Question about The Office Equipment & Supplies
Just pressed the start button on my scan and cut and the screen has come up half grey and white
At times I have to push the start button several times before it turns on. What's wrong?
your start button might stick or it just wont work I suggest taking it to the place called ( i think peach mac) they fix stuff like that and getting them to look at it
Jul 10, 2014 | Apple iPhone4 4G iPhone 4
White screen
Do you always shut down and unplug the laptop when not in use? Has it been cleaned recently? Fan, Vents, heatsink? Has there been ANY damage? It sounds like your Graphics Adapter. screen, Inverter, is going? Have to say exactly. Does the Laptop Overheat?
May 12, 2013 | Dell Inspiron 1545 Notebook
Lexmark x6180 Printer. Unable able to Scan. I turned on my printed and selected "Scan" button, located with two other buttons ("Copy" and "Fax" under the section titled...
On the printer operator panel, press Black to begin a black and white scan or Color to begin a color scan. You can rename the file only on your computer once the scanned file is displayed.
Jun 19, 2011 | Lexmark X6180 Printer
Black screen ecept for thin white line around all four side. Channel buton changes colors in various section of screen. On/ off button does not work
I found the solution on mine. To restate, I just saw a thin white border around a black screen. Pressing the channel up or down buttons changed the screen, in some kind of test mode to shades of gray, and red, green, and blue. I started finding a solution when I noticed when on one of the color screens, that the volume up or down buttons brought up a new menu for color intensity. Finally, I got back to the thin white border screen and pressed the arrow keys in the top half of the remote. Finally a TV screen and I pressed the enter key! Voila!
Mar 14, 2010 | Sylvania LC320SLX 32 in. LCD TV
Canon DR-3080 CII scans only half or right side of document
Try all formats, Color, Grey & Black & white. If you have problem it could be the scan module. Check for loose contacts, but this is rare in a working machine.
S. Mohan
Oct 02, 2009 | Canon Office Equipment & Supplies
Scan feature greyed out on Toshiba eStudio 232
You have to have the USB stick to enable the scan.
It locates on the right side near the back of the machine.
They make , print dongles, Scan dongles and print scan dongles. But that USB device enables scan.
May 04, 2009 | Toshiba e-Studio 232 Black and White...
NEC Dterm 80 calls won't go to voice mail
for us i just found this out.
1.Fwd B/NA
2.1 - 1:set-0:cancel
after 4 rings it goes to voicemail
this works for us.
i hope it works for others too.
turn this feature off
1.hit fwd b/na
should see the normal display then.
Jul 17, 2008 | NEC Dterm DTP 16D-1 Corded Phone
Can't scan or copy...looks all fuzzy
When you say fuzzy, do you mean that you are getting cast or moire? try this and keep me updated on the result
If you are seeing a grey cast to all stand alone copies made with the CX7800 please try the following:
1. Select the SETUP UTILITIES button on the CX7800
2. Press the RIGHT arrow (photo options) button until you have an option for copy quality then press the START button.
3. Use the UP or DOWN arrow (copies) buttons to select the desired copy quality you want then press the START button again.
Now press the copy button and select the START button. Pls rate as fixya if it resolve it, and if you need anything else pls inform me. Thanks!!
Jun 12, 2008 | Epson Stylus CX7800 All-In-One InkJet...
18 people viewed this question
Top The Office Equipment & Supplies Experts
Ian White
Level 1 Expert
Level 1 Expert
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
