equipment & Supplies
Table Mismatch Download Again
This is the only Solution to "Table Mismatch"...
If a “Table Mismatch” is displayed, recycle power and reflash the printer. Can get “Table Mismatch” after replacing CMX Board.
“Table Mismatch”
Flash Upgrade Instructions Using the printer’s Parallel Port: You have ethernet, you can FTP download.
1. Print a configuration on the printer prior to the download. After the flash is upgraded, the printer will be at Factory settings and you will need this printout to restore any non- default settings.
2. The PTX flash code is on a CD you should have received with printer. Don’t have? I can email you the Flash program.
3. Turn the printer's power off.
4. If there is a cable connected to the printer’s serial port, disconnect it.
5. Connect a cable from the LPT1 port on a PC that has a DOS prompt mode to the printer’s parallel port.
6. While holding down the Online & FF(Paper Advance) keys, power up the printer. The printer will display "Waiting for Program Download".
7. At the PC’s DOS prompt, go to the directory where the file is located C:\Temp and
type "filename.exe -pb<ENTER>" where filename is the name of the file that you downloaded in step 2.
NOTE: there is a space before the -pb
8. The printer's display will keep you informed of the status of the download. When the download is complete, cycle the printer’s power.
May 15, 2008 | Printronix Line Matrix P5215 Printer
Print job will not print from the manually feed tray unless I select the Go button for it to process
Table 3-7. Paper Handling Menu
Item Values Explanation
For supported paper sizes
see page 1-12.
This item appears only when the
optional envelope feeder is installed.
Set the value to correspond with the
envelope size currently loaded in the
envelope feeder.
For supported paper types
see page 1-12.
envelope type currently loaded in the
envelope feeder.
Determine how the printer will use
Tray 1.
FIRST: If paper is loaded in Tray 1,
the printer will pull paper from that
tray first.
CASSETTE: A paper size must be
assigned to Tray 1 using the
TRAY 1 SIZE option (the next item
in this menu when TRAY 1
MODE=CASSETTE). This allows Tray 1
to be used as a reserved tray.
see page 1-12.
This item appears only when TRAY 1
MODE= CASSETTE. Set the value to
correspond with the paper size
Mar 12, 2008 | HP LaserJet 4350 Printer
Top RCA Office Equipment & Supplies Experts
ray gallant
Are you a RCA Office Equipment and Supply Expert? Answer questions, earn points and help others
