Question about Panasonic Lands Phones
Hi, i have a panasonic cordless phone which keeps on flashing the answer on indicator and play on indicator at the same time.and it shows Base No Power on th e screen.
This happens every time i replace the handset in the base to re-charge it.
  • 201 Answers
SOURCE: In Use LED flashing constantly
Your phone may have lost registration to the base. 1) Try disconnecting the power to the base and then re-connecting the power with the cordless phone in the base. Give it a few seconds, then see if it works. 2) Try removing the battery, wait 10 seconds, re-install the battery and set the phone in the charger.
Posted on Jul 07, 2007
SOURCE: Cordless Handsets don't work
in manual it states that you need to give permission on corded base for handset to link to cordless phone.
Posted on Nov 17, 2007
  • 106 Answers
SOURCE: panasonic cordless phone
You can get yours repaired at , and if you send the handsets they will reregister them to your fixed base at no extra charge.
Posted on Feb 04, 2008
  • 405 Answers
SOURCE: Panasonic KX-TGA101S base not charging.
Here are a couple things you can try.
Clean the charging contacts, this can be done two ways. The manufacture's recommend using a pencil eraser. I recomend using a q-tip and some rubbing alchol. Just rub the alchol soaked q-tip on all the metal contacts on the bases and the bottom of the handset.
Gooo luck.
Hope this helps
Posted on Mar 12, 2008
SOURCE: audioline cordless phone
answering machine not working on the base station
Posted on May 12, 2008
Answering machine on light keeps flashing but does not turn on unit
The headset(s) and the base station need to be re-sync.
Check the bottom contacts (base and headset) and let them sync (3+ minutes) OVER-NIGHT if the headset are low on battery.
This will sync the security code.
Jan 16, 2014 | Panasonic KX-TG1031S DECT 6.0 Expandable...
My att digital keeps flashing "CL" what does it mean and how do I stop it?
Problem Why is CL ( or C ) flashing in the base message window?
Solution(s) This indicates that you need to set the time and day on your answering system. During initial setup and any time there is a loss of power to the base, you will see this flashing indicator. Consult your User's Manual for instructions on setting the day and time. Manuals for most models can found on this site. Go to our MANUALS section, then search for your particular model.
Dec 01, 2009 | Uniden Cordless phone EXS9950
Panasonic Kx-TG2432 Displays E9
Same here on KX-TG2248:
"Answer on" is flashing rapidly.
"Message/Slow Talk" is flashing rapidly.
"In Use/Charge" is flashing irregularly.
LED displays "E3" (and "set clock" symbol is flashing).
Removing and restoring power, many times,
produced one "spontaneous remission"
(it worked fine for several hours)
but next time moved (having to disconnect power),
it's now quite "committed" to remaining "insane" as above.
Jul 28, 2009 | Panasonic KX TG5100M Cordless Phone
I have a panasonic KX-TG2336S cordless phone and when you try to make a call the handset displays "no link to base". Can this be fixed or is the phone shot?
Just in case you don't have a manual
Page 55 lists your trouble and gets you to page 49. You take the bandset and base, press the locator button on the base and then press the flash/recall button on the handset until Handset Registering appears on the display. If it beeps one time, wait 20 seconds and it should register. If it beeps 3 times, keep trying.
Jan 18, 2009 | Panasonic KX-TG2336S Cordless Phone
Semi Dead Panasonic KX-TGA100N with ''C533'' displayed.
Panasonic KX-TG1050N Cordless Phone. Base handset (No. 1, KX-TGA100N) does not work, no keypad response or dial tone. Green indicator message light ON (should only work with the TG1000N base unit) all the time till battery runs down. Display shows message ?C533?. Can still send and receive calls on extension phones 2 and 3.
Nov 11, 2008 | Panasonic KX TG1000N Cordless Phone
Uniden 5.8Ghz phone.
You need to reset the main base unit. Unplug the power from the back of the base. While the power is disconnected, press and hold the delete key while reconnecting the power. Wait for a long beep tone. When the display shows 88 or P, press play button one time. If you have a phone without an answering machine, disconnect the power from the back of the base, press and hold find hs button while reconnecting power.
Jan 20, 2008 | Uniden Cordless Phone
Answering machine replay is garbled
Your handset battery will have no effect on the answering machine audio, providing your regular audio is fine (its fine when you make a phone call right?), I will assume yes. I have seen this problem in these models, and your problem lies in your base station, and the only fix you can attempt is to go into base programming and delete as much as you can out of the memory, greetings, old messages, etc.. Power down, then power back up again. Call in and leave a message. See if it sounds better through the handset or the speaker on the base when you play it back. If its garbled both ways (reviewing through the handset or on the speaker base) , then your problem is in your base memory. If it is just garbled on your handset, then it may be a radio module problem with the base, either way it probably needs to go in for repair. I don't know if Panasonic still repairs that model, but if you google Panasonic cordless telephone repair, you will find someone. Good Luck, CG
Jan 11, 2008 | Panasonic KX TC1731 Cordless Phone
Lands Phones Logo
22 people viewed this question
Top Panasonic Lands Phones Experts
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
