Question about Saitek Maestro Travel Chess Computer
My Maesstro Computer stopped accepting touches. I had to take out a battery to reset it but its still dead. The options work but not the playing. Problem started yesterday when in the middle of a game I couldn't untouch a blinking pond.
Kobo ereader problems
Unfortunately, the batteries on Kobo were not designed to be replaced. If the batteries will no longer accept a charge, it is time for a new e-reader.
Aug 14, 2014 | Kobo 6" eReader Touch Edition
Why did my zen mozaic suddenly stop working?
Either the switch is broken or the battery is dead.
Jul 28, 2014 | Creative Technology ZEN Mozaic EZ300 MP3...
My laptop won`t charge unless it`s dead and in an outlet I have not used yet with my laptop
Go to control panel, click on Pen and Touch and follow the instructions. Click on the battery icon, you will see your power options, check on each one to set your power options, I suggest you set it to battery saving mode or any mode you prefer.
Nov 07, 2013 | ASUS Computers & Internet
Bought a Nikon Coolpix S3000 (orange) for my daughter after Christmas. It just stopped working one day; wouldn't charge, no lights or come on. The battery it came with is a Nikon lithium ION Battery...
Read page 16 of the manual. Do not use any other charger with this camera. Are you sure you have the battery inserted correctly? When trying to charge, does the green light blink? If so, when it stops blinking and turns off, the battery should be fully charged. Do not attempt to turn the camera on while the charger is trying to charge the battery.
Aug 17, 2011 | Nikon Coolpix S3000 Digital Camera
It is cutting out when I stop at road signs or lights. It is fine when I press on the gas but as soon as I take my foot off it cuts out
THE IDLE SPEED COULD BE LOW.CLOGGEG FUEL FILTER. FAULTY FUEL INJECTOR.BAD PLUGS AND WIRES.YOU COULD HAVE A INTAKE MANIFOLD LEAK.
Oct 26, 2009 | 1998 Mitsubishi Montero Sport
I cant open my computer my password does not accepted
Open Computer and take out oversized watch battery. Count to ten and put it back in. Close computer - Don't touch anything else!! Start computer. Should let you reset from there.
Oct 01, 2009 | Computers & Internet
Creative zen stone plus wont turn on
the battery is dead use a car charger it worked on my creative zen stone plus and ipod touch. the car should charge it
Jun 10, 2009 | Creative Labs Zen Stone Plus MP3 Player
Creative zen v problems-frozen
If a reset does not work using the reset hole, then try this: First, back up all of your music and do this: Turn off the player and disconnect it from the computer. Then press and hold the play/puse button and turn it on simultaneously. The player should be in recovery mode. Scroll down and select format (all) and let it format. Then reload all of music back onto your player and it should work like new. Hope this helps!
Aug 25, 2008 | Creative Labs ZEN V Plus MP3 Player
My 30G 5th Generation pod is totally dead and will not charge even with a new battery
  1. Toggle the Hold switch. To do this, slide the switch to Hold (an orange bar appears) and then slide it back (orange bar is hidden).
  2. Reset the iPod by holding down the Menu and Center buttons for 10 seconds.
    If the Apple logo appears on the display, connect the iPod to a computer and verify that it appears in iTunes and can play music. If the iPod appears in iTunes and can play music, no further troubleshooting is needed.
    If the Apple logo does not appear or the iPod is not seen in iTunes, connect the iPod to a power source by either plugging it into an Apple iPod USB Power Adapter or directly into a computer's USB port.
  3. Let the iPod charge for at least 20 minutes. Note: If the iPod is connected to a computer, make sure the computer is not set to sleep, standby, or hibernate.
  4. After the iPod has charged for at least 20 minutes and while it is still connected to the power source, toggle the Hold switch again as in step 1.
  5. Try resetting the iPod by holding down the Menu and Center buttons for 10 seconds.
    If the Apple logo does not appear or the iPod is not seen in iTunes, the iPod should be serviced.
Nov 22, 2007 | Apple iPod MA446LL/A MP3 Player
My touchscreen does not sense touch anymore?
You could replace the battery by going to the A/V store that you bought it from or you could just use a light cloth like that for cleaning glasses and gently wipe the screen. sounds more like the battery or the programming though
Dec 11, 2006 | Universal Remote Control MX-3000 LCD...
Saitek Maestro Travel Chess Computer Logo
44 people viewed this question
Top Saitek Games Experts
Lesley Cameron
Lesley Cameron
Are you a Saitek Game Expert? Answer questions, earn points and help others
