Question about Water Garden
What is the ratio break down if 3pints of water for 20 pounds of mix
2 Suggested Answers
  • 1169 Answers
SOURCE: What is the correct gas mix ratio for a Homelite Pro 20" model #4620C 46cc
I was able to do a little more research on some other forums and it appear that you have the UT10520 saw with .325 pitch chain. Please note that even though the following attached owners manual specify 5/32 round file for sharping the .325 pitch chain needs the 3/16 round file instead.
As fuel amount of fuel oil atp1962 is right but I would suggest using a good pro mix oil that can be use in nearly all of your 2 cycle without weary of an incorrect mix. This is a multi-mix oil that can use in any 2 cycle that requires any fuel mix from 16:1 to 50:1. It comes in pre-measured mix bottles or packets for use in either 1 gallon or 2-1/2 gallon of gasoline depending which size you use.
http://manuals.homelite.com/system/files/3472/original/UT10517_18_20_210_eng.pdf?2011
Posted on Dec 31, 2014
If direction for plant food mix calls for 15ml per 4 liters of water,what mix ratio for a 1650ml watering can?
1650 ml = 1.650 ltrs
the ratio of 15 to 4000ml(4ltrs) =3 : .0800 ml
8 : 1650 is the ratio
Jul 29, 2017 | Garden
Tip
Freeing a siezed bolt
1.File a flat on each side and grip the bolt with a pair of mole grips 2 Give the bolt a sharp tap with a hammer or punch set the punch at 45 degrees pointing outwards and give it a few taps.
3. try soaking the bolt with penatraing fluid see my comments below.
A Workshop magazine actually tested penetrants for break out torque on rusted nuts.
Significant results! They are below, as forwarded by an ex-student and professional machinist,
They arranged a subjective test of all the popular penetrants with the control being the torque
required to remove the nut from a "scientifically rusted" environment.
*Penetrating oil ..... Average load*
None ..................... 516 pounds
WD-40 .................. 238 pounds
PB Blaster ............. 214 pounds
Liquid Wrench ..... 127 pounds
Kano Kroil ............ 106 pounds
ATF-Acetone mix....53 pounds
The ATF-Acetone mix was a "home brew" mix of 50 - 50 automatic transmission fluid and acetone.
Note the "home brew" was better than any commercial product in this one particular test. Our local
machinist group mixed up a batch and we all now use it with equally good results. Note also that
"Liquid Wrench" is about as good as "Kroil" for about 20% of the price.
Good Luck,
Crofter
on May 01, 2015 | Motorcycles
Tip
Penatrating oils
A popular magazine actually tested penetrants for break out torque on rusted nuts.
They arranged a subjective test of all the popular penetrants with the control being the torque required to remove the nut from a "scientifically rusted" environment.
Note the "home brew" was better than any commercial product in this one particular test. Our local machinist group mixed up a batch and we all now use it with equally good results. Note also that
"Liquid Wrench" is about as good as "Kroil" for about 20% of the price. "
on Apr 30, 2015 | Chevrolet bolt. generator mounting. intake...
Where can you find the mixing ratio for the product being used?
you did not state what paint and what gun and what pressure - telepathy is overrated and works only in the movies...
if you use two pack mix - on the package is clearly stated how much part 'a" and how much part "b" should be used, you can then add up to 20% of thinners if allowed in particular paint.
you need to pay attention if mix is by weight or by volume, light paints are usually by volume,
paint should be rather light oil to water consistency in low pressure guns, if gun nozzle is below 0.8mm strainer must be used (190micron is ok) above that you can use your old pantyhose to strain paint after mixing.
hope this will help you at least a bit...
Oct 26, 2014 | 3M Mix Ratio Insert,pk100 - 3M
How do I find the ratio of a statue made from a mixture of copper and zinc? It is a ratio of 11:4
11 parts copper and 4 parts zinc for a total of 15 parts.
Thus 11/15 copper and 4/11 zinc.
11/15 of 75 pounds is 55 pounds. 4/15 of 75 pounds is 20 pounds.
Hence 55 pounds of copper and 20 pounds of zinc.
However, if you really want to know the ratio of the statue, then it's given in the problem as 11:4.
Oct 06, 2014 | Cars & Trucks
How to remove stripped bolt
Hi Anonymous, it all depends on the size and location. That being said I would take your bike to your local dealer or reputable shop and they will be happy to remove it for a small fee. Good luck
Mar 29, 2014 | 2004 Harley Davidson XL 1200 R Sporster...
I need to acid wash my grids. What is the ratio for acid and water?
Why not try white vinegar and water first, 50/50 mix. White vinegar is a mild acid, and it is a lot safer to use than acid. If you are going to use Muriatic acid ( "mild" version of Hydrochloric acid), then a good ratio is 1 part acid to 20 parts water. And Always add the acid to the water. You could make a stronger solution, 1part acid to 10 parts water, if needed. But be cautious with any ratio. Follow container directions. Wear eye protection ( an absolute must). Wear gloves, etc. This is dangerous stuff, and you can buy it at Home Depot or Lowes!
Aug 25, 2009 | Pentair FILTER TANK BOTTOM, 48 SQFT
Garden Logo
15 people viewed this question
Top Water Garden Experts
ray gallant
Joseph Coppeto
Joseph Coppeto
Don Eagan
Are you a Water Garden Expert? Answer questions, earn points and help others
