Question about Health & Beauty
I found a foreign object in my sandwich and I'm wondering what can I do with it because I broke my teeth
My mouth was infected and I have my open heart surgery cancelled because my mouth was infected
  • 1,830 Answers
Where did you purchase this sandwich? Contact the owner and tell him what happened.
I'm praying for a speedy recovery. stay on your antibiotics and I hope and pray your surgery goes well.
Posted on May 18, 2017
Metal taste on my tongue,have recently had kidney infection
a metal tast6e on the tongue is an indication of a zinc deficiency or excess
talk with a chemist as to the simple test to determine if a deficiency or an excess
Kidneys are blood filters and the antibiotics used in the treatment may have affected that level
Dec 11, 2017 | Health & Beauty
What can i use for pain around my teeth and gum?
get to a dentist for gum and teeth repair before you get an infection in the gums and the loose teeth fall out
Oct 21, 2017 | The Health & Beauty
My question about bad taste at the back of my throat has nothing to do with my refrigerator. It is when I eat or drink anything.
use a antiseptic mouth wash to your oral routine
next visit seek medial professional advice possible viral throat infection
next dentist visit ask
if you had older style filling materials in any teeth that are breaking down to give you a bad tase .. or gum disease ,decay or abscess
Oct 07, 2016 | Colgate Baking Soda & Peroxide Whitening...
Baby annabell is stuck in the sucking motion even when nothing is In her mouth. What can I do to fix her?
You need to figure out what foreign object is in her mouth keeping the switch from working.
Aug 26, 2016 | The Toys
How do I... Eat a sandwich?
Well First Of All you don't shove it in your face, you put it in your mouth and chew the sandwich. But you will probably choke if you put the whole thing in your mouth. I hope you find this helpful!!!!!!!
Feb 11, 2015 | Kitchen Appliances - Others
The machine stops with 21 minuites remaining the pump is running a clicking noise seems to be coming from the soap dispencer have taken dispencer to bits cant see any stripped teeth any ideas?
See if there is wiggle or play in the tub basket. Open loading door put your hand at the top of basket close to the opening and check movement. There should be no play.If there is water in tub when it stops check the drain hose between tub and drain pump for foreign objects. Let me know.
Jan 11, 2013 | Washing Machines
WM-1280 FHD Machine stopped when about to spin. There is still some water in the drum up to door level. It displays error code OE. What does it mean ?
It means "Outlet Error", your drain pump impeller may be clogged with a foreign object. Just open your easily accessible drain filter (indicated in your manual) and remove the object. If no object is found, it could mean that you'll have to replace the drain pump -> purchase one here: www.appliancespareswarehouse.co.uk/
Good Luck!
* If you found this solution helpful, please vote positively. A 4 four thumbs up will do nicely too :-)
Feb 23, 2011 | LG Washing Machines
I GET A PLS OPEN COVER OFFLINE BUT NOTHING IS
I think the machine is telling you to look inside for a foreign object or scrap of paper:
1) Turn the machine OFF
2) Open the cover
3) Carefully inspect inside for a bit of torn paper, staple, paperclip or other such foreign object - gently clear any problem materials. Do not touch internal parts if possible. Use tweezers for small hard-to-grasp objects.
4) Close the cover, and power ON
5) If the MFC cannot reset itself, or if no foreign material is found, the machine should report an error code, for example "Machine Error XX"
6) From this code, brother support should be able to diagnose and help with your problem
Mar 11, 2010 | Brother MFC 8500 All-In-One Laser Printer
When printing, paper will jam/not feed through. seems like rollers not working properly.
Hello: Jen there is some type of object blocking the paper path, Usually this could be a Paper Clip or some other foreign object,. If you have small children then supect this to be the case, they love putting objects into things. I suggest u unplug the unit and carefully turn the opening where the paper feeds upside down and gently shake the printer to see if you hear anyting rattleing in side I believe the scannig door assembly comes off this unit with a cable connecting it. Just shake the unit while the opening facing floor and see if anything falls out. In my experiences I have found coins paper clips even half eaten peanut butter sandwichs..lol
Hope this helps, please leave comment for futher assistance.
Oct 02, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Foreign object in the disc tray
i know this sounds crazy but press the ope thing on the tray then hit the silver thing with tour index finger a few times and it opens... well it does for me anyway
May 07, 2009 | Microsoft Xbox 360 Console
Health & Beauty Logo
22 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
