Question about Garden
I bought a Berkley and Jensen Lighted waterfall fountain. It is missing the 2 bottom LED lights. How can I get them
    Top Expert:
  • Garden Master
  • 44,949 Answers
Refer this issue to BJs.
Posted on May 18, 2017
2 Suggested Answers
  • 15190 Answers
SOURCE: Can pregnant women use berkley Jensen women's daily multivitamins and minerals?
check with a or your medical doctor
Posted on Sep 02, 2016
Waterfall pump hums but won't pump
this sure sounds if the impeller is blocked and not being able to turn ,Dont let it run this way , can dammage motor of pump , remove intake cover (unplugged) and wash out with garden hose real well , see if impeller (black plastic blade) can turn with your finger (unplugged) , should move easy ! this might be an indacation of need for a filter on pump inlet !!!
Oct 14, 2012 | Little Giant Submersible Fountain Pump
How to plug in led lights in a water fountain
never seen one but if you look really hard im sure you will find the plug in it is most likley close to the power inlet these lights run off dc power converted from ac power there is a driver somewhere that has the plug in
May 29, 2012 | Home
LOW OUTPUT WATER PRESSURE
Pull the bottom strainer off and check to see if their is anything in the impeller.
Feb 14, 2010 | Pondmaster Mdwp30 - 3000 Mag - Drive...
I can't get the light or the bell to stop flashig or ringing on the berkley pole tap.what do i do?
You MUST have the LED light facing down towards the reel when it is attached to the rod. If it is attached upside down with the LED facing up it will continue to flash or beep nonstop. The simple instructions for the Berkley poletap is -
1.Turn the unit to light or sound.
2.Cast your line,( it will blink or beep as you cast).
3. Set unit in rodholder or against chair,(Poletap will blink or beep about 12 seconds and then stop when still).
4. When a fish nibbles or strikes the poletap will alert with your setting of light or sound.
You may want to check out the new Berkley Poletap Pro, It has complete sensitivity settings for windy days and Tilt - angle for slow pull fish, high current and trolling mode.Awsome product!
Check it out at this Berkley site.
http://www.berkley-fishing.com/prod.php?k=299309&sk=299309&p=PURBAPPBA%20(11187809)
Oct 04, 2009 | Berkley Twist Lock Rod Rack
My flotec 4/10hp waterfall/utility pump was working fine for about 1 hour, now it's only humming and not pumping any water... ?
Clogged, Impeller loose and not turning. Remove strainer from bottom of pump and check for clogg and see if the impeller is turning.
Sep 21, 2009 | Flotec 4/10 Hp 3000 Gph Waterfall Utility...
Parts for Garden Treasures 2 tier fountain
You can find replacement parts on amazon. click here Amazon com tier fountain parts and search for your part. Hope this was helpful. cheers
Apr 05, 2009 | Garden
I have a pondless waterfall and have a problem with excessive foaming.
Here is some info I looked up. Hope this is useful
Don't forget to rate the answer
Kurt
Definition:
Whenever proteins build up in pond water it causes the water to create foam, especially around the area at the bottom of the waterfall. One of the most frequent causes of protein build up is when the fish spawn so we see more foam in ponds during spring when spawning most often takes place. It's not dangerous but can be unsightly. Use fish-safe de-foaming agents to clear water.
What to Use to Clear Up Foam:
go_button.gif Doc's DeFoamer
Mar 18, 2009 | Gard Aquascape Black Waterfall Foam...
3-light LED spotlight kit with remote solar panel #555-208
The Spotlight kit should still be under warranty for at least a year through the manufacturer. Check your manual and contact the manufacturer. The problem might be the seal which is allowing water in and therefore it needs to be replaced
Sep 10, 2008 | Spotlight Aquascape Water Proof LED 2-Watt...
Garden Logo
212 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
