SOURCE: TV does not power on the red light comes on but
the base of the tv turns on but the actual tv is not showong any picture and the green light is not turning on in the tv panel ??? tried disconnecting switching the cables checking them and nothing ??
SOURCE: When you plug in the tredmill it usually beeps
There is a wire going from the right support post to a connector behind a small door underneath the console. Remove the door and make sure that the connector is properly plugged into the slot. It has probably worked loose due to vibration.
SOURCE: my fridgedaire window unit A/C and heat won't
Plug a light into the outlet used for the A/C, if the light does not come on when reset then the circuit breaker that provided the power to the outlet need to be reset or replaced.
Testimonial: "Thank you. I had pretty much come to that conclusion. I think It may be a faulty outlet or circuit breaker, like you said. Thanks for the advice!"
Must have to take the tv aparts,check the tv power supply board carefully.That the board where the tv a/c power cord plug into it.Look for dying and leakages capacitors components parts.These dying and leakages capacitors parts are causes this problems 90-95% of the times.These dying and leakages capacitors components parts are alway bulges up and or puffing up onto it tops.It dosen't supose to have a flat tops as those are good capacitors components parts that are alway have flats and even cyclinder head tops.If u have all the tools and know basic electronic and also u can do basic soldering work too than u must have to changes all these dying and leakages capacitors components parts that are bulges ups or puffing ups on to it cyclinders tops,will solved this tv problems LED power liight inconsistance staying on power LED light indicaton flashes.If u can't do soldering works on an a electronic board components levels works.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv power supply board for the replacement.
Hi Marilyn Kearns, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Please share the year (?) , make, and model of your Television.
I'm sorry, I thought this was the sight for Keurig coffee machines! I don't know if you can help me with that! It's brand new!
