Question about Hitachi Televison & Video
Hitachi LE55A6R9 dim screen
I have replaced the power board, but screen still extremely dim. How do we test to see if it's the led strips? Thanks!
  • 87 Answers
SOURCE: Hitachi 50UX26B no picture no sound
Because D953 and D954 go dim right away indicates a short in th +27v and -27v line. The most likely suspects are IK04, IK05 (convergence output IC1s). The other suspect is I601(vertical output chip)
Posted on Dec 05, 2007
  • 3 Answers
SOURCE: Rear LED strip light not working
hi I have got the same problem , did you find a solution, i would appreciate some info. model is 2005 continental GT
Posted on Feb 01, 2010
  • 973 Answers
SOURCE: The LED display on my GE JTP56 electric wall oven
It sounds like a defective Control Board, return it or exchange it for another one.
Posted on Jun 13, 2010
leecom72
  • 4806 Answers
SOURCE: I want to test an ecs rs 482-m mother board. Where
The power, hdd led and reset switch pins are at the bottom right hand corner of the motherboard near the BIOS battery.
The connections are fairly easy to plug up to but not knowing what case you have or the connector plugs i'm going to give you a link to download the manual for this motherboard.
Just click on the link below and when the page has loaded up click on the "Downloads" tab and download the manual. The information you need is in section 12 under the header "Front Panel Connector"
Link here >>>>>
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?CategoryID=1&DetailID=536&DetailName=Feature&MenuID=24&LanID=0
Regards.
Posted on Jun 29, 2010
Testimonial: "Thanks a lot."
gopakumarg43
  • 75599 Answers
SOURCE: KDL55HX800 dims and then shuts off and red LED blinks 6 times
IIC bus clock and/or data lines low at power on 06
Posted on Aug 28, 2012
Hitachi LE55A6R9A has sound but no picture. Passes flashlight test. No LED backlights appear visible at all. Trying to determine whether to start replacing boards or LED strips first.
The led driver may be on the main board or on it's own board. Led strips don't fail all at once so if you had a dark area of the picture then I'd suspect a led strip. TV Parts Universal TV Stands DLP Chips ShopJimmy This is the place to get parts.
Feb 13, 2018 | Hitachi Televison & Video
UN60JS8000 Faulty Power Board or LED Strips?
It may take a little doing but if you could reverse the 2 wires that have the voltage on them and see if the top half is dark and bottom good, that would tell if its the power supply or panel LED's and yes opening up the panel isn't fun and if extreme care isn't taken the panel can be destroyed then the set is garbage.
Nov 12, 2017 | Televison & Video
My Hitachi tv will not turn on
My Hitachi used to eat Horizontal output transitors. I do not even know if your uinit has that anymore, but if that goes out the unit wont make the B+ voltage needed to power up the unit.
Sep 19, 2017 | Hitachi Televison & Video
I have an LG 47LN522-UB LED TV that stopped working after three years and need help diagnosing a problem with it.
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Apr 26, 2017 | LG Televison & Video
Hitachi le55a6r9a has audio but no picture. When you shine a flashlight on the scree, you can see a dark image. Which piece needs to be replaced?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Feb 07, 2017 | Hitachi Televison & Video
The TV leds arent working
it should be relatively easy to test if you can get at the back of the LED board first Identify if they are series or parallel wired if they are series, if parallel wired there is full voltage across them all and a single burnt out led isn't the issue ( a burned trace could be depending on location). HOWEVER, the most likely problem is the LED driver, as this varies the brightness of the leds in relationship to the brightness setting of the TV. this is usually a part of another circuit.
Apr 03, 2016 | Hitachi Televison & Video
Televison & Video Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
