Question about LG Televison & Video
LG 23LN5758 does not start -- blinks 3 times
The TV shut off during operation. The SMPS was broken. I renewed the broken FET, the switching regulator IC and the gate resistor. the PSU seems to be fine. When I apply mains the TV blinks 3 times. Nothing else happens. There is no backlight, no audio, nothing else than the LED and the IR receiver seem to work. Any ideas what else I can do? By the way all caps are at at least 90% capacitance and there are no short-circuits in the mainboards power in connector. I am experienced professional audio electronics engineer but here I have no clue.... Best regards Stefan
3 Suggested Answers
herminio_hal
  • 210 Answers
SOURCE: MSI N 1996 MOTHERBORD DO NOT START SMPS OK
Hi this might not be a motherboard problem. Remove the memory card and clean the contacts and reinstall it. If this will not work for you replace the memory card with the same type you have in your computer. Hope this info will help you solve the problem
Posted on Aug 17, 2009
gopakumarg43
  • 75471 Answers
SOURCE: Backlight of LED TV blink and instantly off , what reason will be in backlight circuit ? LED driver IC or FET or in power supply ?
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Posted on May 18, 2016
My 2007 41" plasma Panasonic viera is shutting it's self off after running for and hour or so and the stand by light starts flashing
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here.
Nov 13, 2015 | Panasonic Televison & Video
Why won't it start and, conversely, why does it shut down while operating?
Oct 23, 2015 | Sony Televison & Video
When I press the power button to turn on my LG flat screen TV, it blinks red and green several times, then it comes on.
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Sep 30, 2014 | LG Televison & Video
The power light comes on for a second then goes off. you have to plug and unplug at the mains for it to do this, this problem started after turning the house power on and of
sounds likt the tv got fried from power surge! you might need a new tv, if you have home owners insurance or renters, file a claim
Dec 23, 2010 | LG 32LX1D 32 in. LCD Television
Hi, i have here a mitsubishi WD-57733. once the unit is switch ON, green LED light and a few seconds the status LED light then shuts off. I think light engines good since i just replaced a new lamp.
hello i've just checked the manual for here is some information
None TV is powered off. Normal operation.
Green TV is powered on. Normal operation.
Green 1. TV just plugged into AC outlet.
Wait until blinking stops before turning on (approximately 1
minute). Normal operation.
2. AC just restored after power failure.
3. TV Rebooting after System Reset was
used.
4. TV Rebooting after power fluctuation
or receiving abnormal digital signals
from digital channel, or digital device.
5. You have begun the procedure to
update software from an authorized
flash memory device.
For detailed information, see the instructions that accompany
the authorized software update. IMPORTANT: Do not
use unauthorized software at any time.
Green TV just powered off and lamp is
cooling.
Starts to blink 30 seconds after turning off TV. TV can be turned
on before blinking starts or after blinking stops, but not while the
indicator is blinking. Normal operation. hope it helps regards shaun
Green TV powered off and auto-on timer is set. Normal operation. TV can be turned on at any time.
Dec 06, 2010 | Mitsubishi Televison & Video
VisionQuest Van gogh Plasma 32''. The standby light shut down. No power on has possible. I check the 3 fuses inside the TV and all is good. Someone know what is the problem !!!! Tks
Good day sir, your tv or any new tv are now using SMPS or technically called switch mode power supply, a regulator mode that is more efficient than traditional power supply, the down side is that its prone to defects, there are three main parts the Switching element which is the transistor, the oscillator circuit which is usually an IC that controls the frequency of oscillation and the high freqency power transformer that works with the switching transistor. All of these parts are need to be checked to ensure proper operations. SMPS also detects overload, which is caused by faulty parts on your tv, unless that faulty part is not found, it will not start and go on standby mode, worst will always shuts down. Call your dealer on how to go about your tv problem or have it check by a qualified technician.
Nov 03, 2009 | Televison & Video
EHT PROBLAM
EHT Problemsymptems :1.If U find R457 - 33k,R452 -1k,R458 - 10k Resisters are Burnt In Zenith 14"and15" monitors To replaced all thease resisters and LOT FSN14B016S
2.HCL HCM 482M, 580M,582M, 780M models getting FAT - FAT sound coms from LOT when u switch on the monitor It's LOT Problem . replaced it
3.Samtron Samsung Models like 45Bn, 55V,56V when u switched on the monitor Power indicator (Led )glow one time First u can check Boosting FET IRF630 bitween (SMPS O/P to LOT supply) and also replace LOT.
4.some Old Gold star anlog and LG monitors If U found 12k Resister near by LOT and also bulched 1Mfd/63V capacitor
It's LOT Problem
Oct 04, 2008 | Computers & Internet
Panasonic Th37PE30 Viera plasma stopped working
here is a complete list of all codes for panasonic tv's rgeardless of model if its panasonic it is these codes
1 Blink SOS: This shutdown operation is usually caused by a lack of communication between the A and the D boards.
1 Blink SOS: This shutdown operation may be caused by the improper connection of a SS board connector to the panel.
2 Blinks SOS: Pin 87 of the MPU IC9003 monitors the 15V line. During normal operation, the transistors Q9053 and Q9054 output a high to pin 87. If the 15V line is missing or shorted, a low is provided to pin 87. As a result, the unit shuts down and the power LED blinks 2 times.
3 Blinks SOS: IC9807 is a 3.3V regulator located on the D board. Its output is monitored by IC9003. If the 3.3V is not present at pin 86, the MPU shuts down the unit. The power LED blinks 3 times.
5 Blinks SOS: Pin 85 of the MPU IC9003 monitors the 5V line. During normal operation, the transistors Q9051 and Q9052 output a high to pin 85. If the 5V line is missing or shorted, a low is provided to pin 85. As a result, the unit shuts down and the power LED blinks 5 times.
6 Blinks SOS: Pin 90 of the MPU IC9003 monitors the status of the SC board. During normal operation, the transistor Q6581 and IC6581 output a low to pin 90. If the SC board becomes defective, a high is provided to pin 90. As a result, the unit shuts down and the power LED blinks 6
6 Blinks SOS: 6 blinks of the power LED may also be obtained from pin 3 of IC9003, the DRV_RESET input. The D board provides the 5V source needed to power the C boards. On the C2 board, the 5V is routed back to the D board via connector C20/C10, C11/D31 causing pin 3 of IC9003 to be high. If 5V is not routed back to the D board, pin 3 of IC9003 goes low. The set goes into shutdown mode and the power LED emits 6 blinks.
7 Blinks SOS: Pin 93 of the MPU IC9003 monitors the status of the SC, SU, SD board. During normal operation, the photo-coupler PC6480 outputs a low to pin 93. If the SC, SU, or SD board becomes defective, a high is provided to pin 93. As a result, the unit shuts down and the power LED blinks 7 times.
8 Blinks SOS: Pin 91 of the MPU IC9003 monitors the status of the SS board. During normal operation, pin 8 of connector SS23 outputs a low to pin 91. If the SS board becomes defective, a high is provided to pin 91. As a result, the unit shuts down and the power LED blinks 8 times.
10 Blinks SOS: The SUB5V and DT9V sources created on the A board are monitored by IC1100. If they are not present at pin 30 and 34, the MPU shuts down the unit. The power LED blinks 10 times.
10 Blinks SOS: The F_STB_15V of the P board, as well as the derived SUB5V and DT9V sources are monitored on the A board for excessive current. If a short circuit is developed in one of the supplied lines, pin 114 of IC1100 receives a high. The SUB5V and DT9V lines are also monitored for excessive voltage. When an over-voltage condition is detected, a high is also output to pin 114 of IC1100. The DT9V is provided to a DC/DC converter to create the BT30V for the tuner. If the BT30V becomes excessive, a high is output to pin 114 of IC1100. A high at pin 114 of IC1100 causes the unit to shutdown and the power LED to blink 10 times.
Feb 26, 2008 | Televison & Video
Panasonic Plasma TH-42PZ77U Power Light Flashing 7x
Dec 31, 2007 | Televison & Video
Televison & Video Logo
23 people viewed this question
Computer Repairing
Computer Repairing
